CWCZX3's Built Motor Project - Page 30 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-16-2012, 09:20 PM   #291
cwczx3
cwczx3's Avatar
Fan#: 852
What I Drive: 2000 Autumn orange ZX3
Points 15,417, Level 80
Points: 15,417, Level: 80 Points: 15,417, Level: 80 Points: 15,417, Level: 80
Level Up 14% Completed
FF Reputation: 5 cwczx3 Good Standing Member
Got the Eboost2 installed and wired up. this is how i have the vac lines to the solenoid hooked up.
Port 1 vents to atmosphere
Port 2 goes to the bottom port of the WG
Port 3 goes to a boost pressure source which is my vac manifold block. This is also where i get my signal to the controller itself.
I set everything to zero which should get me gate pressure which was @12 psi on the old setup with xs manual boost controller all the way closed. I hit @16 psi while out testing it so i'm not sure what's going on. Next i will run it with no controller installed to see what my actual gate pressure is.
So anyone else out there using the Eboost2 have any input?
2000 Autumn Orange ZX3 "Beauty"Weekend Toy
2013 Performance Blue STDaily
2001 Flat Black ZX3 "River Rat"SOLD
cwczx3 is offline
Old 12-17-2012, 08:26 AM   #292
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
Points 50,851, Level 100
Points: 50,851, Level: 100 Points: 50,851, Level: 100 Points: 50,851, Level: 100
Buy-Sell-Trade Rating: (11)
At least you aren't using the profec b spec two
FF MODERATOR
RIFF CREW
ZXthrizzle05 is offline
Old 12-17-2012, 12:01 PM   #293
Eastwood
Eastwood's Avatar
Fan#: 62095
What I Drive: 2001 zetec premium zx3
Points 4,797, Level 44
Points: 4,797, Level: 44 Points: 4,797, Level: 44 Points: 4,797, Level: 44
Level Up 24% Completed
FF Reputation: 1 Eastwood Good Standing Member
Buy-Sell-Trade Rating: (20)
Originally Posted by zxthrizzle05 View Post
at least you aren't using the profec b spec two
lol lol
Eastwood is offline
Old 12-17-2012, 12:14 PM   #294
ZXthrizzle05
TURBO ZX3
Fan#: 24434
You already know
FF MODERATOR
RIFF CREW
Old 12-18-2012, 02:20 PM   #295
Black00ZX3
Fan#: 104714
FF Reputation: 3 Black00ZX3 Good Standing Member
Amazing build
Black00ZX3 is offline
Old 12-19-2012, 07:27 PM   #296
cwczx3
cwczx3's Avatar
Fan#: 852
looks like im ok with install of the eboost2. i ran a line straight to the wastegate bypassing the solenoid and i get 16psi. looks like the turboxs was only letting me hit 12psi with it all the way shut. not sure why though. i tested the wastegate and the line that goes to it with my mightyvac tester and it's not leaking so the diaphram in the wasteggate is good. so i set the gate pressure to 12psi and the eboost2 is working like it should. so back to tuning.
cwczx3 is offline
Old 12-19-2012, 07:27 PM   #297
cwczx3
cwczx3's Avatar
Fan#: 852
Originally Posted by old1030 View Post
Amazing build
Thanks
cwczx3 is offline
Old 12-20-2012, 03:48 AM   #298
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
Buy-Sell-Trade Rating: (13)
Hey Corey, I had my E-Boost hooked up like you did once. There are a few different ways to run the vacuum hoses. IIRC hooking up the port # 3 to a boost only connection got me the most adjustability. Here is a link to a pic of mine. Port #3 runs to the charge pipe in the rubber reducer , just above the positive battery post. The controller is on the fire wall next to the master cyl.
Also check out Turbo Smarts web site. It shows you all the different ways to hook it up.
Here is the link to Their instructions and downloads. Scroll down to boost controllers electronic-- either of the ones that say complete guide.
http://www.turbosmartusa.com/instructions-downloads
iroc34 is offline
Old 12-20-2012, 03:01 PM   #299
cwczx3
cwczx3's Avatar
Fan#: 852
Yeah i have the manual printed out. But i think i got it all figured out now.
cwczx3 is offline
Old 01-18-2013, 08:04 PM   #300
cwczx3
cwczx3's Avatar
Fan#: 852
Problem ended up being the wastegate is now too small and doesn't flow enough, time to upgrade to a larger 45mm unit.
cwczx3 is offline
