Old 12-06-2012, 06:43 PM   #1
H8VTEC
Fan#: 107041
What I Drive: 2001 white ZX3
FF Reputation: 1 H8VTEC Good Standing Member
2001 zx3 wont start
Hi guys, ive searched and searched this forum and im still at a stand still. Car wont start. Things ive done to track down the cause....
1. Checked spark. Removed a plug, attached it the wire out of the cylinder and it sparks.
2. Disconnected fuel line after fuel filter. When i turn the key on it spits gas, so i know the pump is working. I disconnected the line at the fuel rail and had the same results.
3. I checked the fuel injector pulse on all 4 injectors and the ecu is sending the signal to each injector.
4. I checked the inertia switch. I bypassed it to try to start it and it did not start.
5. I checked compression. 120-120-120-118, cold.
6. I plugged in a scan tool and im only getting 7 psi fuel pressure when i turn the key to on. Is that normal for these cars?
Im stuck. Anyone have any other suggestions? Thanks.
H8VTEC is offline
Old 12-06-2012, 08:02 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2002 ZX3
FF Reputation: 18 freemind Great Standing Member
Buy-Sell-Trade Rating: (16)
45psi is the spec IIRC
133whp-126ftlbsTQ Eclipse CD8443,JBL Px300.4, JBL GTO7001, PPI 356cs, JBL p1022 in .95 cubes, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 12-06-2012, 08:59 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 33 iminhell Great Standing Member
39 actually, but 7 is definitely under spec.
There's no easy way to do it but I'd almost put a mech. gauge on it and double check that pressure.
Did fuel spray out or did it stream out? Meaning, did it seem like there was good pressure.
Could be the Fuel Rail Pressure Sensor is bad. If it sees low pressure it will send more voltage to the pump and actual pressure might be so high that the car floods almost instantly.
iminhell is offline
Old 12-06-2012, 09:33 PM   #4
H8VTEC
Fan#: 107041
So as soon as i turn the key to on it should be at 45psi?
H8VTEC is offline
Old 12-07-2012, 12:33 AM   #5
freemind
freemind's Avatar
Fan#: 67513
Like iminhell said, 39 psi is spec and yes, the pressure should be there when you turn the key to start.
Hatch Nation #140
freemind is offline
Old 12-07-2012, 12:48 AM   #6
H8VTEC
Fan#: 107041
Fuel didnt spray out, but it did push it out....but not 45psi like.i'll check pressure tomorrow with a mechanical gauge. I'll connect it after fuel filter.
H8VTEC is offline
Old 12-07-2012, 05:19 PM   #7
H8VTEC
Fan#: 107041
Ok, checked fuel pressure manually and its only getting 7 psi. I changed the fuel pressure sensor and still no luck. Any other ideas?
H8VTEC is offline
Old 12-07-2012, 08:24 PM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Only 7 would sound fuel pump, not the FRPS. The sensor read 7 and you manually got 7, so it's working.
Pull the line before the Fuel Filter and see if that makes a difference. Hell, just replace the Fuel Filter being you're right there.
If there's no change you're going to be replacing the pump. How you want to go about that is up to you; cut an access hole or drop the tank.
Just make sure the pump you buy has the spring top (update pump).
iminhell is offline
Old 12-08-2012, 01:32 PM   #9
H8VTEC
Fan#: 107041
I replaced the pump with a new one from a local parts store. I cut an access panel, way easier than removing the tank. What do you mean by spring top? Should i get it from the dealer?
H8VTEC is offline
Old 12-14-2012, 08:22 PM   #10
H8VTEC
Fan#: 107041
Ok....replaced the fuel pump with a spring top fuel pump, had to cut the old bracket inside the tank....what a pain! It now gets 40psi but i got a code P1237. So i guess i have a short somewhere. Any suggestions on where to start?
H8VTEC is offline
