Make me a parts list - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2012, 12:40 PM   #1
SlateTheGreat
SlateTheGreat's Avatar
Fan#: 63859
What I Drive: 2008 Silver SE Sedan
FF Reputation: 1 SlateTheGreat Good Standing Member
Hey all!
So I have an 08 sedan that's due for a good amount of maintenance so I plan on upgrading as I go. I want this little car to be the best canyon carver it can be so I want to revamp the suspension as much as possible.
I want to do coilovers, sway bars, poly bushings, and camber/toe arms as necessary. I'm planning on running 17x9 et 30 (or so, correct me on the offset if that won't work) Team Dynamics 1.2 with hankook ventus tires (no stretch, meaty stance). EDIT: silver car, should I do black/gold/white wheels?
What I'm looking for is a list of brands and where to buy them of all the parts you would suggest for the upgrades above! Thank you all in advance for helping me compile this. I'm planning on doing i/h/e/t as well for the power side of it.
SlateTheGreat is offline
Old 11-30-2012, 04:19 PM   #2
thenorm
thenorm's Avatar
Fan#: 14947
Points 5,551, Level 48
Points: 5,551, Level: 48 Points: 5,551, Level: 48 Points: 5,551, Level: 48
Level Up 1% Completed
Forum Activity 8%
those wheels are close to the right offset , but you will have issues with your fenders. (6mm closer to strut, 44mm closer to fender). Especially if you want meaty stance, which would call for a 245/40R17 tire. An easier fit would be 17x8 40mm.
May 2014 ROTM
for street: '02 Infrared SVT
thenorm is offline
Old 11-30-2012, 09:53 PM   #3
SlateTheGreat
Fan#: 63859
Yea after talking to another couple of guys I'm going to be doing et38, I thought it was 30 but I remembered wrong :)
Old 12-01-2012, 01:48 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,007, Level 74
Points: 13,007, Level: 74 Points: 13,007, Level: 74 Points: 13,007, Level: 74
Level Up 40% Completed
Add to that list CFM's tubular control arms, 4-point lower stress bar, dogbone, STS. I see you have toe-links already.
felixthecat is offline
Old 12-01-2012, 01:55 AM   #5
SlateTheGreat
Fan#: 63859
I have an automatic :'((((
But yes I will add those to the list.
Old 12-01-2012, 02:22 AM   #6
SlateTheGreat
Fan#: 63859
http://www.tirerack.com/tires/tires....10XL&tab=Sizes
http://www.teamdynamicsracing.com/pr...Pro-race12.htm
http://focus.c-f-m.com/spc-rear-uppe...0-13-pair.aspx
http://focus.c-f-m.com/cfmfronttubul...fordfocus.aspx
http://focus.c-f-m.com/cfmlowerengin...0-10focus.aspx
http://fswerks.com/coilover.htm
http://focus.c-f-m.com/newitemcfmfro...2010focus.aspx
http://fswerks.com/fswerks_coolflo_air_intake.htm
http://fswerks.com/headers.htm
http://www.carid.com/2000-ford-focus...m-1461410.html
As an alternative to the coilovers, koni yellow/race springs are always an option with the omni kit
Do all years of Focuses have the same bushings set?
Old 12-01-2012, 11:25 AM   #7
felixthecat
w/ my magic bag
Fan#: 80663
For the rear camber arms I Like the Sure motorsports one's. Don't forget about getting the boots for the cfm arms & toe-links. I'd pass on the poly bushing kit for the rear. What sway bars are you going w/? Eibach has f22mm/r25mm.
Old 12-01-2012, 12:14 PM   #8
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
I find it hilarious that links to FSWerks are blocked.
... Anyways, don't waste your money on any lower braces. If doesn't matter if its a 2 point, or a 4 point, or a 15 point. The only thing those are good for is as a skid plate of sorts for being low.
Likewise, tubular control arms aren't going to add anything to the mix beyond what a good set of camber plates will do. In fact, you'll actually loose inside wheel clearance as you adjust camber inwards.
Bigger isn't better when it come to sway bars either, especially on a road like GMR where there are a lot of undulations and decreasing radius turns. Sway bars should be the last thing you do so you can fine tune the car. Your best bet is to try to find an Auto-X-ZTS rear bar that is adjustable. A 25mm rear bar on that road will suck, you can count on that.
Save the money spent on the tubular brace and control arms and put a differential in. That will far outweigh any benefit those two parts could bring.
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 12-01-2012, 02:32 PM   #9
felixthecat
w/ my magic bag
Fan#: 80663
Just to add the lower bar do more than a strut tower bar does.
Old 12-01-2012, 05:15 PM   #10
Nickgt40
Nickgt40's Avatar
Fan#: 40924
Right, nothing plus a little is better than absolutely nothing.
Hatch Nation #2
Nickgt40 is offline
