Dreaded Can't fill gas tank problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2012, 10:50 AM   #1
NitroMan
Fan#: 107269
What I Drive: 2005, Silver, ZX5
Points 91, Level 1
Points: 91, Level: 1 Points: 91, Level: 1 Points: 91, Level: 1
Level Up 82% Completed
FF Reputation: 1 NitroMan Good Standing Member
Okay, I have a 2005 zx5. Owned it since new.
All of the sudden it takes 30 minutes to fill up because of fuel splash back on the pump nozzle turning pump off.
I have read many posts on the problem, but really don't see where anyone has found a solution.
1) Spider nests in vent tube.
- I have removed both the vent tube. No clogs
2) Some type of clog in fill tube.
- I have pulled the fill tube. First I tried running a siphon hose through. Hose would not go through, so I thought this might be the problem. After pulling the tube have declared it clear.
3) Pulled gas tank to check tank venting.
- Tube is clear to the charcoal/EVAP canister.
- Exit tube from EVAP Canister clear to Fuel Vent, up to Fuel Fill.
Apears the The Charcoal Canister/EVAP is the problem.
So, here's where I need help. The Charcoal Canister/EVAP is wedged above and between the rear end and the bottom of the vehicle body. How is this thing suppose to come out?
After looking at it for a few nights, I am thinking I will cut a huge hole in the floor panel by the spare tire and pull it out the top. Otherwise I think I need to drop the rear end - at least one side.
Anyone ever replace the Charcoal Canister/EVAP that can help me out here. Anyone have the Ford Service manual that can shoot me the directions for Removal/replacement?
Thanks, any advice appreciated.
NitroMan is offline
Old 12-14-2012, 11:33 AM   #2
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Points 11,527, Level 70
Level Up 70% Completed
Buy-Sell-Trade Rating: (48)
to FF
Is this what you are looking for:
http://www.focusfanatics.com/forum/showthread.php?t=276213
I hope this helps!
Hatch Nation #8
katiekay is offline
Old 12-14-2012, 12:10 PM   #3
NitroMan
Fan#: 107269
Points 91, Level 1
That is a sweet write-up for the Fuel sending unit. Thanks.
I already have the fuel tank out though. Since I may be cutting holes, maybe I should do that one too, in addition....
I'm thinking of doing the same thing for the EVAP/Charcoal Canister. Cut the floor panel.
I was hoping not to do that if there was an easy way to drop the rear end or get the damn canister out.
NitroMan is offline
Old 12-14-2012, 12:50 PM   #4
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Sorry it wasn't what you were looking for. But since this works great for the fuel filter, it might just be a good idea to cut a hole where you need it too
Sent from my iPhone using FF Mobile
Hatch Nation #8
katiekay is offline
Old 12-25-2012, 01:29 PM   #5
NitroMan
Fan#: 107269
Points 91, Level 1
Okay, after searching for several days I found that the rear end is called a rear sub frame. There are 5 bolts on each side that hold the rear sub frame in. I basically put the whole car on jack stands with about 30 inches of clearance. With wheels removed put a hydraulic jack under each rear spring. loosened the 5 bolts on each side and lowered the rear sub frame. I was then able to remove the charcoal canister assembly. As previously diagnosed, the charcoal canister was plugged up.
Recommendation: The EVAP lines have special clips on them and I have not been able to find replacement clips. So use great care in removing the lines and do not break the clips.
After reinstalling everything, I can now pump gas into the vehicle with no issues. Problem solved. Hope this helps others with a similar problem.
NitroMan is offline
