#1 | ||||
What do I need to get more bass to my sub and amp through my stock HU?
So, I have my sub and amp installed and it sounds pretty good but the factory hu is keeping me from turning up the bass. I am afraid I will blow the speakers so I dont want to turn the bass all the way up. Is there anything I can buy for bass boosting the sub without buying a new HU? Also there is no bass boost on my amp, just a gain contrtol.
DD: 2003 Ford Focus ZX5-65mm TB, Intake, Long Tube Header, 2.5" exhaust, UDP, Tom's Tune. Almost 200k miles and still running strong! |
Remove Advertisements |
#2 | ||||
ok wow nevermind lol. my amp wasnt even turned on, no wonder my speakers were blasting. so i guess im good with the original question but i would still like to know if i have a 200w amp and 300w rms sub, would it be ok to turn up the gain all the way? its 3 quarters of the way up now, but im afraid to turn it up all the way just in case. thanks for the help guys.
#3 | ||||
FocusFest Event Team
first you can put some bass blockers on the speakers to keep them sounding better; or get an eq to seperate sound better. the amp just needs to be tuned properly. depends what all the equipment is as to how it needs to be set.
2013 F150 4x4 SCrew XLT 5.0L Midwest Crew #22 Official FocusFest Event Planner
#4 | ||||
pretty simple, do what I did, here the thread about it
http://www.focusfanatics.com/forum/showthread.php?t=304837 |
#5 | ||||
nice, thanks for the info fellas
#6 | ||||
A few things can possibly help your situation
first things first, I wouldn't turn up the gain on the amp, as that is what distorts subs and can blow them. You need to find a good point that makes them sound nice without distortion. These are the steps you need to take to tune your sub and set the gain http://knowledge.sonicelectronix.com...tview-132.html Once this is done, if you still want more bass, you may need a better box that is tuned to the subwoofer. Box is everything and is key to a good bass sound. you can also get a better subwoofer that can handle more power, but you will need to get a better amplifier that matches the subs specifications (match RMS power from the sub and amplifier) Make sure your cables are in good condition and installed correctly. Typically you want 4 gauge for anything over 350-400 watts RMS. It would also be wise to do "the Big Three" (rewiring for bigger 4 gauge battery cables from the alternator and grounding strap) Again just make sure that you tune it correctly on both the amp, and the box, make sure your cables are good, and if you still want more, buy new gear dont' worry about a capacitor. they don't do much good if anything at all ![]() good luck ;) |
