Old 12-15-2012, 02:16 PM   #1
PowerFocer
PowerFocer's Avatar
Fan#: 61706
What I Drive: 2010 Sedan SE
FF Reputation: 2 PowerFocer Good Standing Member
Looking to do battery relocation.
I'm looking at doing a battery relocation similar to this http://www.iwsti.com/forums/how-inst...ine-trunk.html
The only real differences is that I would be running a sealed box and have harness protector running along the entire length as sealed up as I could get it. Anyone have experience and good/bad reviews on this? Looking for a bit better weight balance.
Originally Posted by WeeAsp View Post
Rule of thumb:
NEVER trust anyone with your car or your girl.
Either way, you could get a rod thrown in both.........
Fast cars make smart people do dumb things
PowerFocer is offline
Old 12-15-2012, 05:34 PM   #2
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Lots of wrench time, no respect
FF Reputation: 14 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (7)
I've looked into this and it's not a difficult mod. The only issue with doing this on the 08+ is the ECU location. The ECU uses the stock battery box as a mounting point. If you move the battery then the ECU is kinda hanging out under the engine bay.
You would need to make some kind of custom mount for the ECU.
SES #009
FR '11 FF Moderators pick
Oct '11 ROTM
FR '12 Carlisle Nifty Fifty Award/Best in Boost/Best 08-11/Finest Five Pick
PSUrivie is offline
Old 12-16-2012, 01:55 AM   #3
PowerFocer
PowerFocer's Avatar
Fan#: 61706
Shouldn't be difficult, but thanks I didn't even think of that.
Rule of thumb:
Old 12-16-2012, 02:03 PM   #4
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
Add a Braille battery if you looking for weight reduction. They start at 6lbs. T.R. has 10 difference versions of them. Plus also the weight of the battery cable too.
felixthecat is offline
Old 01-03-2013, 10:06 PM   #5
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
FF Reputation: 200 warneej Excellent Standing Memberwarneej Excellent Standing Memberwarneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Mine is in the hatch in my ZX3. Used high quality 4ga amplifier wiring to connect it with a 150 amp circuit breaker mounted at the positive terminal.
Looking for 17x8 wheels to race on! PM me if you have something!
173.4whp
gump
crew #6
warneej is online now
Old 01-04-2013, 12:19 PM   #6
elsolo
elsolo's Avatar
Fan#: 96835
FF Reputation: 9 elsolo Good Standing Member
You have a 150 amp breaker inline to your battery terminal?
Cranking amperage can be five times that high.
I put the battery in the trunk on my Chevelle 20 yrs ago.
2/0 copper cable
I added a ford starter relay in the trunk so the battery cable is not an unfused constant hot cable. The cable only goes hot when cranking, the rest of the car is supplied off a 10ga wire that has a fuseable link.
elsolo is offline
Old 01-04-2013, 07:49 PM   #7
warneej
warneej's Avatar
Fan#: 20372
2/0 copper cable
Negative. Have a starting test done on your vehicle, most car starters pull in the 100-140 amp range. If the testers sees even over 200 amp it will ask if the vehicle is a diesel and when you select "No" it will inform you that your starter is shorted and bad.
173.4whp
gump
crew #6
Old 01-05-2013, 10:10 AM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Normal current draw on a BBC starer is 400 at first, then drops down to about 250 amps.
This is the specs on the (factory chevy hi-torque) starter in my car with a trunk mounted battery:
starter type pg260
model delco
rated power 104kw
rated voltage 12.00v
free run speed 3006rpm
free run current 50 amp
max of power 1.89kw
max of torque 23.36nm
max of current 606 amp
ripple 4 amp
direction cw
hold current 10 amp
pull current 38 amp
voltage drop .3586 v
elsolo is offline
