Old 12-28-2012, 11:20 AM   #1
Magus2727
Magus2727's Avatar
Fan#: 62897
FF Reputation: 6 Magus2727 Good Standing Member
Wheel Bearing the same for SVT vs ZX3?
Looking at getting some wheel bearings but my ZX3 has been converted on the front brakes to the SVT. doe they use the same Bearings?
I am looking at the TIMKEN Part # 510056 is this the right part #???
Or i might just go with a whole replacement. and get the Timken part # HA590263K. Looking on their site it says 00-07 all motors so just wanted to double check.
Thanks!
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 12-28-2012, 11:45 AM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2002 ZX3
FF Reputation: 18 freemind Great Standing Member
Buy-Sell-Trade Rating: (16)
They are different knuckles. I am not sure about the bearing. Perhaps one of the other Mods can chime in here.
133whp-126ftlbsTQ Eclipse CD8443,JBL Px300.4, JBL GTO7001, PPI 356cs, JBL p1022 in .95 cubes, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 12-28-2012, 11:48 AM   #3
Magus2727
Magus2727's Avatar
Fan#: 62897
thanks, I know the knuckles are different (different caliper mounting for the larger rotors). But the bolt pattern is the same, the axles are the same, so I am guessing the bearing and hub assembly would be the same. but sometimes manufactures do weird stuff... all the sites don't discriminate/specify the motor so would assume that means it works on all Foci from 00 to 07? Thanks for the quick feedback!
Hatch Nation #42
Old 12-28-2012, 01:58 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
What I Drive: 2001 Red ZX3
FF Reputation: 82 BC_ZX3 Excellent Standing Member
Yes, same bearing. I have SVT brakes on my ZX3, too.
BC_ZX3 is offline
Old 12-28-2012, 02:03 PM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Great. Thanks. I decided to order the hub and bearing kit. Amazon has it for only $19 more get a fresh hub and comes with the axle nut also. Figured it was a good deal. Thanks for the feed back.
Hatch Nation #42
Old 12-28-2012, 03:36 PM   #6
rsnow
Fan#: 105358
What I Drive: 2002 pitch black svt
FF Reputation: 1 rsnow Good Standing Member
sometimes the only difference in bearing is the svt ususally has abs, if your zx3 has abs you will need to order such. has a magnetic ring on bearing facing abs sensor
rsnow is offline
Old 12-28-2012, 04:57 PM   #7
Magus2727
Magus2727's Avatar
Fan#: 62897
Nope the ZX3 does not have ABS, the sensor was in the knuckle but cut right after the plastic molding.
Hatch Nation #42
Old 01-02-2013, 07:43 PM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
So to follow up. I got the bearings kit.
I dont have ABS so is their a right or wrong direction to press these in? If so what direction? Red rubber seal towards wheel?
Edit: looks like the black side has the ABS in it. And can check using a small paper clip. Will double check when I get home. Even though I don't have ABS want to make sure I don't want to cut corners in the event their is a reason to install them in 1 direction vs the other.
Hatch Nation #42
