4f27e rebuild - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2013, 07:18 AM   #1
Diesel
Diesel's Avatar
Fan#: 86584
What I Drive: 99 zx2, 04 focus wife's car
Points 1,749, Level 24
Points: 1,749, Level: 24 Points: 1,749, Level: 24 Points: 1,749, Level: 24
Level Up 49% Completed
FF Reputation: 2 Diesel Good Standing Member
4f27e rebuild
does any one here have any evperience with rebuilding thefirst gen focus auto transmissions.
I've built 700r4's, escort 5 speeds, spicer 7speeds, and some work to eaton fuller 10 speeds. But nothing on fwd auti transmissions.
Mide pooped out something solid and was wondering if it was an overly complicated transmission to rebuild or should I be able to tackle it. I didn't really see any special tools listed in mitchel.
Rims, fog light conversion, Interrior lighting recolor from starfuryt
Diesel is offline
Old 01-06-2013, 11:14 AM   #2
Points 27,736, Level 98
Level Up 39% Completed
I doubt it is all that complicated. Ford transmissions tend to be fairly simple as far as transmissions go.
Have you called or contacted Lentech? They are the people who build transmissions like the one that 1TurboFocus uses in his 700 hp drag Focus. Their website used to talk about the 4F27e, but I don't think it mentions it now. Even so, I bet they still would be willing to share knowledge or build a transmission. The price wasn't horrible as far as race transmissions go. It's not cheap when comparing it to TCI over the counter built transmissions for RWD, but it is cheap when compared to a custom built transmission.
Old 01-06-2013, 02:36 PM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Level Up 84% Completed
Forum Activity 8%
I would just swap it out with s low mileage used unit, then explore rebuilding the brken unit w/o the pressure of a time constraint.
You will likely need to order parts twice: first the known parts for a rebuild and the broken hard parts, then the correct thickness snap-rings after you begin the assembly and can measure clearances.
I would start with one of these, familiarize yourself with it before you dig in.
elsolo is offline
Old 01-06-2013, 04:43 PM   #4
Diesel
Diesel's Avatar
Fan#: 86584
I was gonna order that. I don't have any "low mileage" units close. they want $650 300+ miles away and a local rebuild is like $1000 and I have like $100 to spare right now.
Diesel is offline
Old 01-06-2013, 08:11 PM   #5
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
There is a gear in there that does not come off without a lot of torque, like 350 ft.lbs. or somesuch. Don't undo it if it still spins smoothly. It uses a crush washer to re-set-up and the gear must turn within a certain spec like pinion in rear end.
If you change any part that affects overall main shaft length then you MUST re-set-up the end bearing/case preloads, special tools required to do that as well as removing the gear I spoke of earlier. Other than that very simple transmission........... that manual will show you what I post here.
Modern transmissions do not set up mainshaft end plays with like shims anymore, they commonly use tapered roller bearings which have to preload like oldschool rear end parts. They last longer but much harder to be able to correctly set them up in the field. Why Ford and others now change complete trans instead of rebuilding themselves. They don't wanna screw with it and easier to find someone else to blame when things go wrong.
amc49 is online now
Old 01-07-2013, 08:55 AM   #6
Diesel
Diesel's Avatar
Fan#: 86584
I'd seen that nut in mitchel. Mitchel said to take it apart.
Not trying to build a race transmission. this thing only races to grocery store and back.
Just don't have the $1000+ for a rebuid
I've build 700r4 (back in the day) cdl 7-10 speeds and the escort MXT.
So I was curious as to how hard/easy these were. I'll probally give it a try.
Diesel is offline
Old 01-07-2013, 08:25 PM   #7
Rebuilders generally leave that nut alone if the assembly still spins smooth, the instructions tell them to in one of the two main aftermarket manuals, I can't remember the other one although I have them both. How to do it is in the back of book but obvious you don't do it unless necessary. That manual is not as good as the one picced here anyway. This one includes some solenoid diagnosis, the other strictly rebuild only and as basic as possible, for 4 year olds.
No different from oldschool stuff. I've done ATX and CD4E to last for years and with no specialized training at all. You simply pay attention to details and use the manual for clearancing. Biggest problem with these is getting around special tooling needed to check those clearances or preloads. I used a piece of surface plate, dial calipers, telescoping hole gauges, and mag based dial indicator to replace the $250 toolset needed on the CD4E, you just gotta figure out other ways to do things.
amc49 is online now
Old 01-07-2013, 09:57 PM   #8
rotarypwr
rotarypwr's Avatar
Fan#: 107786
What I Drive: 88rx7 85rx7 02zx3hatch w/ roush
FF Reputation: 1 rotarypwr Good Standing Member
It is a easy build. Make sure to inspect back cover bearings and sealing rings twice. Also pay attention to reverse drum and piston.
rotarypwr is offline
Old 01-07-2013, 10:17 PM   #9
rotarypwr
rotarypwr's Avatar
Fan#: 107786
And also depending on whats wrong. (Reverse o.d. issue) I repair the back half of this trans in vehicle. Drop trans mount and back mount drop down remove line and back cover and reverse drum can be removed.. oh yea remove band first too.
Old 01-08-2013, 01:53 AM   #10
Yes, that end cover can wear around the lands and sealing rings since it supports one end of rotating mass there. The gear support in the middle splits the mass into two parts, easier to pull the end to do at least one end of it. The CD4E had no center support and the support hub was so long that there was no way to pull cover to do work. It comes off easy enough but almost impossible to get back in because so many parts have to be relined up to mesh.
amc49 is online now
