2012 HID Thread (Info Only No Arguing) - Page 33 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-23-2012, 01:28 AM   #321
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,075, Level 45
Points: 5,075, Level: 45 Points: 5,075, Level: 45 Points: 5,075, Level: 45
Level Up 63% Completed
FF Reputation: 4 Ox-y-GenIII Good Standing Member
Ok, I'm going to post pictures of what I have right now. Can someone guide me as to where to plug everything in and such? I have installed other kits on older vehicles that didn't need a harness (just plug and play), this is a little confusing.
Just for reference the engine bay - old pic but still helpful
The resistor (yes just one is what I have for now, I ordered this a few months ago)-
The wiring harness
Also where do I connect the ballasts themselves? to the headlight power supply or later in the chain? Thanks ahead of time, if I can get a good description I will try to install these again tomorrow. I don't work til Wednesday so I'd like to try.
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 12-23-2012, 10:16 AM   #322
Bwill9886
Bwill9886's Avatar
Fan#: 93444
Don't know if you have checked out my youtube video or some of the pictures Fraychild put up (both are a few pages back), but you might find some of that useful. You have also seen the retro-solutions diagram, yes?
To answer your last question, the ballasts will get their power from the relay harness. There should be two male connections (and one should be quite long, as it will connect to the passenger side) for each ballast.
Bwill9886 is offline
Old 12-23-2012, 10:14 PM   #323
Ox-y-GenIII
Fan#: 90008
Good luck that I have, I lost my T30 bit. Gotta go buy another. Lame.
Ox-y-GenIII
Old 12-24-2012, 07:21 AM   #324
Bwill9886
Bwill9886's Avatar
Fan#: 93444
If you are wanting it to remove the headlights, just use a bigger standard screwdriver.
Old 12-26-2012, 03:36 AM   #325
Darketernal3
Darketernal3's Avatar
Fan#: 98631
What I Drive: 2012 Ford Focus SE Sedan
Points 484, Level 9
Points: 484, Level: 9 Points: 484, Level: 9 Points: 484, Level: 9
Level Up 68% Completed
FF Reputation: 1 Darketernal3 Good Standing Member
Agreed...
The wiring harness
But here... something just for you, using your diagram reference Ox-y-GenIII
Ok.. from your pictures and label... I'll see if I can peice it together for you... It helps to assemble them ahead of time to get an idea.
Now.. Unfortunately I took them out of my car, but you wouldn't be able to see it anyways... I had them tucked under, but I will lay it out for you.
Facing your car with the hood open, remove your headlight assembly, Use a large flat head; should work fine. You will either need to make a hole in your rubber cap, or find a way around it because there'll be a lot of wires going in and out.
OK, so you don't have 2 Resistors, so this will give you a Bulb dip error, but will still work. Instead of connecting it to a resistor harness, you will simply let it hang free inside the headlight assembly. But will need to know the process since it's going to be repeated on the driver side, also as a reference to anyone else who has 2 resistors and would like to try it.
So, whenever I refer to (A) or (B) on the passenger side, just think of it as the old halogen lamp connector.
Remove the bulb and replace it with your HID bulb.
Feed both Resistor wire (A) and the HID double wire through the hole in the rubber cap, and connect (A) to the old halogen wire and the HID to the bulb and replace the rubber cap over the opening. (For you, you will just be running the HID connectors from your Ballast through the cap on this side.)
Ground the end (C) on to the chassis or somewhere in the engine compartment, I undid one of the bolts holding the fender and looped it and tightened it down there. Let end (B) hang loose on this side, DO NOT CONNECT IT. (For you, you will have the old halogen wire remain inside the assembly unattached.)
OK... now the tricky part, hopefully I can explain it all.
Remove the driver side headlamp assembly and repeat the above process. HOWEVER, you will need to connect resistor connection (B) to the relay harness at (G).
Ground the Relay and Resistor on the same place on one of the bolts securing the fender well.
Connect relay (D) to the passenger side ballast and (J) to driver side ballast.
Ground connector (E) to the bolt used for the resistor on passenger side, if you decide to get one.
Ground connector (I) to the bolt used for the resistor and relay on the driver side.
Finally, connect (H) to your (+) lead on your battery.
Relay box (F) mount does nothing... might be additional grounding, or just a mounting hole.
PS. Be absolutely sure you keep track of your ground wires.
PSS. you might want to mount those resistors onto the chassis, they get extremely hot, I just taped them over the wheel well by their wires and let them dangle... seemed to work OK
Silver Ingot
203A Package
SE Sports Package
Two toned sports interior Stone/Black
Darketernal3 is offline
Old 01-05-2013, 12:50 AM   #326
calvin.lehman
calvin.lehman's Avatar
Fan#: 107838
What I Drive: 2012 Sonic Blue SE sedan
FF Reputation: 1 calvin.lehman Good Standing Member
Do I absolutely have to have the resistors?
calvin.lehman is offline
Old 01-05-2013, 08:12 AM   #327
BaconZombie
BaconZombie's Avatar
Fan#: 98205
What I Drive: 2013 VW GTi, United Grey
Points 813, Level 15
Points: 813, Level: 15 Points: 813, Level: 15 Points: 813, Level: 15
Level Up 13% Completed
FF Reputation: 3 BaconZombie Good Standing Member
Only is you don't want a bulb out warning.
BaconZombie is offline
Old 01-05-2013, 08:16 AM   #328
Fraychild
Fraychild's Avatar
Fan#: 37309
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 2 Fraychild Good Standing Member
Fml
Possibly for the 100th time in this thread...
YES!!! AS MENTIONED IN THE VERY FIRST POST....
YOU HAVE TO GET TWO RESISTORS AND A RELAY HARNESS IN ORDER FOR ANY HID/XENON KIT (35W or 55W) TO PROPERLY WORK IN THE MK3 FOCUS WITHOUT THE BULB OUT/DIPPED BEAM ERROR MESSAGE!
2012 Candy Red SE Manual... I smell serious trouble.
Fraychild is offline
Old 01-05-2013, 11:08 AM   #329
Bwill9886
Bwill9886's Avatar
Fan#: 93444
Pft, you actually expected someone to read through the thread? Even the last several pages were you can find an answer to just about anything related to installing HID's?
Reading is hard!!!
Old 01-05-2013, 11:38 AM   #330
calvin.lehman
Fan#: 107838
You know you guys are kind of jerks I did read the entire thread. and with all the replies from some stupid people confused me. this stuff is somewhat confusing to someone that is a little slow at grasping all these tasks.
