Wheel Bearing the same for SVT vs ZX3? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-28-2012, 12:20 PM   #1
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,401, Level 61
Points: 8,401, Level: 61 Points: 8,401, Level: 61 Points: 8,401, Level: 61
Level Up 84% Completed
Forum Activity 30%
Looking at getting some wheel bearings but my ZX3 has been converted on the front brakes to the SVT. doe they use the same Bearings?
I am looking at the TIMKEN Part # 510056 is this the right part #???
Or i might just go with a whole replacement. and get the Timken part # HA590263K. Looking on their site it says 00-07 all motors so just wanted to double check.
Thanks!
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 12-28-2012, 12:45 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,604, Level 53
Points: 6,604, Level: 53 Points: 6,604, Level: 53 Points: 6,604, Level: 53
Level Up 27% Completed
Forum Activity 48%
Activity: 48% Activity: 48% Activity: 48%
Buy-Sell-Trade Rating: (23)
They are different knuckles. I am not sure about the bearing. Perhaps one of the other Mods can chime in here.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 12-28-2012, 12:48 PM   #3
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
thanks, I know the knuckles are different (different caliper mounting for the larger rotors). But the bolt pattern is the same, the axles are the same, so I am guessing the bearing and hub assembly would be the same. but sometimes manufactures do weird stuff... all the sites don't discriminate/specify the motor so would assume that means it works on all Foci from 00 to 07? Thanks for the quick feedback!
Hatch Nation #42
Old 12-28-2012, 02:58 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Yes, same bearing. I have SVT brakes on my ZX3, too.
BC_ZX3 is offline
Old 12-28-2012, 03:03 PM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
Great. Thanks. I decided to order the hub and bearing kit. Amazon has it for only $19 more get a fresh hub and comes with the axle nut also. Figured it was a good deal. Thanks for the feed back.
Hatch Nation #42
Old 12-28-2012, 04:36 PM   #6
rsnow
Fan#: 105358
What I Drive: 2002 pitch black svt
FF Reputation: 1 rsnow Good Standing Member
sometimes the only difference in bearing is the svt ususally has abs, if your zx3 has abs you will need to order such. has a magnetic ring on bearing facing abs sensor
rsnow is offline
Old 12-28-2012, 05:57 PM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
Nope the ZX3 does not have ABS, the sensor was in the knuckle but cut right after the plastic molding.
Hatch Nation #42
Old 01-02-2013, 08:43 PM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
So to follow up. I got the bearings kit.
I dont have ABS so is their a right or wrong direction to press these in? If so what direction? Red rubber seal towards wheel?
Edit: looks like the black side has the ABS in it. And can check using a small paper clip. Will double check when I get home. Even though I don't have ABS want to make sure I don't want to cut corners in the event their is a reason to install them in 1 direction vs the other.
Hatch Nation #42
