2013 engine "click click whir" (engine not running) - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-05-2012, 08:13 PM   #111
Kabigon
Fan#: 88299
Points 4,568, Level 43
Points: 4,568, Level: 43 Points: 4,568, Level: 43 Points: 4,568, Level: 43
Level Up 9% Completed
Forum Activity 14%
Originally Posted by able2358 View Post
Going to call dealer and see if it is possible to reflash the computer with an older version of the software. Anyone know if this is possible.
In theory yes, but a dealer can't do it.
Kabigon is online now
Old 12-05-2012, 08:25 PM   #112
HatsuneMiku
Fan#: 105511
What I Drive: 1996 Nissan Maxima
Points 24, Level 1
Points: 24, Level: 1 Points: 24, Level: 1 Points: 24, Level: 1
Level Up 47% Completed
FF Reputation: 1 HatsuneMiku Good Standing Member
Took my wifes car to a different dealer,
Two techs and service advisor were baffled.
They reflashed the computer i belevieve it was 12b35b upgrade.
Makes same noise they said not to worry but agreed it wasn't normal.
Read some more on another site and this update was for those complaining about the car rolling backwards on hill starts.People are opting to not have this update just for this reason. Going to call dealer and see if it is possible to reflash the computer with an older version of the software. Anyone know if this is possible.
Keep us updated if you found a solution.
HatsuneMiku is offline
Old 12-05-2012, 08:36 PM   #113
able2358
Fan#: 106565
What I Drive: 2012 focus
FF Reputation: 1 able2358 Good Standing Member
Will do.
able2358 is offline
Old 12-05-2012, 08:39 PM   #114
flingwing1969
flingwing1969's Avatar
Fan#: 91700
Points 1,131, Level 18
Points: 1,131, Level: 18 Points: 1,131, Level: 18 Points: 1,131, Level: 18
Level Up 31% Completed
Originally Posted by rzero0101 View Post
I have the same issue and I don't feel whatever this noise is should be considered normal. I plan to take mine in sometime in the next couple weeks so the dealer can take a look. I found the following on another site.
"More than likely the noise you are hearing is the shift fork actuator motors resetting in the transmission. Unlocking the door starts this process. When the shifter is placed in park and the engine shut off, the computer places the transmission in gear and releases both clutches. When the door is unlocked the computer begins resetting the shift fork motors and clutch motors in preparation for engine start. This is directly from Ford:
2013 Focus vehicles equipped with the Powershift DPS6 transmission may
experience a clicking noise from the transmission after the doors are unlocked and prior to the engine starting for up to 3 minutes. The noise is the transmission shift motors waking up and preparing for startup. Attempts to eliminate the noise should not be made."
They they change these parts in 2013 - I've never heard anything like this on my 2012 SEL 6-speed DCT. Also, why does it repeat for three minutes? It would seem that when the shift forks are reset and the clutch motors are too, they should be quite done,eh?
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
flingwing1969 is offline
Old 12-05-2012, 08:46 PM   #115
able2358
Fan#: 106565
I am not sure why keeps resetting but the one tech told me it takes 3minutes or so for the computer to shut down. We came to the conclussion that the only reason it stops making the noise is because the computer powers down.
able2358 is offline
Old 12-05-2012, 09:37 PM   #116
Fourder
Fan#: 107011
What I Drive: 2013 black tuxedo metallic Focus SE
FF Reputation: 1 Fourder Good Standing Member
An example of the issue posted on YouTube...
http://www.youtube.com/watch?v=YkbGjGX3dyM
Fourder is offline
Old 12-05-2012, 09:41 PM   #117
Kabigon
Fan#: 88299
Forum Activity 14%
This is true.
Those of you that have an OBD scan tool can confirm it.
When you open the door, you can read data (for example, engine coolant temp.) from the PCM for a couple of minutes and then the PCM will go to sleep.
Old 12-06-2012, 05:07 AM   #118
Defender
Fan#: 106391
What I Drive: 2013 Titanium HB (White Platinum)
Points 89, Level 1
Points: 89, Level: 1 Points: 89, Level: 1 Points: 89, Level: 1
Level Up 78% Completed
FF Reputation: 1 Defender Good Standing Member
Buddy, I promise you the dealer has no freakin idea what they are talking about. My dealer spent all of about 10 minutes looking on their system for the noise I described and one Salesman even said his was doing the same thing and that it was normal.
2013 Focus vehicles equipped with the Powershift DPS6 transmission may experience a clicking noise from the transmission after the doors are unlocked and prior to the engine starting for up to 3 minutes. The noise is the transmission shift motors waking up and preparing for startup. Attempts to eliminate the noise should not be made."
I personally don't like it anymore than anyone else here does, but Ford says it's normal and there hasn't been a recall yet so I don't see where the problem is, YET.
Peace, Defender
Defender is offline
Old 12-06-2012, 02:59 PM   #119
Pendarus
Pendarus's Avatar
Fan#: 94411
What I Drive: 2012 Sonic Blue Titanium 5dr
Points 365, Level 7
Points: 365, Level: 7 Points: 365, Level: 7 Points: 365, Level: 7
Level Up 30% Completed
FF Reputation: 2 Pendarus Good Standing Member
Twelve pages? Can someone explain why this is an issue? What damage is this causing?
Sonic Blue Titanium 5dr Titanium Handling Package
Ordered: 01/28/12
Vin: 02/20/12
Build Date: 03/06/12
Delivery Date: 03/30/12
Pendarus is offline
Old 12-06-2012, 03:42 PM   #120
Merrigan
Merrigan's Avatar
Fan#: 104581
What I Drive: 2013 Black SE Hatch
FF Reputation: 2 Merrigan Good Standing Member
No damages. Just paranoia.
Sent from your mom's house.
Sonics MK3 Crew #21
Merrigan is offline
