2005 Focus ZX4 Transmission problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-06-2012, 04:24 PM   #1
matt6195
Fan#: 107036
What I Drive: 2005 Black ZX4
FF Reputation: 1 matt6195 Good Standing Member
I have a 2005 Ford Focus ZX4 Auto trans. Car has 122,000 miles. Tranny fluid was changed at 100,000 miles.
I was coming home from work one night and got on the gas in first gear the car rev'd up to 4 grand and didn't shift. The O/D light came on and started flashing. I ran my scan tool on the car and it gave me a code which came back to Trans-axle solenoid.
Took the car in and they ran the scan and said yep thats it. $465 later and it's still doing the same thing. The car shifts really hard. They say they see no damage to transmission. They are sending it Ford Monday to get a better scan done.
Any idea's on what it could be? The transmission gave no signs of problems. Just one day and bham I had an issue.
Thanks for the help!
matt6195 is offline
Old 12-06-2012, 04:45 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Level Up 84% Completed
Forum Activity 8%
Well, these transmissions are completely controlled by solenoids.
It could be one of the solenoids, the wiring that connects that solenoid to the computer that controls it, or an internal mechanical problem.
Do you know which solenoid(s) were replaced, what the trouble code(s) were?
Looking at the solenoid engagement chart, the only one that changes state during the 1-2 upshift is "shift solenoid D" which goes to full-open.
(if the cart is left in "D", manually upshifting involved solenoids A, B as well) .
elsolo is offline
Old 12-06-2012, 05:00 PM   #3
matt6195
Fan#: 107036
I believe it was p0706. The car was in D when this happened. I believe I did try manually shifting from 1 to 2 and had the same problem.
matt6195 is offline
Old 12-06-2012, 10:44 PM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 8%
I don't see p0706 on the chart I have, it goes from 0705 right to 0712.
elsolo is offline
Old 12-07-2012, 09:52 AM   #5
matt6195
Fan#: 107036
Transmission Range Sensor Circuit Performance
Is what P0706 shows.
However I was talking to another guy last night and he said his fusion had similar problems and it ended up being the speed sensor?
This is past my mechanic skills. However being $500 into the car in a new part that the mechanic thought was problem and isn't, really sucks.
matt6195 is offline
Old 10-14-2013, 02:31 PM   #6
jcraw
Fan#: 119810
What I Drive: 2005 White Focus
FF Reputation: 1 jcraw Good Standing Member
I have a 2005 Ford Focus ZX4 Automatic 2.3 118K miles
engine revs up and has a hard shift from 1st to 2nd gear, brought it in to a mechanic who I trust and he found the following codes:
P0732 Transmission Gear # 2 incorrect ratio Status FF (Above Maximum Threshold)
P0767 Shift Solenoid # 4 stuck on Status FF (Above Maximum Threshold)
P0981 Sift Solenoid D Control Circuit Range / Performance Status FF (Above Maximum Threshold)
Advise getting an estimate from a transmission shop.
Any suggestions?
Thanks.
jcraw is offline
Old 10-14-2013, 02:33 PM   #7
jcraw
Fan#: 119810
2005 Focus Transmission problem
Any suggestions?
Thanks.
jcraw is offline
Old 10-14-2013, 03:17 PM   #8
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,008, Level 45
Points: 5,008, Level: 45 Points: 5,008, Level: 45 Points: 5,008, Level: 45
Level Up 29% Completed
Forum Activity 12%
FF Reputation: 6 SlickWilly Good Standing Member
Probably change noid D, not to hard of a job on some transmissions.
K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - N2O
SlickWilly is offline
