Restarting Issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2013, 05:28 PM   #1
JJMcKinney
Fan#: 108097
What I Drive: 2003 White SE
FF Reputation: 1 JJMcKinney Good Standing Member
Angry Restarting Issue
While I was driving, my 2003 Ford Focus 2.0 SOHC split port just stopped, no warning, no noise, nothing, just stopped running. When I tried to restart it, the motor will turn over like it wants to start, but will not catch. I just replaced the idler pulley as well as baring went out. Since the re-starting issue, I have checked the fuel pump and it checks out fine, checked the spark and is getting spark, compression is good. Replaced the spark plugs, and fuel filter, but nothing. I also verified the timing belt was intact and not broke nor missing teeth. Today I replaced the Cam position sensor and still nothing. I'm starting to think it could be the crank sensor, but not 100% sure and do not have my tools with me to test it. The focus has 104000 on it and now I am stumped as to what the problem might be. Any help would be greatly appreciated, Thank you!
JJMcKinney is offline
Old 01-07-2013, 03:04 AM   #2
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
put a scan tool on it and are there any trouble codes?
tmittelstaedt is offline
Old 01-07-2013, 06:09 AM   #3
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Crank position sensor bad = no spark.
You might have weak spark, have you done a resistance test on the coil? I've had this problem once- where I used a spark plug tester (timing light), and it flashed, but I was getting a weak spark. I don't know what spark plug tester you used, but a resistance test might be prudent at this point. You'd find high primary resistance in this case. I don't know specs for the Focus, but typically anything over 15 ohms is not good.
Fuel injection fuse? That protects power to the injectors, but not the fuel pump. You'd have good fuel pressure right up to the rail. Test for power to ground on one of the injectors. You should get power on one side. In most cases where I've tested injectors the injector has power on one side, then when it operates, the ground is what is switched.
Old 01-07-2013, 06:28 AM   #4
JJMcKinney
Fan#: 108097
Posted via FF Mobile
Thank you I will have to check those things out, as there are no trouble codes I may just take it to a shop as most of this is outside what I know how to do and don't have the proper tools to do it
Old 01-11-2013, 10:23 AM   #5
JJMcKinney
Fan#: 108097
Where is the Fuel injection fuse located, I cannot seem to locate it and it's not listed in my owners manual?
Old 01-11-2013, 11:12 AM   #6
Forum Activity 10%
My bad. I don't own one of those exact Focis, so things can be a bit different. It's probably #9 under the hood which is the Engine management fuse. First you should check the fuel injection for voltage with the key turned ON.
