Duratec 2.0L owners.. do you experience long cranking/need for multiple start attempts? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: Do you experience starting difficulty with your Duratec 2.0L Focus?
All the time 6 23.08%
sometimes 7 26.92%
seldom 3 11.54%
never 10 38.46%
Voters: 26. You may not vote on this poll
Old 12-02-2012, 06:00 PM   #1
xFOCIx
Fan#: 23553
What I Drive: 2005 ZX3 5spd
FF Reputation: 15 xFOCIx Great Standing Member
When it works normally, the starting setup on a Focus works like a start button.
Hold the key to "start" and ECU disengages the starter automatically even if you hold it at "start".
It usually takes 3-4 seconds of cranking to start. Sometimes the ECU will disengage it, then reengage the starter while the key is still held at "start" and grind gears.
Sometimes, it will stumble and stall shortly after starting, but fires right up on second attempt.
Do you experience this sort of starting difficulty with your Duratec 2.0L Focus?
I've been suggested to put the key to run and wait a sec or two before starting, as if I'm letting the glow plugs warm up on a diesel. I've tried it, and I can't say that its effective at all.
It's been like this ever since new, been to a few different dealers over the years and its never been resolved.
xFOCIx is offline
Old 12-02-2012, 06:04 PM   #2
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
Points 4,176, Level 41
Level Up 13% Completed
hell yea i do, iv been trying to figure that out for the longest , funny thing is when i use the remote start there are no problems lol.
Sent from my N860 using FF Mobile
sam fisher is offline
Old 12-02-2012, 06:46 PM   #3
Minchkin
Minchkin's Avatar
Fan#: 92792
Points 948, Level 16
Points: 948, Level: 16 Points: 948, Level: 16 Points: 948, Level: 16
Level Up 48% Completed
FF Reputation: 3 Minchkin Good Standing Member
Oddly enough, I get that with my 09... I flick it to start, it attempts to start for 10 seconds, then stops. Flick it again, BOOM! Starts right up. It is the weirdest thing ever.
Originally Posted by Fact Core from Portal 2
Before the Wright Brothers invented the airplane, anyone wanting to fly anywhere was required to eat 200 pounds of helium.
SES #032
Minchkin is offline
Old 12-02-2012, 06:56 PM   #4
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
This is an 05 only problem. It's been well documented in the Duratec Owner's lounge, and Duratec Performance forums. There is too much air getting in at startup, so it makes it hard to start sometimes.
What I've been doing for 150k miles is crank the starter for about 1 second, then stop, and bump it again. It always starts the second time immediately.
Old 12-02-2012, 07:01 PM   #5
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Level Up 38% Completed
I voted, but it's for my 04 2.3D, oops, sometimes it starts right up, other times 5 seconds of cranking and it starts, other times, 5 seconds of cranking and nothing, then bam, next key turn and it fires right up.
GreySkorpion is offline
Old 12-02-2012, 07:28 PM   #6
Forum Activity 10%
That sounds like the same issue. Another way I'd get around it was by bumping the key, then 1, 2, then starting. That gives you 2 fuel squirts and enough time for the first one to form vapor. That might not be a good method when it's cold. EFI engines can flood too, but the way to clear a flooded engine is similar. It's also called Emergency start mode: key off, press and hold accelerator to the floor, then crank the engine. No fuel will be sprayed, if there is fuel in there already when it's sufficiently mixed it will start. Just let off the gas when it does, and it will idle.
Old 12-02-2012, 07:33 PM   #7
SaleenT121
SaleenT121's Avatar
Fan#: 57997
What I Drive: 05 Saleen Focus
Points 3,174, Level 34
Points: 3,174, Level: 34 Points: 3,174, Level: 34 Points: 3,174, Level: 34
Level Up 83% Completed
FF Reputation: 3 SaleenT121 Good Standing Member
I got an 05 and i used to get that a lot before i modified the car.
Saleen Focus #74
-Carbon Hood and trunk
-SVT rear Disc brake conversion
-Custom fab turbo kit
-Built 2.0L by Turbo Turtle
SaleenT121 is offline
Old 12-02-2012, 07:54 PM   #8
JüstCantFocüs
Team NoSoul
JüstCantFocüs's Avatar
Fan#: 103283
What I Drive: 2015 GTI, 13 Mopar Edition Dart
Points 8,460, Level 62
Points: 8,460, Level: 62 Points: 8,460, Level: 62 Points: 8,460, Level: 62
Level Up 4% Completed
Forum Activity 37%
FF Reputation: 12 JüstCantFocüs Great Standing Member
hmm I've never had this issue
Hatch Nation Leader #95
JüstCantFocüs is online now
Old 12-02-2012, 08:44 PM   #9
xFOCIx
Fan#: 23553
doesnt look like 05 only..
xFOCIx is offline
Old 12-02-2012, 09:19 PM   #10
GreySkorpion
Fan#: 94674
I have tried the turn key to run for 2 or 3 seconds but not start trick, no change, still will crank a few seconds. But then sometimes, bam, no hesitation.
