Throttle body stop screw - Adjustable? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-16-2012, 01:02 PM   #1
exsodius
Fan#: 14827
What I Drive: 2002 Silver 1.6 Wagon
Points 7,116, Level 55
Points: 7,116, Level: 55 Points: 7,116, Level: 55 Points: 7,116, Level: 55
Level Up 83% Completed
FF Reputation: 1 exsodius Good Standing Member
My focus 1.6 petrol sticks on the lowest gas pedal position. I know its the butterfly sticking. Throttle stop screw is worn a little. So i put 3 layers of electrical tape together and laid it between the stop screw and the stop plate. And that was enough to fix the problem. But this tape will get worn so i have to fix it more permanently.
Does anybody know if the stop screw can be turned? When i feel the backside of the screw i fell that the screw has a round head without the possibility to put a screwdriver into it.
Ford Focus 1.6 Wagon
exsodius is offline
Old 12-16-2012, 01:07 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,253, Level 77
Points: 14,253, Level: 77 Points: 14,253, Level: 77 Points: 14,253, Level: 77
Level Up 51% Completed
Forum Activity 20%
Use metal tape. Like (real) duct tape. It is aluminum metal with a sticky backing.
It will last much longer.
I had used it on my Contour SVT throttle stop for the same reason.
Elizabeth is offline
Old 12-16-2012, 07:39 PM   #3
exsodius
Fan#: 14827
Thank you!
I will try that, i know i have this aluminium tape somewhere in my home. I got it with a dishwasher mashine to tape above the front opening to avoid moisture to the kitchen table. The tape was the same width as ducted tape.
So in this answer from you i assume you found out that you could not adjust the trottle screw?
exsodius is offline
Old 12-16-2012, 07:47 PM   #4
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
The US model is adjustable with an allen wrench. It's hard to see it, but it's an allen head screw.
TerryB is offline
Old 12-16-2012, 08:06 PM   #5
exsodius
Fan#: 14827
Thanks
No i cant see it but i feel it is round like a half lemmon, maybe the hole for allen wrench is filled with epoxy because it should not be tampered with.
exsodius is offline
Old 12-16-2012, 08:16 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
FF Reputation: 49 iminhell Great Standing Member
Loosen the 2 screws holding the throttle plate in place. Force the throttle open then closed, push it closed a little while tightening the screws.
Should help.
iminhell is offline
Old 12-16-2012, 08:18 PM   #7
TerryB
TerryB's Avatar
Fan#: 34559
The first time I looked at mine, I used a mirror to see it. As I mentioned above, that's US model. I don't see why yours would not be the same.
TerryB is offline
Old 12-16-2012, 11:32 PM   #8
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
Points 2,072, Level 27
Points: 2,072, Level: 27 Points: 2,072, Level: 27 Points: 2,072, Level: 27
Level Up 48% Completed
Forum Activity 8%
Buy-Sell-Trade Rating: (13)
I drilled/knocked out the epoxy on one I was trying to fix, and there was an allen screw inside. I used my Scangauge to set the idle TPS percentage to factory specs. I would try what 'iminhell' suggested first it works too, especially if you don't have any way to look at the TPS readings.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is offline
