Fan blower making noise~~ - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2008, 02:51 AM   #11
Cheffy
Fan#: 33581
What I Drive: 2001 Pitch Black SE Wagon
FF Reputation: 8 Cheffy Good Standing Member
I removed and cleaned the fan using brake cleaner to remove some built up dust etc, then I lubricated as suggested above. I sprayed some good penetrating lube first, then pushed some moly grease (it was available) in too, then added some more penetrating lube to help disperse the grease. So far so good, I've had some cool mornings and the fan has yet to squeak. We'll see how well it holds out in winter.
Cheffy is offline
Old 09-26-2008, 01:04 AM   #12
fastfocussvt87
fastfocussvt87's Avatar
Fan#: 59141
What I Drive: 2002 Blue SVT focus
FF Reputation: 4 fastfocussvt87 Good Standing Member
^^^^ Cheffy's got the right idea, just lube the heck out of the parts that move. not to sure about the moly grease, but hey, whatever fixes it.
02 SVTF, ORP, SRI, modified counterweight bracket. without the weight, short throw shifter, and many a modds to come.
i am #173 of 1184, sonic blue with blue interior SVTF's born during the year of 2002. And proud of it.
fastfocussvt87 is offline
Old 11-02-2008, 04:59 PM   #13
lukeykookey
Fan#: 60291
What I Drive: focus
FF Reputation: 1 lukeykookey Good Standing Member
Talking These diagrams may help
Hi all,
I was completely confused by all this, looking to get the motor out through the glovebox.
After searchingn for aaageas and actually paying someone, I now have diagrams which I shall share with y'all!
Firstly go into the glovebox. Push the sides of the glovebox in, each side at a time to give the rubber bungs clearance. On the left there is a little black piece of plastic like a hinge, push this to the right and it will undo. Then drop the box right down. Remove the screw directly facing you, you can see the top of this part here
Then remove the felt like panel that is UNDER the glovebox, there is one row of 3 phillips screws, ignore these completely. Look lower. There are actually 3 phillips scrivets (screws and rivet combo) here. Carefully undo the screws - if you push too hard they will go back in - then pull them out with their housing.
You get under the blower this way. Then undo the three phillips screws from underneath, one on each side and one at the back.
And bobs your uncle. There is a grey clip on the electrical connector, push it towards the connector and pull.
Installation is the reverse of removal.
Hope this helps.
lukeykookey is offline
Old 01-10-2009, 08:37 PM   #14
shane_c
Fan#: 53658
What I Drive: 2004 Light Tundra SE Wagon (SPI)
FF Reputation: 1 shane_c Good Standing Member
Mine makes a high pitch squeak when it's on setting #1 and I turn the steering wheel to the left. Once it warms up a bit I'll have to get in there and re-grease the thing.
2.0L SPI, automatic
shane_c is offline
Old 11-12-2011, 06:38 PM   #15
JCHogan
Fan#: 91710
What I Drive: 2000 Gold
FF Reputation: 1 JCHogan Good Standing Member
This is a great help. My problem is different as I live in the country and I had a mouse eat through the plastic grid that is supposed to keep foreign objects out. The mouse died and the stench is nasty. Fixed the intake by attaching 1/2 hardware cloth. Hopefully that will dissuade any critter from chewing their way in again. (Also removed a massive nest)
BTW. 2000 SE with 265K miles. Also, forgot about the timing belt the first time. It only lasted 198K miles. Still getting about 30 MPG in the summer and about 28 MPG in the winter. Only real problem is lack of power. I doubt I can claim 90 HP any more. Too bad they no longer make the SE. Nice little car for commuting.
JCHogan is offline
Old 11-13-2011, 01:43 PM   #16
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
Do it right once.
Here's my 2 cents worth. NAPA sells a Chain and Cable Lube sold under a can # Macs 1370. It's pricey, but you use very little to get the squeaks out. I've had a can now for a yr. and still got more in the can. Cost about 8-9 American bucks. Goes a long way.
And no I ain't a NAPA dealer! lol.
coldbear is offline
Old 11-26-2012, 03:13 PM   #17
gondorian
gondorian's Avatar
Fan#: 105695
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Mine was squeaking too so I pulled it out and vacuumed it up and lubed it and it stopped squeaking. There were definitely some leaves in there. While I was at it I installed a cabin air filter so that I wouldn't have to worry about leaves any more.
I used tri flow lube for it because that is what I had around and I use it on bikes to good effect. Pretty much any good lube will work (WD40 is not a lubricant).
gondorian is offline
Old 11-26-2012, 04:33 PM   #18
Elder
Points 12,818, Level 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Level Up 92% Completed
Tri-Flon is good stuff, straight 30W (couple drops) has kept mine going for a couple years now after the annoying low speed squeak started...
The squeaky wheel.... got the grease!
sailor is online now
Old 01-02-2013, 08:22 PM   #19
iB Chunkyboy
Fan#: 105705
What I Drive: White 2001 Ford Focus LX 4DR Sedan
FF Reputation: 1 iB Chunkyboy Good Standing Member
Pics don't work :[ help please
iB Chunkyboy is offline
Old 01-02-2013, 08:38 PM   #20
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Level Up 84% Completed
Forum Activity 8%
You don't need pics or some written document.
Just look down under the glovebox, it's as straightforward as a job could be.
Three screws to remove glovebox door.
Two plastic push pins to hold the soft trim cover.
Three screws to remove fan motor.
Nothing is hidden, it's all in plain sight.
elsolo is offline
Similar Threads
'00 - '03 Ford Focus Fan Wiring Durango_Boy General Technical Chat 6 11-03-2007 01:42 PM
fan switch or blower relay needin help General Technical Chat 4 08-09-2004 01:07 AM
A/C & blower motor problem....HELP, I'm burning up! BlownSkillet General Technical Chat 10 07-07-2004 07:07 AM
2000 focus blower fan location needed guest General Technical Chat 3 07-06-2004 10:56 PM
Volant Scoop or boat blower microtonal Ford Focus & General Car Chat 4 05-11-2004 05:05 PM
