#171 | ||||
#172 | ||||
1) What is often described as a "grinding noise coming from the transmission" (I am very familiar with the sound), is not grinding and it's not coming from the transmission. 2) Many people have had their clutch assembly replaced and reported that the noise stopped. As you know, the clutches are outside of the transmission. 3) My car is approx. 18 months old and has occasionally made this noise for as long as I've owned it. My belief is that there are probably no ill effects associated with this noise (certainly not with the transmission itself). |
#173 | ||||
My belief is that without correcting how the learning process is performed in the computer that controls the gear shifts, the clutch will continue to tear itself apart every 20,000 miles or so. |
#174 | ||||
Thnak you for the information. I am just cuirious if your RPM's flux as well when this noise is going on and if your car shudders (jerks)? Mine does.
#175 | ||||
This is true for mine as well, when it was 65f earlier, it took it a few more miles to do it, but it made sure to make the noise after my first stop. However, when it was 75, it only took 3 miles and 3 stops to make the noise.
I am curious if this is some sort of heat problem, becuase if it is, when summer rolls around here it reaches 110 (and up) with no problem - I could imagine going half a mile and the clutches/xsmn quitting. |
#176 | ||||
Good luck with yours. I gave up at this point, I am just never ever will buy ford anymore. |
#177 | ||||
Otherwise, I was looking into the California lemon law and it seems to be a simple process of letting them try, letting Ford know I want it fixed in writing, and taking them through arbitration if nothing happens. I know I’m making it sound simple, but with 2 years of the same problem on these models, I don’t think a reasonable arbitrator will argue that I am wrong…hopefully. |
#178 | ||||
By the way you might want to ask about MPG as well. Cause I can't explain why they went south. Good luck |
#179 | ||||
Is there a known issue with MPG as well that I am missing? |
#180 | ||||
This is for California...
If the dealer won't help you adequately, turn to the manufacturer. Take these steps: Write a letter to the manufacturer asking it to buy back your car. This letter should be sent via certified mail, with a return receipt requested, to the address listed in your vehicle owner's manual. If the manufacturer balks at repurchasing your vehicle, you have two options: Hire an attorney that specializes in Lemon Law, or ask the manufacturer if it has an arbitration program. Check to see if the manufacturer offers an arbitration program by looking in your owner's manual, or by calling California's Consumer Affairs Hotline at (800) 952-5210. Request an application form and a copy of the manufacturer's arbitration program regulations. If you enter into arbitration, the manufacturer must schedule a hearing within 40 days. Now is the time to compile all your documents regarding the car's problem, including service reports, work orders, a copy of your warranty, and your calendar showing downtime for the vehicle. If at all possible, attend the arbitration hearing in person. You can either accept or reject the findings of the arbitration panel. Should you decide to reject the offer, or if the panel finds against you, don't despair. If you are not satisfied with the results, you can always file a suit against the manufacturer through the courts. If you file a lawsuit, and the court rules in your favor, the manufacturer has 30 days to pay you. If you are uncertain how to proceed with a lawsuit, be sure to hire an attorney who is experienced with this type of action. |
