Blown off oil filler cap - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-11-2012, 10:28 PM   #1
Artex
Fan#: 107214
What I Drive: 2012 Black SE
FF Reputation: 1 Artex Good Standing Member
Long time lurker- first time poster...
Posted thus in the "technical" section but got no bites.
Here's the rundown; got the first oil change @ 3000 miles. I'm at around 8800 now. Was driving to work this afternoon (about 30 miles one way) and started to notice a weird smell in the cabin. Long story short: got to work, opened the hood, oil filler cap sitting on top of the engine - oil everywhere. Checked the level, looks about at the halfway mark. What should I do now? I didn't even open the hood since the last oil change ( I know, I know... I drive a truck for a living so I know a little about maintenance, etc. just didn't see a reason for it on a brand new car that was running fine). Called the dealership... The guy at the service desk didn't even seem interested to talk to me- told me to "bring it in".
What should I expect/ ask for? Evidently it was not my fault. Even if I was to check the oil level I would use the dipstick and not fiddle with the filler cap.
What would be a "procedure" for a remedy to my issue?
Thank you in advance
Artex is offline
Old 12-12-2012, 06:00 AM   #2
SonicZXIII
SonicZXIII's Avatar
Fan#: 90927
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 1 SonicZXIII Good Standing Member
Sounds like they put it on but might have left it loose
FO-FO FO SURE
Rolling in a 2005 ZX3 Roush SVT combo
"When a man opens a car door for his wife, it's either a new car or a new GF.
SonicZXIII is offline
Old 12-12-2012, 08:46 AM   #3
c5karl
Fan#: 105687
What I Drive: 2013 Hatchback SE, 5-speed, silver
Points 67, Level 1
Points: 67, Level: 1 Points: 67, Level: 1 Points: 67, Level: 1
Level Up 34% Completed
FF Reputation: 1 c5karl Good Standing Member
Would there really be enough crankcase pressure to blow the filler cap off? I'd be surprised.
A more likely explanation: The person who filled the oil never put the cap back on. He (or possibly she) left the cap resting right where you found it. It's an easy thing to forget.
You have every right to ask that the engine compartment be restored to its previously clean state, even if that means replacing the insulation under the hood.
c5karl is offline
Old 12-12-2012, 08:49 AM   #4
Rogerschro
Rogerschro's Avatar
Fan#: 90661
What I Drive: '12 FFE Frosted Glass
Points 902, Level 16
Points: 902, Level: 16 Points: 902, Level: 16 Points: 902, Level: 16
Level Up 2% Completed
FF Reputation: 3 Rogerschro Good Standing Member
A couple of questions, by 'oil everywhere' do you mean a lot or a light coating? Is the oil being blown out while the car is running? The fact that it is down 1/2 is worrying. There shouldn't have been that much loss from a cap being off. Either there is a LOT of oil splash off from the cams out the filler or there is pressure build up in the crankcase, which is bad news. You need to have that checked! I don't know for this engine but usually there is a baffle to prevent oil from splashing out if the cap is off but would allow for some oil vapor to coat the engine, but 1/2 of it being down is to me very excessive. You have the service record so you should be covered for who's responsibility it is. Good luck and let us know how it goes.
Rogerschro is offline
Old 12-12-2012, 08:55 AM   #5
PoonRacing
PoonRacing's Avatar
Fan#: 106556
What I Drive: 2013 Performance Blue ST-3
Points 776, Level 14
Points: 776, Level: 14 Points: 776, Level: 14 Points: 776, Level: 14
Level Up 76% Completed
FF Reputation: 1 PoonRacing Good Standing Member
I will probably get some oil and fill it back up seen halfway mark on dip stick only about half quart low, and being running with the oil filler cap off it's not going to hurt the engine.
2013 Focus ST-3
2005 Mini Cooper S JCW
1995 Twin Turbo 402 Mustang (under construction)
1986 Buick Grand National
1991 Escort GT(Daily), 1986 Merkur xr4ti(Summer Daily), 1980 Fiesta(auto-x special)
PoonRacing is offline
Old 12-12-2012, 09:45 AM   #6
dan50
Fan#: 91789
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
The caps screw on pretty tight, so it really has to be a case of the oil change tech not putting the cap on properly. The dealer should clean up the engine bay, but I would also request a fresh oil change: the engine compartment is not a particularly sanitary place and there is surely dust, dirt, grit and the like passing through, some of which could have entered the engine through the oil filler. Granted, the bigger bits should have been captured by the oil filter but the smaller stuff could still be circulating.
dan50 is offline
Old 12-12-2012, 12:27 PM   #7
Artex
Fan#: 107214
Quick update:
I'm sitting at the dealership at the moment. They took a look under the hood, are going to clean up the engine compartment and give me the Works oil change. No arguments or problems. Evident fault from their side for not having the filler cap tightened.
I wasn't looking for freebies- just wanted them to make it right. Happy with the outcome.
I will request to have this "incident" notated in the service history for future reference- as someone here has suggested.
Thanks for the replies folks. Regards.
Artex is offline
Old 12-12-2012, 07:32 PM   #8
lookin4trouble
Fan#: 101921
What I Drive: 2012 Tuxedo Black Ti Hatch
FF Reputation: 2 lookin4trouble Good Standing Member
I had this same thing happen to me. Except the dealer never put the cap back on in the first place. I had the hood liner replaced and the cabin air filters. It stunk in the cabin prior to having these replaced.
lookin4trouble is offline
Old 12-12-2012, 08:15 PM   #9
Artex
Fan#: 107214
I think I'm going to pay them a visit again. Did they just wipe the engine bay or steam clean it in your case? They didn't even mention anything about the cabin air filters; then again it doesn't smell in there anymore. I did try to have em put something about this incident on the receipt but he claimed that he already "closed that ticket". It doesnt seem like they steam cleaned my engine- just wiped it off half a**ed. Did they write something on your ticket?
Artex is offline
Old 12-12-2012, 08:40 PM   #10
Kabigon
Fan#: 88299
Points 4,428, Level 42
Points: 4,428, Level: 42 Points: 4,428, Level: 42 Points: 4,428, Level: 42
Level Up 39% Completed
Forum Activity 16%
How is "down 1/2" worrying or excessive when it is not clearly defined?
In any case, how could you possibly know that half of the oil is gone without adding more oil?
Kabigon is offline
