IMPORTANT: ALL MK3 Focus Owners, I could use your input. - Page 20 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-03-2012, 03:05 PM   #191
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Points 15,460, Level 80
Points: 15,460, Level: 80 Points: 15,460, Level: 80 Points: 15,460, Level: 80
Level Up 22% Completed
Forum Activity 29%
And also, not associated with the Dual Clutch arrangement as mine has a Manual Trans... No auto here
http://www.rebeldevil.com
Shade-010 is offline
Old 12-03-2012, 03:44 PM   #192
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Level Up 36% Completed
Likewise.
Joined the dark side.
Zillon is offline
Old 12-03-2012, 03:45 PM   #193
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
Points 22,494, Level 93
Points: 22,494, Level: 93 Points: 22,494, Level: 93 Points: 22,494, Level: 93
Level Up 15% Completed
Forum Activity 14%
I just got a voicemail from Ford Canada regarding this issue. Whenever their lines are clear hopefully I can get through to the rep who called and discuss it.
officialTHREETWENTY
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 12-03-2012, 04:06 PM   #194
Zillon
Zillon's Avatar
Fan#: 17393
Hopefully it's more than just bureaucratic mumbo-jumbo.
Good luck, amigo.
Zillon is offline
Old 12-03-2012, 09:36 PM   #195
Zillon
Zillon's Avatar
Fan#: 17393
Well, tried a few things tonight. First I tried removing the endlinks and tying the sway bar up.
No luck.
I also found that the subframe bolts aren't centered in the bushings. And, on top of that, they certainly were NOT tightened to the 115 N-m they were supposed to be tightened to. Regardless, the clunking doesn't seem to be much better after tightening them to the proper spec.
Note the shift.
Zillon is offline
Old 12-03-2012, 10:19 PM   #196
Shade-010
Sonic Crew # 010
Shade-010's Avatar
Fan#: 87369
Forum Activity 29%
weird, wonder if all of ours are doing the same thing?
Old 12-03-2012, 11:36 PM   #197
Zillon
Zillon's Avatar
Fan#: 17393
No idea. It's not exactly the easiest thing to check.
I do know my alignment is fine, though; I just had it checked in October after I bent a wheel.
Zillon is offline
Old 12-03-2012, 11:41 PM   #198
tang122
Fan#: 105830
What I Drive: 2012 Focus SEL Gray
FF Reputation: 1 tang122 Good Standing Member
Hey, guys
Unfortunately, My car also has the clunk noise. It has been out of service for more than 50 days in 4 months. No Fix.
I just want to share some information .
Mine is 2012 SEL, bought as a demo.First ,everything was great. But there was a small imperfection. When turning the steering wheel to the left at very low speeds, I could hear a friction noise. Like two rubber pipes rub against each other. Because I was going to do a oil change , I told the service guy to check that noise. And that was the beginning of the nightmare.
I think the first two service records might be the key.
1st. TSB 12-6-17 performed(Both front spring and upper strut bearing). Friction noise was still there, but any way, it was not annoying at all. Still no clunk.
TWO DAYS past.
2nd .VERY loud metal on metal noise came from front end when driving on FLAT road at ANY speed. I brought it to the dealership, and had the left front sway bar links replaced. The loud metal on metal noise went away, but..... the clunk noise appeared. Since then, the clunk has never been eliminated.
Something about the clunk.
It comes from the drivers side. Hot and dry weather makes the noise worse. Cool wet weather can improve the noise. And I don't have the strut reinforcement plate.
tang122 is offline
Old 12-04-2012, 12:13 AM   #199
Lipshurt
Fan#: 92314
Points 732, Level 14
Level Up 32% Completed
Hey I'm the credit card fix guy.
When its about 60 degrees my sound will show up now, but for a very short time, and its way better with the shim. Now the sound stops completely after driving about 2 to 4 minutes. It used to take 10 to 20 minutes to warm up enough. So the credit card is doing something. If it comes back, I'm going to get a set of chassis ears with wires, and trouble shoot the thing to the point of knowing exactly where the noise is coming from.
I'm not sure why nobody has done this yet. It will mean put all six mic clips in various suspicious places, record the output on 6 separate tracks on my laptop, lather rinse repeat, until its zeroed in. I can't do it till Christmas break, and I'll only have about 4 minutes at a time maximum before the sound stops. Of course I could take the credit card out.
The mics are 119 bucks at amazon.com
We could send them around to people on the forum. That would be a good data resource.
Or ford could it do it for us:)
I pretty sure that "ford customer service" will not show up here again, peddling that jive about "working on it" with engineers yadda yadda. That's total BS.
Lipshurt is offline
Old 12-04-2012, 12:25 AM   #200
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 14%
It was a moderate temperature tonight, about -2 degrees C, and my noises were much more subtle than normal. I at least noticed immediately leaving the parkade on campus, I didn't really pay attention the rest of the drive.
officialTHREETWENTY
Bill M.
Twenty is offline
