Purolator Oil Filter Question - Focus Fanatics
Old 01-05-2013, 07:21 PM   #1
scada
Fan#: 107778
What I Drive: 2013, Silver, Focus S
FF Reputation: 1 scada Good Standing Member
I tried searching for it, there was a post that listed a Purolator filter that is longer than the PL10241 the FoFo calls for. I did mine yesterday and there is plenty of room for the longer one and would like to go to that for the next oil change.
by sadicarnot, on Flickr
scada is offline
Old 01-05-2013, 08:20 PM   #2
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 53 felixthecat Excellent Standing Member
Try a Motorcraft FL842 or a Fram TG16 or similar.
felixthecat is online now
Old 01-06-2013, 01:08 AM   #3
6769MOPARS
6769MOPARS's Avatar
Fan#: 86108
What I Drive: PB Focus ST2 and 67 426 Hemi GTX
FF Reputation: 1 6769MOPARS Good Standing Member
I'd avoid the Fram. I use Motorcraft on our two Focuses and the Purolator PureONE on my 426 hemi.
6769MOPARS is offline
Old 01-06-2013, 01:11 AM   #4
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
Before going for the longer filter I would make sure it actually has more filter material (it may actually have less), that it filters as well as OEM, and it has the correct bypass.
Hatch Nation #29
Joeywhat is online now
Old 01-06-2013, 09:03 AM   #5
dan50
Fan#: 91789
FF Reputation: 11 dan50 Great Standing Member
Unless the filter manufacturer approves a specific filter for a specific car, why take a chance while your car is under warranty. While it's really unlikely, if you have an engine problem under warranty and you've used an unapproved oil filter, it's one more excuse for the manufacturer to be difficult.
Ford in particular is really fussy about filters. If you have any complaint about engine noise, the very first question they will likely ask is what filter you're using. If it's not a Motorcraft, they will suggest that is the problem.
If you use an unapproved filter and an engine problem develops, do you really think Purolator or Motorcraft will stand behind you?
dan50 is offline
Old 01-06-2013, 09:20 AM   #6
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
FF Reputation: 11 kam327 Great Standing Member
What's an "unapproved oil filter"? Ford says right in the manual that another brand filter of equivalent performance can be used.
The only place it talks about voiding the engine warranty is with regard to additives.
kam327 is online now
Old 01-06-2013, 01:08 PM   #7
dan50
Fan#: 91789
I mean unapproved by the filter manufacturer. So, if Purolator says an P10241 is the filter for the 2012 Focus but you decide, like the OP, to use a different Purolator because you think it fits/filters "better", it's conceivable you could have a problem. I agree if you use the filter Purolator specifies for the car there shouldn't be an issue.
dan50 is offline
Old 01-06-2013, 02:49 PM   #8
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
FF Reputation: 1 Dgc333 Good Standing Member
The specified Motorcraft filter for the Focus is the FL910S this filter is also specified on a lot of Chrysler products (Chrysler and Ford have had the same gasket and thread since the 60's and have used the same filters). The FL910S is what is called out on the NA Chrysler 2.0 and 2.4, the turbo 2.4 calls for a Motorcraft FL400S which is a couple of inches longer, this filter is also used by Ford on a lot of the v6 engines.
I have been using the FL400S on our 12 Focus since the first oil change 22k miles ago.
Dgc333 is online now
Old 01-06-2013, 02:51 PM   #9
scada
Fan#: 107778
Purolator makes a filter exactly the same as the P10241 except for the length. If you have the clearance it is common for 2 filters to be exactly the same except for the physical length. There is plenty of room in the 2012 FoFo for a longer filter. If you use a longer filter you benefit from it having a higher surface area as well as being able to hold more oil.
scada is offline
Old 01-06-2013, 03:05 PM   #10
dan50
Fan#: 91789
If you're positive they are identical in all other respects, including how the bypass valve is calibrated, and the additional filter media doesn't cause an oil pressure drop, go for it. For me, the extra bit of oil and filtering capacity aren't worth a debate with Ford in the admittedly unlikely event of an oil-related problem.
dan50 is offline
