Help!!! Some one ! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-01-2013, 10:24 AM   #1
02blacksvt
Fan#: 105081
What I Drive: black 02 svt
FF Reputation: 1 02blacksvt Good Standing Member
Help!!! Some one !
Okay, i live in Cincinnati ohio i was driving up 75 to Dayton last night and i was in 6th gear at about 70mph at about 3k rpm.. okay well i was just minding my own buisness and then all of a sudden the rpms shot up and the speedometer did to and the car like started to bog and cut out alittle and then i down shifted to 5th and stayed there for a sceond and then i went back to 6th and everything was okay and then it did it the rest of the way to dayton off and on multipul times. and sometimes it would even do it in 5th and 4th and id have to go as low as 3rd gear and then go to 4th then 5th then 6th. i have no idea what this could be? i still have a good clutch so i dont think it is that. Ecm maybe? im really lost, if anyone has any suggestions or have had this problem before please help
02blacksvt is offline
Old 01-01-2013, 11:53 AM   #2
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
FF Reputation: 17 BLRich1 Great Standing Member
Moved to "General Technical Chat"
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 01-01-2013, 02:22 PM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,596, Level 30
Points: 2,596, Level: 30 Points: 2,596, Level: 30 Points: 2,596, Level: 30
Level Up 98% Completed
Holy run on sentence batman.
I rad that three times, here is what I think you said:
RPM's climbed unexpectedly while cruising steady throttle in 6th gear, and engine ran crappy.
This happened again a few more times, in several gears.
You downshift when this happens, and it seems to go away after a moment?
elsolo is online now
Old 01-01-2013, 03:14 PM   #4
02blacksvt
Fan#: 105081
hahah yeah my bad im kinda freaking out about it, so i apologize. but yeah that is the jist of what was/going on.. but once i would down shift then shift back to 6th it would go away for a little bit then it would come back.
Old 01-01-2013, 05:53 PM   #5
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Buy-Sell-Trade Rating: (45)
Vacuum leak?
zetecDon is offline
Old 01-01-2013, 11:46 PM   #6
02blacksvt
Fan#: 105081
You think it could be a vac leak?
Well i started with nothing, and have most of it left.
Old 01-02-2013, 12:05 AM   #7
elsolo
elsolo's Avatar
Fan#: 96835
Could be, that would explain the RPM increase and poor running while that happens.
But it would need to be a large, intermittent vacuum leak.
Old 01-02-2013, 09:45 AM   #8
02blacksvt
Fan#: 105081
Would that also cause the speedo to jump like that as well?
Old 01-02-2013, 12:23 PM   #9
CaptainRyan
Fan#: 104289
What I Drive: 2007 SES focus black
FF Reputation: 1 CaptainRyan Good Standing Member
Just for clarrification the tach and spedo jumped - Did the car accelerate when this occurred? or did it just begin to run like crap? I have seen this in a 1998 honda where the main relay was going bad and intermitantly killing power to the PCM. I'd check for a loose connector at the PCM and then start checking grounds
CaptainRyan is offline
Old 01-02-2013, 01:23 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
No, it would not.
I missed that very important detail about the speedo.
(why it is important to clearly describe the problem)
I would lean towards in intermittent open circuit, loose wire, bad ground, loose relay, that kind of thing.
