Oil Pressure - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 12-07-2012, 12:49 PM   #1
aernan
Fan#: 105907
What I Drive: 2013 performance blue ST3
FF Reputation: 2 aernan Good Standing Member
Oil Pressure
My ST is the first car I have had an oil pressure gauge. I have no real idea what it should be reading. These are my finding please tell me if they are normal.
Cold Start:
3/4 or above on the gage until warm
Warm Start:
Goes to 50% then comes down
Idle:
in the lower 1/4 area. Seems low to me
Driving:
around 50%
When the car had low milage the gage never went down to the lower 1/4 area. Now I have 2200 miles on the car it lives down there at idle. I'm guessing this is normal.
Questions:
Does the wear level of the oil change the oil pressure?
How much variation should I expect based on outside temp?
Does the now lower oil pressure at idle suggest the engine is now broken in?
aernan is offline
Old 12-07-2012, 01:00 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Forum Activity 16%
it's fine. (basic answer I know)
mikebontoft is online now
Old 12-08-2012, 11:49 AM   #3
KaputtEqu1pment
Fan#: 91122
What I Drive: 2012 Triple Plat White Focus Ti HB
FF Reputation: 1 KaputtEqu1pment Good Standing Member
One of the first questions i asked when I got my car. It'll be ok. Oil will be colder and this a little bit more dense and therefore more pressure. Basically, don't mash the throttle on a winter morning (or on a cold engine in general) and you'll be A-Ok
KaputtEqu1pment is offline
Old 12-15-2012, 12:12 AM   #4
vanace
Fan#: 350
What I Drive: 2005 ST
FF Reputation: 1 vanace Good Standing Member
You have a new car. Your oil pressure is fine. Get used to it and don't bug the dealer about it. People who bug the dealer about oil pressure is why for many years we had a idiot oil pressure gage that didn't tell us the truth. Now they are coming with a true oil pressure reading. Don't ruin it for us gear heads by whining about oil pressure. If you have any oil pressure at idle you are fine. Quit worrying about it. Why do you think the idle oil pressure is low? Are you some kind of engineer? Do you know more than Ford's design engineers? Peoples opinions are over rated (mine included) so let the engineers do there job. low oil pressure at idle is normal. The oil pump isn't turning as fast as it would at crusing speed DUH!
ST crew #18
vanace is offline
Old 12-15-2012, 02:39 PM   #5
aernan
Fan#: 105907
like I said in my post. I don't know what's normal because I've never had an oil gage.
aernan is offline
Old 12-15-2012, 05:31 PM   #6
shineboy
shineboy's Avatar
Fan#: 60173
What I Drive: 2013 ST, 2004 Cobra
Points 1,216, Level 19
Points: 1,216, Level: 19 Points: 1,216, Level: 19 Points: 1,216, Level: 19
Level Up 16% Completed
FF Reputation: 1 shineboy Good Standing Member
My car runs basically the same: pegged when cold, normal cruise ~50% (~35lbs)... I agree idle looks alow 25% or ~16lbs when warm. I am at ~3000 miles and just about to do the first oil change
2013 ST2 for DD
2004 Terminator for fun
shineboy is offline
Old 12-16-2012, 01:31 AM   #7
aernan
Fan#: 105907
I have not looked in the manual. What is the oil change interval?
aernan is offline
Old 12-16-2012, 07:16 AM   #8
shineboy
shineboy's Avatar
Fan#: 60173
Supplment says see manual. Same as standard Focus but I will go by severe duty since its turbo
2013 ST2 for DD
shineboy is offline
Old 12-21-2012, 11:03 PM   #9
acbauza
Fan#: 104447
What I Drive: 2013 Performance Blue Focus ST
FF Reputation: 1 acbauza Good Standing Member
For the sake of the turbo and all the high temp that's in there use the full synthetic. Having already done mine at 1200 miles after tracking the car I can say you will notice a difference in the oil press and oil temps.
I change mine every 3000 to 5000 miles under "normal" conditions, but under track conditions I will dump it every 3000 period.
acbauza is offline
Old 01-22-2014, 08:31 PM   #10
shawndevaraj
Fan#: 137105
What I Drive: 2014 Tuxedo Black Focus ST3
FF Reputation: 1 shawndevaraj Good Standing Member
Hey guys, my oil pressure maxes out at just under 70psi at 1800 rpm on startup. It takes about 5miles before the pressure starts dropping. The reason I am concerned is because the pressure seemed to jump by about 5psi at 4800miles and when I did my first oil change at 5000miles, the pressure did not drop. Also, I started a brand new ST and revved the engine to 2500rpm and the pressure was still lower at around 60psi. So if you see an ST doing 55mph on the freeway, that is me freaking out about the oil pressure.
The dealer says that it is normal, but I am sure that it is not. To confirm, could you please reply with your cold startup oil pressure at 1800rpm? Thanks for your help.
shawndevaraj is offline
