MFT 3.5.1 bugs - Page 4 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 11-29-2012, 03:52 PM   #31
copernicium112
Fan#: 87742
Points 1,491, Level 21
Level Up 91% Completed
Originally Posted by TiPilot View Post
Honest to god, I don't understand how this hasn't returned yet with all the updates we've had over the past year.
That is what I'm sayin'. Taking away a functional progress bar and replacing it with the useless count-up timer is like getting kicked in a nut. Not only refusing to return the progress bar but also proudly displaying the useless count-up timer on one more screen so I'm reminded of the loss on that screen as well is like getting kicked in both nuts!
copernicium112 is offline
Old 11-30-2012, 01:07 AM   #32
flingwing1969
flingwing1969's Avatar
Fan#: 91700
Points 1,110, Level 18
Points: 1,110, Level: 18 Points: 1,110, Level: 18 Points: 1,110, Level: 18
Level Up 10% Completed
Originally Posted by Aychdot View Post
Mine works pretty well except when I start the car. MFT wants to start at the first track on my usb no matter what I was previously listening to.
That's been my experience with 3.0.2 also.
2012 Yamaha TW200 Dual Sport
1975 Jeep CJ -built
flingwing1969 is offline
Old 11-30-2012, 11:01 AM   #33
12RedHotHatch
Fan#: 96478
What I Drive: 2012 Candy Red Focus Titanium Hback
FF Reputation: 1 12RedHotHatch Good Standing Member
Overall it is working much better than previous versions but the same thing has happened to me twice. I was listening to Bluetooth Audio on my iPhone 5 and stopped at a store. When I got back in and started the car back up, the entertainment section could not connect to Bluetooth Audio and the lines on my Backup camera (straight and based on how the wheel is turned) disappeared. I had to go into settings and turn the lines back on. Also after this happens, when I switch to my USB thumb drive, it restarts at the first song instead of at the song / album I was last listening to.
But at least when this does happen it will connect back up to Bluetooth Audio in a minute or two. With 3.0.2, the Bluetooth Audio connection was toast until it decided to reconnect, which took a while.
12RedHotHatch is offline
Old 11-30-2012, 12:05 PM   #34
bassmobile
bassmobile's Avatar
Fan#: 95742
What I Drive: 2012 Yellow Blaze Titanium Focus
FF Reputation: 2 bassmobile Good Standing Member
Well just had the 3.5.1 updated installed. Now note, I still had v2 in my car. So this was a major upgrade.
So far pretty good. So much faster than the previous version I had. But there is one bug (so far) that is driving me nuts!!
All my music is on a SD Card. I cannot get it play genre "blues" via voice command! When I try it plays "rock". It works fine if I say "jazz" or "classical" and "rock". But will not do blues for some reason. If I do it manually via the touch screen I can get it to play blues. I did a couple of master resets and forced the SD card to be indexed, but no luck so far!
2012 Ford Focus Titanium Hatch - Yellow Blaze
2007 Mercedes Benz SLK 280 - Bright Silver Metallic
bassmobile is offline
Old 11-30-2012, 07:16 PM   #35
peridigm
peridigm's Avatar
Fan#: 103341
What I Drive: 12', Ti wrapped
FF Reputation: 1 peridigm Good Standing Member
I just got my car back today after being updated to 3.5.1. Previously had 3.0.2. My 3.0.2 issues were similar to everyone else, sporadic reboot, button labels blank, slow response, etc...
What I have observed so far...
1) I cannot make a call with voice recognition. Repeated attempts to make calls using names from my IOS5 iPhone ended with "please say a name as it is listed in your phone book". Despite me speaking clearly and the same way I spoke with 3.0.2, it would not make one call. I tried about 6 names from my contact list. I finally resorted to "dial xxx-xxx-xxxx". She repeated the number back to me and dialed.
2) I'm primarily a Sirius listener. For some reason today I could not locate anything that I wanted to listen to so I decided to use my iPhone BT connection. This is where the frustration began. 20 seconds into track 2, it decided to start track 3. Um, okay. When I reached the end of the album, it switched to a new album with unknown artist, 0 tracks. It would not skip forward, backward, or play. Silence!
I selected a new album from my iPhone (yes I pulled over first). I skipped to the last track and let it play. When it reached the end, the same thing happened, silence. I changed source to Sirius, then back to BT. Still wouldn't play.
I started a new album and let it play. I had to stop for gas. When I got back in and started the car, it was still on BT, but now the display read Walt's iPhone where it should have the artist and song title, the track listing was where I had left it, and it would not play, skip back or forward. It was silent again! I finally had enough and switched it to Sirius for the rest of my trip.
Anyone else having this BT quirkiness? IOS5 or IOS6? I don't really want to upgrade to IOS6 but I may to see if my issues are resolved.
peridigm is offline
Old 11-30-2012, 07:48 PM   #36
dragonpalm
dragonpalm's Avatar
Fan#: 104183
Points 571, Level 11
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Level Up 43% Completed
You are the 3rd person on here (including me) that has experienced the BT track auto-advance (skip) problem on 3.5.1. I'm kinda glad others are experiencing this but I'm sorry that it is you. I have the same problems as you described and I use an iPhone 4S 6.0.1. BT audio has always been the worst part of MFT and it looks like 3.5.1 doesn't fix it completely. I suggest you avoid BT audio until someone has resolved this issue. Someone reported that they did a master reset/delayed reboot and it fixed the issue for them. However, this did not fix it for me. I'm going to do a fuse pull+master reset tomorrow to see if it helps. For now, I just plug my phone into the USB and listen that way.
Here is my log of the problem
*Edit* A fuse pull+master reset did not fix this issue for me.
dragonpalm is offline
Old 11-30-2012, 07:56 PM   #37
Richs10
Richs10's Avatar
Fan#: 95786
What I Drive: 2012 Sonic Blue Titanium Hatch
Points 336, Level 6
Points: 336, Level: 6 Points: 336, Level: 6 Points: 336, Level: 6
Level Up 72% Completed
FF Reputation: 1 Richs10 Good Standing Member
Got my upgrade and new nav card this week. Initial impressions are that navigation locks on faster and the HD FM signals are way stronger. I'm finding new HD stations I never had before. Also, my IPod synced up much faster. Very happy with it so far! I do wish they had fixed the song timer to count down rather than up. That "feature" is still a bit of a mystery to me.
Leather, Nav/MFT, Moonroof, 18" wheels, Handling & Winter Packages, Remote Start.
Echomaster DRLs.
Richs10 is offline
Old 11-30-2012, 08:00 PM   #38
bassmobile
bassmobile's Avatar
Fan#: 95742
Well now the select music via genre using Voice Command seems to be working. I guess it was not fully indexed and did not finish building the voice commands when I first tried. So....I am liking this upgrade!
Old 11-30-2012, 09:05 PM   #39
MrMyth
Fan#: 106845
What I Drive: 2013 Performance Blue Focus
Points 21, Level 1
Points: 21, Level: 1 Points: 21, Level: 1 Points: 21, Level: 1
Level Up 41% Completed
FF Reputation: 2 MrMyth Good Standing Member
My 2013 Titanium came with 3.5.1 and I have had it for almost a week now. Only one reboot, everything else works perfectly.....except the album art is too small and upside down. If I hit the More Info button all is displayed correctly. Weird.
MrMyth is offline
Old 11-30-2012, 09:10 PM   #40
Just Tom
Fan#: 106663
What I Drive: 2013 Focus Ti (5 Dr.)
Points 1,206, Level 19
Points: 1,206, Level: 19 Points: 1,206, Level: 19 Points: 1,206, Level: 19
Level Up 6% Completed
Forum Activity 6%
FF Reputation: 3 Just Tom Good Standing Member
Originally Posted by I Bleed Ford Blue View Post
I thought I could start a thread specific for MFT 3.5.1 so anyone could report any bugs or glitches they find. Then ford could use the information to improve MFT on the next update.
Please try to keep it clean and no ranting or raving (you catch more flies with honey than vinegar) and keep it 3.5.1. specific, if you want to get 351 there is another thread for that.
I'll start, dealer installed 3.5.1 on 11-20-12 and so far all is well.
I checked my MFD and it said I have ver. 3.34.4 So it looks as though I need the update.
Just Tom is offline
