SVT is idling better with no MAF hooked up??? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-21-2012, 10:24 PM   #11
sweetnlo
Fan#: 105730
What I Drive: 2003 Svt Swap
FF Reputation: 1 sweetnlo Good Standing Member
Ok so today i got my svt mass air flow sensor delivered! I plugged it in,... and it still idles like sh** and stalls out. I plugged in into the snap-on scan tool and my o2 sensor 1 bank 1 was bad. I ordered a new one and put it in and it still idles like sh** and then stall out. I can smell that it is running really rich. I guess my next option would be to replace the IAT sensor. I hope its not expensive..
sweetnlo is offline
Old 12-21-2012, 11:52 PM   #12
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,488, Level 100
Points: 138,488, Level: 100 Points: 138,488, Level: 100 Points: 138,488, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (11)
The IAT is built into the MAF. Maybe check the TPS sensor?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 12-22-2012, 12:05 AM   #13
Points 27,762, Level 98
Points: 27,762, Level: 98 Points: 27,762, Level: 98 Points: 27,762, Level: 98
Level Up 42% Completed
There's something else you're missing. Do you hear any loud hissing when the engine is idling? Do you have any way to data log? That's what 1TurboFocus needs to be able to help you diagnose this issue.
It's nagging the hell out of me because I've seen this before, but I can't remember what it was. Sorry Paul, I don't think it's the TPS. If it was, it would be drivable with or without the MAF unplugged.
Old 12-22-2012, 12:13 AM   #14
sweetnlo
Fan#: 105730
Im goin to check for vacuum leaks again. I feel like i have a vacuum hose crossed or something. I DO HEAR HISSING when i start up my car for a little while till the engine calms down. Do you happen to have pictures of vacuum lines/hoses? That would help me eliminate an easy fix. Also my car backfires alot when shifting.
sweetnlo is offline
Old 12-22-2012, 12:15 AM   #15
sweetnlo
Fan#: 105730
no i dont have a way of data logging and im unfamiliar with what that even is.. Ive read alot about getting the svt tuned. Any info on this?
sweetnlo is offline
Old 12-22-2012, 02:48 AM   #16
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 57%
Yea I don't think it was, I'll be honest was just making a quick suggestion.
Moderator for
Technical Chat
Old 12-22-2012, 12:02 PM   #17
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
He has a rich or lean condition and by unplugging the MAF it goes into the failed MAF tables
Wish I could help more but cannot do much with out a datalog
Before this have you changed ANYTHING even anything small ?
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 12-22-2012, 12:23 PM   #18
Well with an SVT manifold you have lots of places where you can have vacuum leaks. There is a vacuum line diagram under the hood on the VECI (vehicle emissions control information) sticker. Most vacuum will come off of the throttle body, but a few come directly off of the intake manifold- like the PCV and brake booster. A rusty brake booster will cause a very annoying vacuum leak coupled with weak/hard brakes. A bad check valve- the 90 degree connector where the hose goes to the booster- will do the same thing.
Trace down each vacuum line using the VECI diagram to help you locate them. You should have about 5. The longest one will be the one that goes to the EVAP system. It should connect to the TB, then go to the purge valve, and from there to the carbon canister. That one won't be it unless it's not hooked up at all- or the purge valve is stuck open. I'd give a stuck purge valve a 10% likelihood. It's really uncommon. The most common issue is the PCV line, but I'm not sure where it connects on an SVT manifold- if there is one at all. Check your VECI, and then look for what is on there.
1Turbofocus is right, the MAF is not your problem, what's happening with the MAF is a result of another problem. Stop throwing parts at the car, and work from the cheapest fix up, or diagnose it properly. We can help you with diagnostics- one of which is listening for the hissing sound indicating a vacuum leak. The best way to figure that one out is to simply remove each line, inspect visually for dry rotting or damage, replace if needed, and re-install. I have stopped recommending starting fluid or WD40 sprayed around the inside of the engine compartment to help find vacuum leaks because of the dangers involved- and it's a subtle change in rpm that most people will miss. In the end you just have a lot of flammables in a confined space without much new information.
Old 12-22-2012, 04:20 PM   #19
sweetnlo
Fan#: 105730
Tom
i am running reaally rich, just had to replace my o2 sensor again. what do i need to do to data log? i dont know what that is
sweetnlo is offline
Old 12-22-2012, 04:23 PM   #20
sweetnlo
Fan#: 105730
i only hear the hissing sound when i start up the car and then it stops.. Also, i dont have the o.e. hood from an svt and im having a hard time figuring out the lines. i need to find the pcv line..
sweetnlo is offline
