turn off lights auto when turn off car - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-12-2012, 04:33 PM   #11
flingwing1969
flingwing1969's Avatar
Fan#: 91700
Points 1,131, Level 18
Points: 1,131, Level: 18 Points: 1,131, Level: 18 Points: 1,131, Level: 18
Level Up 31% Completed
Originally Posted by yanivdan98 View Post
hi
first of all, i have the europe model of ford focus...
second, how can i get into the Sync opton menu and set the delay to 0?
do i need the specific Bus for ? or is there any option to do it from the radio menu?
thanks
If your's was truly manufactured in the EU, it should already have DRLs.
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
flingwing1969 is offline
Old 12-12-2012, 04:33 PM   #12
Points 10,236, Level 67
Points: 10,236, Level: 67 Points: 10,236, Level: 67 Points: 10,236, Level: 67
Level Up 47% Completed
Forum Activity 30%
hi
thanks
In europe I don't think the cars had sync available yet, so the proceedures will be a little bit different.
http://www.ford.co.uk/OwnerServices/Owners-Manual
Consult your owners guide for the details of how the system works.
Home safe lighting
Switch the ignition off and pull the
direction indicator lever towards the
steering wheel to switch the headlamps
on. You will hear a short tone. The
headlamps will go off automatically after
three minutes with any door open, or 30
seconds after the last door has been
closed.
The home safe lights can be cancelled by
either pulling the direction indicator lever
towards the steering wheel again or by
turning the ignition switch ON.
suss6052 is offline
Old 12-12-2012, 04:44 PM   #13
yanivdan98
Fan#: 107246
What I Drive: ford focus 2012 black
FF Reputation: 1 yanivdan98 Good Standing Member
http://www.motorcraftservice.com/pub...N12FOCog4e.pdf
thanks, first, the pdf link isnt working ,can you fix it please?
second..i didnt understand you how can i set the home safe function that will turn off light after turn off my car?
thanks you all guys!
yanivdan98 is offline
Old 12-12-2012, 04:48 PM   #14
Forum Activity 30%
Go to the second link and search for the manual, I can't directly link to the motorcraft page as they don't allow it to be linked. Select the 2012 Model Year and then select Focus EU then it will give you a list of owners documentation, pick the latest revision of the owners manual.
That was the proceedure listed in the manual for your european model to have a programmed three minute delay with the doors open or 30 seconds after the last door is closed.
You would pull the indicator stalk (which is also the high beam switch) towards you with the ignition off until you hear the warning tone which will indicate its been programmed.
suss6052 is offline
Old 12-12-2012, 04:51 PM   #15
yanivdan98
Fan#: 107246
thanks you, i got the manual , however i i didnt understand you how can i set the home safe function that will turn off light after turn off my car?
can someone exaplain it for me?
Old 12-12-2012, 04:58 PM   #16
Forum Activity 30%
I have explained it as plainly as I can in my previous post.
Step one: Turn the car off.
Step two: pull the turn signal/ dipped beam switch towards you (this should be on the left side of the steering wheel if its laid out like the lhd cars) until you hear a chime.
This enables the pre-programmed delay to leave the head lamps on for 3 minutes with the door open or 30 seconds after the doors are closed. This is to allow you to have an illuminated path to your home.
If you want to disable it I believe the proceedure outlines pulling the stalk forward again or turning the ignition on and off.
This will only keep the lights on for a set period after turning the car off, this won't turn them back on if it is not already dark when you turn the car on.
suss6052 is offline
Old 12-12-2012, 06:04 PM   #17
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,083, Level 83
Points: 17,083, Level: 83 Points: 17,083, Level: 83 Points: 17,083, Level: 83
Forum Activity 7%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
hi
i have ford focus 2012 model and when i turn off the car and the lights are in auto model the lights are not turn off and stay on..
how can i automatically turn off the lights after X seconds when i turn off the car and automatically turn on the lights when i turn on the car?
note that in my previous chevy cruze it was possible..
thanks alot
on your steering wheel, you should have a button that says okay and has arrows. use the arrows to select the menu. then select headlights. then you can set the delay for up to 20 seconds or not at all. i just set mine for 20 seconds. mine used to be set for 0.
Originally Posted by flingwing1969 View Post
The U.S. Focus is not equipped with daylight running lights (DRL - lights that stay on during the day). There is considerable discussion here as to whether or not the BCM can be reset to turn on the DRL feature in our cars without modification to hardware. If you want DRLs there are several options out there, including modifying your fog lights to run of an ignition on power source so they will turn on/off with your ignition key. It is a minor wiring cut/reconnect but should be done carefully by someone who is knows how. You could get a Canadian Focus too - DRLs are required there.
incorrect sir. my car was equipped with DRL's. US built, but with Canadian setup as my car was previously a rental car. I had a technician at the Ford dealer I work at go into the BCM and turn the feature off. Took him about 40 minutes and my headlights are no longer on all the time.
Will aka Misfire
misfire is offline
Old 12-12-2012, 06:46 PM   #18
flingwing1969
Fan#: 91700
I meant a Focus built to the US market and not a fleet vehicle. Along the border there are a number of cars built to Canadian specs.
1975 Jeep CJ -built
Old 12-12-2012, 09:29 PM   #19
cobie56
Fan#: 84403
Unless there is something wrong with your car it is supposed to turn the headlamps off as soon as you turn the car off when left in auto mode.
Mine has always shut off as soon as I turned the car off.
suss, there is an adjustable delay setting incorporated into the auto light system which can b adjusted to delay lights out
cobie56 is offline
Old 12-13-2012, 12:02 AM   #20
Forum Activity 30%
Yes, but by default its set to manual, and that's where I'd prefer it to be. I don't want to leave the lights on when I get out of the car. The default has them turning off as soon as the engine is shut off.
The only other options are 20 second intervals up to 60 seconds. Since it doesn't actually let you dial in a manual delay it should really be called 0 seconds, but that's ok.
My car didn't sit around on the lot for months and no one really played with it except me, so since that's where I want it that's likely where it will stay.
suss6052 is offline
