Squealing brakes while stopping - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-04-2013, 11:52 AM   #11
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,632, Level 94
Points: 23,632, Level: 94 Points: 23,632, Level: 94 Points: 23,632, Level: 94
Level Up 29% Completed
Forum Activity 16%
Originally Posted by Dardas View Post
My rotors look fine, they are quite shiny. i think the pads would be the first thing to replace. but i was not sure if the drums needed to be replaced as well because they look rusty
Check it out, like I said... you DON'T want nice and shiny rotors.
mikebontoft is online now
Old 01-04-2013, 01:01 PM   #12
VinnyB
VinnyB's Avatar
Fan#: 97705
What I Drive: '03 Screaming Yellow EAP
Points 1,199, Level 18
Points: 1,199, Level: 18 Points: 1,199, Level: 18 Points: 1,199, Level: 18
Level Up 99% Completed
FF Reputation: 18 VinnyB Great Standing Member
What does it mean if your rotors are shiny? My rotors are shiny, but I'm getting ready to replace the brake pads. (Not to mention, I think I need to have my rotors cut)
If it wasn't for law enforcement & physics, I'd be unstoppable.
VinnyB is offline
Old 01-06-2013, 01:22 AM   #13
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
If you drive fast and ride brakes hard you will get squealing... Drum brakes get over polished when you ride them hard and will resonate. nothing you can do other then replace the drum with OEM, DO NOT BUY EBAY!! I cannot stress that enough, I went thru 3 cheap drums on ebay then just bought OEM and lasted 3 more years..
this is commonly known as Glazing..
Pads to make a difference..
VEGAS is offline
Old 01-06-2013, 02:12 AM   #14
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,186, Level 100
Points: 138,186, Level: 100 Points: 138,186, Level: 100 Points: 138,186, Level: 100
Forum Activity 53%
Buy-Sell-Trade Rating: (11)
The rear drums are notorious for squealing on our cars. Usually it's from brake dust build up. Take the drum off clean it out and readjust the shoes fixes it most of the time.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-06-2013, 08:01 AM   #15
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,998, Level 74
Points: 12,998, Level: 74 Points: 12,998, Level: 74 Points: 12,998, Level: 74
Level Up 37% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (45)
Moved to "Tires, Wheels, Brakes & Suspension".
zetecDon is offline
Old 01-06-2013, 09:00 AM   #16
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
It doesn't take much either. Mine is usually a tiny bit of rust ( rear drums ). I take a brass mallet and smack the drum while spinning it. Very little falls out, but it's good for quite awhile.
TerryB is offline
Old 01-06-2013, 11:41 AM   #17
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
I've had this happen. You can try to change pad brands, that usually fixes it. The disc brake quiet goop you put on the back of the pads also can help in some cases.
But, you might want to leave it alone.
Where I live, people glare at you if you touch the horn - no driver uses their horns, it's considered bad form, I guess. I can live with that - except that at every street corner pedestrians constantly walk out into the street - in front of cars - against red lights - you name it.
I found when I approached a stop sign that if I lightly touched the brakes the things would squeal the loudest - so I would get them screaming a block or so away - and by the time I got to the sign the noise would have cut through to even the most stoned/high/moronic pedestrian and they would be backing away from the curb, not running out in front of me.
It was a sad day when those pads wore out - and I have never been able to get replacements to scream like that.
tmittelstaedt is offline
Old 01-07-2013, 02:03 AM   #18
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
If you grind off the right angle 90 degree corner to a 30-45 degree bevel where the pad material ends the noise will disappear for good. Dust makes it worse but not the cause, relubing the shoe rub points makes it better but not the cause. The right angle corner digs in to let the shoe snag and go forward until it snaps back to repeat at very high speed, the reverberation turns into squeal. I've fixed several now doing this and permanently. Will even fix the loudest squealing you ever heard. Takes two-three minutes on a bench grinder to do it. The Ford backing plates are too thin and ring that vibration like a bell.
amc49 is offline
