Starting issues???? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-12-2012, 06:54 PM   #1
Mystic544
Mystic544's Avatar
Fan#: 17917
What I Drive: 2003 Pitch Black SVT
FF Reputation: 1 Mystic544 Good Standing Member
Question Starting issues????
2003 SVT Focus
77xxx miles, new battery last month, new fuel filter maybe 6K miles ago...
So - the last couple of months the Focus has had a starting issue from time to time. Sometimes she will turn over and run for a second then die and other times she just cranks but no fire. In the past I would check a few things or maybe disconnect the battery or just give her some time and she would fire up and be fine for a few weeks - but not today, had to leave her in the parking lot at the gym :( Turns over like a Champ but today just seems/sounds like no fuel is being sent at this point??? The SVT Focus fuel pump is pretty high volume and you can hear it kick on a send fuel before you try and turn her over (that is, when it is working)...
Is there a diagnostic tool that can maybe give me some direction???
I'm wondering if maybe the main fuse (not the blue 15amp, but the bigger box one) is going out, but really no idea how to tell if those are bad?
Maybe a relay? or bad wire or ground?
or Maybe the fuel pump is going out ... but would guess those things last longer then 77K miles
Any suggestions or ideas??
Thanks for the help - Tim
TimmaY
2003 Pitch Black SVT Focus
1996 Mystic Cobra #544
VP www.midwestfords.org
Mystic544 is offline
Old 12-13-2012, 12:18 PM   #2
Mystic544
Mystic544's Avatar
Fan#: 17917
??? Nothing....
Well - went back late last night to give her another try and sure enough, she turned right over. Ran rough at 1st but drove home like a champ...
No idea why letting her sit all afternoon "changed" anything - don't know what to think about this issue????
TimmaY
Old 12-13-2012, 12:38 PM   #3
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
I don't know much about the SVT, but sounds like it might be a fuel issue.
probably not a fuse, i don't think they cause intermittent failures, but there is no harm in looking at it.
it could be wiring, but i would bet fuel pump is most likely culprit.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 12-13-2012, 12:55 PM   #4
Elder
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Well, that second post gave me ONE idea, but I'll admit THIS idea doesn't QUITE add up to a no-start....
Starting up after sitting a while, then running rough & smoothing out, SOUNDS like possibly a "flooded" situation. One cause that's only occasionally seen is an injector that doesn't seal and leaks fuel into the cyl. after shut down.
(there's another similar issue possible I remember seeing here, but I need to check details on that)
You might try the "flooded" starting procedure (foot to the floor to cut fuel injection) next time & see if that helps.
Luck!
sailor is online now
Old 12-13-2012, 01:30 PM   #5
SVTisRight4me
Fan#: 105772
What I Drive: 2004 Black SVTF 3 door#1009 in 2004
FF Reputation: 1 SVTisRight4me Good Standing Member
before u do anything else i would go back to where u got the battery and get them to test it.; probably not the problem but its worth a shoot considering it works some times and not others. but it ran rough at first so its probably not it. worth a shoot.:)
-Baker
SVT Focus 2004 EAP 80k miles +. 1 of 128
SVTisRight4me is offline
Old 12-13-2012, 05:06 PM   #6
Mystic544
Mystic544's Avatar
Fan#: 17917
Cool
Thanks for the thoughts!
I was planning on pulling some stuff and checking the situation out - try cleaning the throttle body & IAC while checking wires and vac lines. I will add pulling the injectors and looking at the O rings...
After she started, it only ran rough for like 15 seconds - kind of like she either wasn't getting enough fuel or getting too much fuel. After she settled down, I drove off...
The battery cranks with no issues...but since I currently only seem to make short trips, it might not hurt to check the charge.
I guess my wonder on the Fuel Pump would be, if it is going out - why is it only a start up issue and not a problem while driving??? No hesitation when I step on it or decellerate. And do they actually progressivly get worse or just go dead???
I also had a random thought - what if the Key is going dead (PATS)? Does that not even allow the car to turn over OR does it allow it to turn over but not fire? Being a 2003 one has to wonder how long those Keys last???
Thanks Again - TimmaY
TimmaY
Old 12-13-2012, 06:40 PM   #7
Elder
That injector thought is for the injector itself, not the o-rings for it"s installation...
PATS failure lets it crank but not fire, but you WOULD get a flashing dash light for that - the same one that flashes slow when you lock it up...
Old 12-17-2012, 09:06 PM   #8
Mystic544
Mystic544's Avatar
Fan#: 17917
Arrow P1246
So - a friend brought over his killer SnapOn scan tool tonight...
Didn't read any issues initally, but this code came up after running for a while:
P1246 - Alternator Load Input
1st thoughts were maybe a bad ground (but where to check???)
? -Anyone have experience with that code- Thoughts???
Thanks again .... TimmaY
Oh- after cleaning the throttle body & IAC, checking wires and useing electric parts cleaner on connections, pulled the injectors cleaned and looked at the O rings and put a new fuel filter ... she started fine twice today and drove pretty darn smooth.
TimmaY
