Car stalling while revving. Curious?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-31-2012, 10:21 AM   #1
Urbanspacedude91
Urbanspacedude91's Avatar
Fan#: 91432
What I Drive: 2010 Blue Flame Duratec
Points 2,235, Level 28
Points: 2,235, Level: 28 Points: 2,235, Level: 28 Points: 2,235, Level: 28
Level Up 57% Completed
FF Reputation: 1 Urbanspacedude91 Good Standing Member
Whats going on FF?? So i was driving around with my friends just for a spin and i came to a stop light and ill admit i revved my vehicle . Then suddenly it stalled and everything in the dash went blank but showed a battery light. I took the key out and tried starting it again and its like nothing ever happened. So me being curious i did it again and the same thing happened. I tested the battery and alternator and both were good. I know one of the main probably only factors was me being a . But any ideas on what could of been the reason. Curious as can be.
I drive a Focus and You noticed!
Urbanspacedude91 is offline
Old 12-31-2012, 12:19 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,314, Level 77
Points: 14,314, Level: 77 Points: 14,314, Level: 77 Points: 14,314, Level: 77
Level Up 66% Completed
Forum Activity 20%
The device which adds air to keep the engine from dying when it goes to idle is not set up for the rapid RPM drop.
It needs to learn what to do.
Often the flaw in the system is die at sudden RPM drop.
It is nothing to worry about.
If you want it to stop, then keep doing it. gradually your car will figure out to stop it from happening.
On the other hand, that devise may be failing.. but more likely my first comment.
Like I said it is no big deal. really.
IAC (idle air control valve is the name of your culprit)
Elizabeth is online now
Old 12-31-2012, 02:15 PM   #3
Urbanspacedude91
Fan#: 91432
That actually makes alot of sense. I would of never thought of that. Thanks i really appreciate it.
Old 12-31-2012, 02:45 PM   #4
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
FF Reputation: 1 don627 Good Standing Member
I think that in addition to the above, I would be concerned about my charging system I know when my alternator was going bad my '03 did all kinds of weird things including stalling at random times it wasn't until the alt was completely shot and wasn't charging at all that I got a batt light. It's possible when you rev it up like that the engine is moving just enough to break a circuit somewhere in the charging system.
don627 is offline
Old 12-31-2012, 04:31 PM   #5
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Forum Activity 7%
No, the battery light came on because engine died. Normal. There'd be something wrong if it didn't.
amc49 is offline
Old 12-31-2012, 10:00 PM   #6
Dukttape
Dukttape's Avatar
Fan#: 94135
What I Drive: 2011 Sangria Red SE Sedan "Fiona"
Points 635, Level 12
Points: 635, Level: 12 Points: 635, Level: 12 Points: 635, Level: 12
Level Up 70% Completed
FF Reputation: 1 Dukttape Good Standing Member
This is kind of weird. My car just did this on my way home. Same deal, revved to like 5k in second, shifted into third pushed to 60 mph and thew the clutch and was going to cost to down to 30. Fun speed zones just outside of town. Look down at the tach and it reads 0. Turn it back on and it idled funny for a minute. But once I got it into a gear it started to work normally.
Roush performance intake, Exedy 12.5 lb flywheel, Massive 76A lower engine mount... more to come with more money.
Dukttape is offline
Old 01-01-2013, 09:45 AM   #7
don627
Fan#: 56863
Points 208, Level 4
Yes we all know the battery light comes on when the engine stops, that is not the point of my post.
don627 is offline
