How To: Proper EGR Delete *now with 20% more How* - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-23-2012, 06:28 PM   #61
joesperformance
joesperformance's Avatar
Fan#: 92411
What I Drive: 01 Focus SE Sedan, Zetec
FF Reputation: 3 joesperformance Good Standing Member
Originally Posted by Magus2727 View Post
^^^ picture of the actual plug?
I just went out and unscrewed it out of my header and took a pic of it for ya.... took me literally 1 min to do.... uses a standard 3/8" ratchet or extension to screw it in and out.... so no specialty socket needed
NO LEAKS AND NO THREAD TAPE OR ANYTHING ON THREADS...
PIC OF IT INSTALLED IN MY HEADER,
look at header, its the only shiny silver thing on right side on header
http://www.firebirdnation.com/forums/uploads/1341751582/gallery_13330_2406_139330.png
Sedan Revolution #232
joesperformance is offline
Old 01-26-2013, 10:56 PM   #62
jdamitio88
Fan#: 109112
What I Drive: 2001 red zx3 S2
FF Reputation: 1 jdamitio88 Good Standing Member
Hey how did you go about getting a tune done? Did you find someone or did you do it yourself? I'm trying to figure out that process because my lower hose on my EGR is cracked and sucks air (kinda sounds like a turbo) so i planned on just taking off the EGR all together. My only issue is that i need to find a way to shut off the diagnostic check for the EGR to shut off the CEL so i can pass washington emissions. Any help or suggestions would be appreciated.
jdamitio88 is offline
Old 01-27-2013, 08:59 PM   #63
joesperformance
Fan#: 92411
the vacuum line that comes from the firewall to the EGR Valve itself, u can move it to the square box, that has the 2 tubes that come off it onto the EGR Tube (runs from EGR Valve to Exhaust Manifold), just move vacuum line from EGR Valve to that sensor, to the test port, and it'll keep the Engine light from coming on.....
Old 01-28-2013, 05:57 PM   #64
jdamitio88
Fan#: 109112
hey thanks, i appreciate the feedback. I'm going to try it this weekend and see if it works. Also what kind of intake do you have? I need a CAI to free up space in the engine bay.
Old 04-25-2013, 05:10 PM   #65
Whitebread
Fan#: 113941
What I Drive: 2002 White ZX5
FF Reputation: 1 Whitebread Good Standing Member
Bringing this back.
I've searched everywhere.
Has anyone found a diy fix for the code? Such as wiring in a resistor,etc?
What exactly triggers the code electronically? Is this a measurable occurrence?
Coming from the mistubishi would it was a $0.20 fix
http://www.3si.org/forum/f1/resistor...h-pics-382054/
Whitebread is offline
Old 04-25-2013, 05:14 PM   #66
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,393, Level 61
Points: 8,393, Level: 61 Points: 8,393, Level: 61 Points: 8,393, Level: 61
Level Up 81% Completed
Forum Activity 30%
The EGR is a vacuum based measurement on the focus that takes measurements before and after an orifice/restrictor. it is not temperature based. It measures the delta between the two to determine if there is sufficient flow. Not saying a resistor can not "fix it" but over the years I have been on the forum and working on my Focus the only way to fix it is through a tune.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 04-25-2013, 05:22 PM   #67
Whitebread
Fan#: 113941
Well thanks for the info. I was hoping this was something i could take care of myself. I enjoy little diy projects like that.
Far as i know the resistor mod was for temp based egr's.
Back to the drawing board i guess.
Old 04-25-2013, 05:41 PM   #68
Whitebread
Fan#: 113941
Before i spend too much more time looking for a diy, are there are vendors that offer a cel code out service separate from a full tuner?
I just dont feel my mod list warrants a tune just yet.
Old 04-25-2013, 07:12 PM   #69
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
it requires a full tune to "turn off" the cell. it tells the computer to not report or not to look at that value. if you get that far into the ECU then you can do everything else. And to do it requires a SCT tuner that then gets locked to that ECU code. that is the expensive bit is buying a tuner that they get locked to that specific vehicle and costs $100 to "unlock"
Hatch Nation #42
Old 04-25-2013, 07:54 PM   #70
Whitebread
Fan#: 113941
Well that makes sense. $100+ to code it out probably wouldn't fly.
