How-To: Custom block heater plug mount through Euro grille - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-07-2013, 11:17 AM   #1
swansong
swansong's Avatar
Fan#: 83576
Points 2,307, Level 29
Points: 2,307, Level: 29 Points: 2,307, Level: 29 Points: 2,307, Level: 29
Level Up 5% Completed
Have a Euro grille with the flip out badge?
Like to use your engine block heater, but hate opening and closing that darn hood every time?
Have I got the solution for you!
Inspiration credit for this project goes to OrangeSVTguy and this thread.
Feature/Parts/Tools needed:
1. Winter package, with engine block heater
2. Euro grille, with flip-over badge
(Aside: I realize that there are probably very few cars with this combination, but oh well!)
3. Dremel with cutting wheel, or similar tool
4. Small saw or sharp kitchen knife (optional)
5. Zip-ties
6. Epoxy, super-glue, etc. to secure plug.
7. 10mm socket, probably a 6" extension.
Step 1:
Remove radiator cover thing (snap clips, may need screwdriver). Remove grille, two 10mm bolts.
Step 2:
Check out the hood latch area, and notice how there's the part sticking out that would normally be used for the key lock mechanism. It sticks out too far for our purposes, so start sawing/Dremeling this away. I found that a sharp kitchen knife actually worked better than the Dremel for whatever reason. I think I removed about 3/4 inch of material.
Step 3:
Keep removing material until you can do this with your plug. As you can see, the support structure inside all this plastic seems to hold the plug in perfectly. It's like it was meant to be.
Step 4:
Modify the grille. You'll have to widen the dime-sized keyhole to fit a rectangular 3-prong extension cord. Exactly how wide to make this hole will depend on the cord you want to use. Just keep removing material until it fits. The extension cord plug will actually go through the grille and meet up with the plug.
Step 5:
Reattach grille, test fit, modify if need be.
Step 6 (optional):
If you haven't done so already, cut the grille to create recessed area for the hood latch release. Mine looks like this.
Step 7 (optional):
Secure the plug. Use epoxy, glue, whatever you like, just make it work. Consider using zip-ties to secure the block heater cord to things in the engine bay to keep it from moving around.
Step 8:
Put it all back together. I suggest routing the plug cord under the radiator cover and securing it with zipties.
Disclaimer: I actually have not yet secured the plug in any way, and I don't think I will. The plug just sits in the latch area, and stays there from friction. What this means is that I have to open the hood to plug in the extension cord (it takes some force), but I can then close the hood and forget about it. I plug in at night, and the outlet is on a timer that comes on a few hours before I go to work. In the morning I just unplug, flip the badge, and off I go. I don't want to secure it because I may want/need to remove the grille and separate the plug from the grille without ruining either. If that doesn't concern you, go ahead and permanently attach them for easier plug-in.
That's it, hopefully someone else finds this useful, I sure love it! Now I can make "Look at my silly electric car!" jokes too!
Mine: 2008 Saab 9-3 Aero SportCombi XWD: 92k, Black, Manual, JZW Stage 1. 320hp/400tq.
Gone: 2002 SVT, #1654
Hers: 2010 Focus SES: 84k, Ebony, Auto, Moon and Tune
swansong is online now
Old 01-07-2013, 11:29 AM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
Buy-Sell-Trade Rating: (18)
Genius!
SkyPilot is offline
Old 01-07-2013, 03:22 PM   #3
Black00ZX3
Fan#: 104714
Points 1,902, Level 26
Points: 1,902, Level: 26 Points: 1,902, Level: 26 Points: 1,902, Level: 26
Level Up 2% Completed
FF Reputation: 3 Black00ZX3 Good Standing Member
Originally Posted by skypilot View Post
genius!
+100
Black00ZX3 is offline
Old 01-09-2014, 12:28 PM   #4
Bandrew
Bandrew's Avatar
Fan#: 79705
What I Drive: 2003 Pitch Black ZX3 SVT
Points 58, Level 1
Points: 58, Level: 1 Points: 58, Level: 1 Points: 58, Level: 1
Level Up 16% Completed
FF Reputation: 3 Bandrew Good Standing Member
I used your idea as inspiration, but took it a step further and used a IEC power jack (Like a computer uses).
Here is the grill when latch is closed. I plasti dipped the grill.
Here it is open. You can see the plug.
Here it is plugged in. The cable I'm using is a 25ft 14AWG Power Cord from monoprice.
Bandrew is offline
Old 01-09-2014, 01:37 PM   #5
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,448, Level 65
Points: 9,448, Level: 65 Points: 9,448, Level: 65 Points: 9,448, Level: 65
Level Up 33% Completed
Forum Activity 10%
That is a kick ass idea! If i had to use one of these I would definitely do it.
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is offline
Old 01-09-2014, 01:42 PM   #6
swansong
swansong's Avatar
Fan#: 83576
Great idea! Did you just slice the old cord and new IEC jack together? I might consider doing something like that.
To be honest I haven't utilized my front grille plug in trick since last winter. The heater plug and the cord I use to plug it in take quite a bit of force to separate, and by trying to unplug them numerous times I stretched the hole in the plastic such that the heater cord comes right through with very little effort . So I'm back to leaving the hood up overnight until I decide to get creative again.
Old 01-09-2014, 01:52 PM   #7
Bandrew
Bandrew's Avatar
Fan#: 79705
Points 58, Level 1
I didn't connect it directly. I just have a adapter cord that plugs into the heater plug. so if I ever want to use a normal extension cord all I have to do is pop the hood an unplug the adapter.
To make the adapter I cut about a foot off the female end of an extension cord and then soldered the IEC jack to the end.
I actually ran the cable through first because it wouldn't fit with the jack on it.
Then I soldered the jack on. I don't have any pictures of it mounted but its held in place with some long screws.
Bandrew is offline
Old 01-09-2014, 02:23 PM   #8
swansong
swansong's Avatar
Fan#: 83576
Good stuff!
Old 01-09-2014, 02:59 PM   #9
volcomstone1966
RIP 02 SVT 0209
volcomstone1966's Avatar
Fan#: 35104
What I Drive: 04 PWSC EAP SVT - 04 Kawasaki ZX6R
Points 16,708, Level 82
Points: 16,708, Level: 82 Points: 16,708, Level: 82 Points: 16,708, Level: 82
Level Up 72% Completed
FF Reputation: 15 volcomstone1966 Great Standing Member
Buy-Sell-Trade Rating: (45)
i like the idea , but i never use my block heater and have the euro hood latch
04 SVT EAP #1131 -POWERWORKS-Torsen-Clutch Masters-Top Speed-Massive-Brembo-Fifteen52-Steeda-UNDER CONSTRUCTION
2K14 Turbo Veloster
04 Kawasaki ZX6R
volcomstone1966 is offline
