Head unit not getting power. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2012, 11:33 PM   #1
TheDude
Fan#: 107335
What I Drive: 2002, black zx3
FF Reputation: 1 TheDude Good Standing Member
I have a 02 zx3 just replaced the head unit with an after market one and it didn't have power so I checked both fuses rechecked the wiring still nothing so I tested the red power wire it didn't seam to have anything so I ran a toggle switch straight from the battery to the red connector wire and I still can't get my unit to power on. Any suggestions? And yes I removed the screws you are supposed to for it to work on a new head unit.
TheDude is offline
Old 12-15-2012, 07:44 AM   #2
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,474, Level 100
Points: 57,474, Level: 100 Points: 57,474, Level: 100 Points: 57,474, Level: 100
Forum Activity 17%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
There are three fuses that you should check. The one for the Acc wire, the fuse for constant power, and the fuse in the back of the headunit itself. Check all of them one more time.
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is online now
Old 12-15-2012, 09:24 AM   #3
TheDude
Fan#: 107335
I check the 3 fuses the 2 10 amp fuses in the fuse box and the 7.5 amp on the back end of the head unit itself. All three are good I going to try running the toggle switch to the constant rather then the ignition switch power wire to see if that makes a difference.
TheDude is offline
Old 12-15-2012, 09:30 AM   #4
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 17%
How about the ground wire? I should have ask this right off but make sure your unit is getting a good ground or it won't power up.
Old 12-15-2012, 10:42 AM   #5
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
was your factory headunit the Blaupunkt one? with the VW plug behind it?
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Kipp is offline
Old 12-15-2012, 01:53 PM   #6
TheDude
Fan#: 107335
Yes for the antenna wire but I figured it out. I ran the toggle to both the red and yellow power wires and it turned on. Thank you for the help.
TheDude is offline
