#11 | ||||
#12 | ||||
No TCE has nothing to do with this OEM style upgrade. The brackets and rotors are OEM parts for a different car that I believe will adapt to the spindles with minor or no modifications. The stock caliper and the caliper the new brackets were originally from use the same pads, so the stock caliper MAY bolt right to this new bracket. That's what I'm going to try determine.
IF the new bracket bolts to the stock caliper AND fits over the new 300mm rotor (which they should, given the respective measurements of both rotors and calipers), then I'll determine what final thing to do to get it to fit/function as if the factory did it. IF this doesn't work then I will look at installing the Wilwoods onto the 300mm rotor using my own bracket design. I've been selling brake kits for 15 years so this isn't that difficult. I'm trying to fit this all under the 16" factory wheel (the OEM caliper will easily fit, the Wilwood don't know till I try it). |
#13 | ||||
I've been curious to know if any of the Volvo 5x108 cars with larger brakes could be an upgrade path for us. Any chance you're looking at any of the Volvo stuff for this deal?
Just curious. Sent from my SCH-I905 using FF Mobile |
#14 | ||||
Yes it is some Volvo parts I'm looking at. There are some minor differences that need to be addressed, and I will know next week if it's possible to adapt them.
#15 | ||||
Ok first try didn't work the brackets were for a different pad. Next up some Mazda calipers. Oh and I test fitted some Wilwood Dynalites onto both the stock rotor and the 300mm rotors. Easy 4 piston upgrade, you just need wheels to clear them, stock 2013 SE 16's will NOT clear.
#16 | ||||
anyone here find info on getting ST front brakes and rotors on our cars?
I searched but did not find anything... |
#17 | ||||
Hit up Todd at TCE, he has 2 different size brake kits.
