Blown valve cover gasket + sludge in air box - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-05-2013, 04:58 PM   #21
tazman2
Fan#: 88684
What I Drive: 2000 Ford Focus ZX3
Points 473, Level 9
Points: 473, Level: 9 Points: 473, Level: 9 Points: 473, Level: 9
Level Up 46% Completed
FF Reputation: 1 tazman2 Good Standing Member
Thanks!! Will do!! Is there a seperate back PVC hose as in minus the metal part!? I'd like to just change that hose as mine is collapsed on the intake manifold already! :(
tazman2 is offline
Old 01-05-2013, 05:03 PM   #22
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
There is only one PCV hose.... so what is it that you're thinking is the "back" line? Pic?
PCV= positive crankcase ventilation (emissions controls on cars since the 60's that sucks up crankcase emissions to be burned up in the engine)
PVC= poly vinyl chloride (plastic, good stuff unless it burns, then it emits poisonous chlorine gas in mass quantities)
Old 01-05-2013, 05:05 PM   #23
tazman2
Fan#: 88684
Points 473, Level 9
Well. There is a PCV hose from the intake manifold into a metal piece then back to rubber that turns into the PCV valve. If I have to get the whole thing I'm fine with that but. Rather get the back and front part minus the metal part if possible! :)
tazman2 is offline
Old 01-05-2013, 05:09 PM   #24
Points 3,366, Level 36
Points: 3,366, Level: 36 Points: 3,366, Level: 36 Points: 3,366, Level: 36
Level Up 11% Completed
Forum Activity 42%
Yes, the PCV simply plugs into grommet like most. The rubber right angle turn atop it generally breaks once old enough, the cat heat cooks it. Can't get the bend without buying more hose than necessary, about $25ish at Ford, all to get $2 part. I simply added a loop of PCV straight to attach at 1/4 the cost.
Anarchy, I could tell a really funny story about a lifetime Ford tech who taught auto tech in school here in the mid '70s. He challenged brother and I to a race once the class year long Ford 427 Galaxie drag car project was done. He wanted to 'stomp' our 390 inch AMX into the ground, the results were quite a blow to his ego................my little brother actually swiped the condenser in the distributor to mess with him and the guy gave up trying to get it started, he couldn't figure out what was wrong with it. Spent three days with the class helping him before brother revealed the truth of it. At race day a month later the AMC car dusted the Galaxie so bad it was unbelievable and with most of the class present.
Water in oil there indicates PCV not working fully as elsolo suggested, all I said was that there was water in the oil........................and now you seem to agree.
amc49 is offline
Old 01-05-2013, 05:16 PM   #25
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,234, Level 41
Points: 4,234, Level: 41 Points: 4,234, Level: 41 Points: 4,234, Level: 41
Level Up 43% Completed
Buy-Sell-Trade Rating: (17)
The hose going into the intake manifold has been redesigned by ford. I believe the new hose is a little different and it has insulation around hose. The originals did not have the heat shield and just broke down ov time from heat.
I now drive a Japanese Ford.
macdiesel is online now
Old 01-05-2013, 05:27 PM   #26
tazman2
Fan#: 88684
Points 473, Level 9
Seeing my PCV was rusted and broke in half upon removal and the hose was rock solid and the back hose has NO shielding I'll assume its old if not original from the factory! :o
tazman2 is offline
Old 01-06-2013, 01:29 AM   #27
Forum Activity 42%
If the hose softens and tries to collapse, you can buy time by putting say heater hose size worm drive clamp to compress at the sunk in area to squeeze it back open. I've had one running like that for a year now. When they finally let go I usually put my own setup on there to not have to buy any more expensive hose, just ain't done that one yet. Other car I did myself still running fine many years later, can't even remember when I did it.
amc49 is offline
Old 01-06-2013, 08:22 AM   #28
macdiesel
macdiesel's Avatar
Fan#: 31579
Luckily, the hose in question isn't pretty cheap to replace.
Old 01-07-2013, 09:42 AM   #29
tazman2
Fan#: 88684
Points 473, Level 9
BTW, Tousley Ford is a dealer who gives FFs special pricing. Look them up online, they are in WI. Call the number for parts, ask for Steve, tell him you heard about him on Focus Fanatics, and then order whatever factory parts you need. It will be a whole lot cheaper than your dealer, even after you pay for shipping.
That sort of thing might fit your schedule better than having to take off work to go to a local dealer.
I've dealt with them before from your tip many moons ago but I'm having trouble finding their info again. Only Tousley Ford I can find is in MN...
tazman2 is offline
Old 01-07-2013, 11:33 AM   #30
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,620, Level 62
Points: 8,620, Level: 62 Points: 8,620, Level: 62 Points: 8,620, Level: 62
Level Up 57% Completed
Forum Activity 27%
^^^ that would be him. you will have to have it shipped to you, but the discount is usually enough to still offset the cost of shipping.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
