Old 01-05-2013, 10:53 AM   #1
Rally Steve
Fan#: 107312
What I Drive: 2013 Focus
FF Reputation: 1 Rally Steve Good Standing Member
Stability Control
I would like to know how to disable the Electronic Stability Control and keep the antilock brakes and the traction control unless it is turned off. Ideally I would like to put a switch somewhere to turn it on or off.
Any help would be appreciated.
Thanks,
Rally Steve is offline
Old 01-05-2013, 12:36 PM   #2
zehkaiser
Fan#: 98706
What I Drive: 2012 Tux Black Focus Titanium Hatch
FF Reputation: 1 zehkaiser Good Standing Member
My understanding is that all of that was run through a single fuse (that people were using for a switch to enable/disable all). I'm not sure you can disable just ESC with a switch.
zehkaiser is offline
Old 01-05-2013, 12:42 PM   #3
erato
Fan#: 97294
What I Drive: 2012 Candy Red Ti Ecoboost estate
FF Reputation: 1 erato Good Standing Member
In the EU ESC will be mandatory on new cars in a few years. Guess the option to turn it off will go out the window simultanously.
erato is offline
Old 01-05-2013, 12:47 PM   #4
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
FF Reputation: 7 BetaDnB Good Standing Member
Can't be done at the present time. Hopefully somebody will release a tuner within the next century that will make this possible.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/betadnb
BetaDnB is offline
Old 01-05-2013, 12:48 PM   #5
Rally Steve
Fan#: 107312
When you unplug the fuse you disable the traction control, anti-lock brakes and the speedo.
Where is the Yaw sensor located?
Old 01-05-2013, 03:58 PM   #6
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2013 Tuxedo Black Focus SE Hatch
FF Reputation: 1 MetalMuffins Good Standing Member
Where did you get that the speedo is disabled???
I have wired an over-ride switch on the fuse to disable the TCS/ESC/ABS etc. and the speedo works fine with the switch off (everything disabled).
On that note, I don't believe there is any way to disable just certain parts of the system. It's all or nothing until there is a tune done for the car.
2013 Focus HB - Tuxedo Black, 201A, Black Pack, 5 Speed
MetalMuffins is offline
Old 01-05-2013, 09:58 PM   #7
yeroc40
Fan#: 2581
What I Drive: 2012 SE Sport YB 5-sp
FF Reputation: 1 yeroc40 Good Standing Member
did you happen to post a how-to, or have a link to the info? I'd like to do this mod. Did you use a relay, or direct switch?
yeroc40 is offline
Old 01-05-2013, 10:45 PM   #8
MetalMuffins
Fan#: 107135
Well I got some supplies the other day and managed to get a switch wired up to disable the TCS, ESC, and ABS. If you read one of my earlier posts in this thread, I have went over the effects of pulling the F19 5A fuse when driving. This is a short how-to if you want to wire up your own.
Sorry I did not take any pictures when installing, so these are all taken after the install was completed.
The switch is a simple on/off rocker switch. This must be wired into the fuse box via two wires that will run to the engine compartment through the fender. This I found was the easiest way to run the wires without modifying the car.
The switch is zip-tied to the wire running into the ambient lighting under the foot-well. This lets the rocker switch fit in between the kick panel on the side and the heat vent. It is very out of the way and won't be kicked.
The switch is wired as follows. I wish I had taken a picture of how the switch was wired before installing, as this is the most confusing part of the install.
1) The first wire from the fuse box must be connected to the switch
2) Make a very short wire with two female spade connectors, this will run from the other pole of the switch to the 5A fuse that is zip tied to the side of the switch.
3) Connect the female spade connector on the second wire running back to the fuse box.
This is a picture showing the cabin where the wires are running through the fender. You can push the wires right into the engine compartment and around the back of the fuse box.
This picture shows the inside of the fuse box where the wires run into the box. You do not have to modify anything, but I recommend pushing the wires through from inside the fuse box. You have to remove the plug for the fuse box to do this, but can be done easily by lifting the blue lever. Note the is a small black tab that must be pushed aside to lift the lever.
You can remove the plastic holder for the three fuses that control the TCS/ESC and install the two main fuses by themselves.
I connected the wires to the F19 fuse connector with male spade connectors. You can cut them in half with strong wire cutters and file them smooth. This makes them the same size as ATM fuse prongs. You can see the hole where the wires run in the picture above.
The picture below shows everything closed up. You can see the wires running into the fender. They run around the top of the fuse box and enter under the main harness plug. Again, I recommend running the wires from inside the fuse box and than around the top and through the fender to the interior.
I have tested this and it works like a charm. Once again, I wouldn't recommend leaving the track control off for normal driving, and I feel the system does an OK job, but this will allow you to turn it off easily if you want / need to in a pinch.
Please let me know if you have any questions, and you can view all of the pictures I took here: http://s1305.beta.photobucket.com/us...ffins/library/
Copy/Paste from this thread: http://www.focusfanatics.com/forum/s...=275688&page=7
Direct switch and no mods to the car itself, completely reversible. Cheers
Old 01-05-2013, 10:52 PM   #9
Kabigon
Fan#: 88299
FF Reputation: 5 Kabigon Good Standing Member
The yaw rate sensor, longitudinal accelerometer, and lateral accelerometer are located in the RCM (restraints control module).
The RCM also controls the airbags.
Kabigon is offline
Old 01-06-2013, 08:20 AM   #10
yeroc40
Fan#: 2581
Awesome, thanks MM!
yeroc40 is offline
