Michigan people - Page 9381 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > Great Lakes Fanatics
Great Lakes Fanatics Serving the Illinois, Indiana, Michigan, Minnesota, Ohio and Wisconsin regions.
Old 11-29-2012, 10:19 AM   #93801
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '87 Jetta GL, '82 Benz 300TD
Points 22,298, Level 92
Points: 22,298, Level: 92 Points: 22,298, Level: 92 Points: 22,298, Level: 92
Level Up 95% Completed
FF Reputation: 9 Timmeh! Good Standing Member
Klod we should set the "Max" accel at about what a 200 or 225ish pound guy could manage. Maybe more. Just don't give the featherweights such a big advantage. I can design the motor controller. I worked in power electronics.
Sent from my DROID2 using FF Mobile
Otto - 82 Benz Turbo Diesel Wagon - cruiser
Mitzi - 87 VW Jetta - low n slow
CATIA is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Timmeh! is offline
Old 11-29-2012, 10:31 AM   #93802
Aku
Sneeze
Aku's Avatar
Fan#: 57726
What I Drive: 04 A4 Avant, 04 R32T, 94 CBR
Points 10,207, Level 67
Points: 10,207, Level: 67 Points: 10,207, Level: 67 Points: 10,207, Level: 67
Level Up 40% Completed
Forum Activity 7%
FF Reputation: 4 Aku Good Standing Member
So we are wanting like a presssure sensor in the seat to sense the occupant weight and adjust the power output accordingly?
I dig it
'04 Audi A4 Avant 1.8T 6MT
'04 VW R32 - (O:o)=R32=W====(o:O)
'94 Honda CBR600 F2
Aku is offline
Old 11-29-2012, 10:33 AM   #93803
beat3rfocus
aint no shame
Fan#: 3178
What I Drive: Red 1990 Miata Hardtop
Points 15,249, Level 79
Points: 15,249, Level: 79 Points: 15,249, Level: 79 Points: 15,249, Level: 79
Level Up 80% Completed
FF Reputation: 11 beat3rfocus Great Standing Member
Buy-Sell-Trade Rating: (9)
I dig it
Could prolly modify one of the airbag off sensors in the passenger seat to do this function.
I sold my focus after 9 years.
beat3rfocus is offline
Old 11-29-2012, 10:36 AM   #93804
klodkrawler05
Sooooooooooo EURO
klodkrawler05's Avatar
Fan#: 47771
What I Drive: BMW's
Points 12,705, Level 73
Points: 12,705, Level: 73 Points: 12,705, Level: 73 Points: 12,705, Level: 73
Level Up 64% Completed
Forum Activity 9%
FF Reputation: 26 klodkrawler05 Great Standing Member
Buy-Sell-Trade Rating: (30)
well I was thinking more about in terms of fat guys are slow.
so say that max accel for a 140lb guy in a 9hp gasser kart is 100ft/min
with a 200lb guy that drops to maybe 90ft/min
so if you have 20hp electric karts they could have a theoretical max hp of 200ft/min for a 140lb guy and 180ft/min for a 200lb guy
so (if its possible) have a live updating speed sensor.
that way you can set the karts to have an artificial max acceleration of 100ft/min regardless of whose in the kart.
for a 140lb featherweight that might require 65% of max power for a 200lb guy that may require 70% of max power. if the kart is actively monitoring the change in wheel speed aka accel (and also max RPM?) you could then have the kart setup to supply whatever power is required to acheive max accel of 100ft/min regardless of whose driving with a max RPM of whatever you want it to be to limit the karts to say 45 mph. that way as batteries start to loose their charge etc the kart would be able to adjust to its conditions to continue supplying that accel/max mph that you've programmed it for until the batteries are no longer able to keep up.
li-po's would help prevent battery drop off but add cost (still potentially worth using though)
as another advantage and as a way to promote return customers you could have the karts have a 3 position switch:
Position 1: normal k2k type speeds
Position 2: advanced speeds for drivers who've completed more than X number of races at the track.
Position 3: "super kart" mode. for drivers with XX amount of races under their belt at the track, max power or at least say 90% of max power (so that the kart can match 140lb kart driver max speeds to 220lb kart driver max speeds)
they'd likely have wheel spin etc and would be the true drivers challenge but we're talking 55-70mph speeds assuming the karts can hook up.
-Brad
'03 VW Jetta TDI - The Daily Commuter
'02 Chevy Corvette Z06 - The Toy
'99 Triumph Daytona - Death Machine
klodkrawler05 is online now
Old 11-29-2012, 10:38 AM   #93805
Aku
Sneeze
Aku's Avatar
Fan#: 57726
Forum Activity 7%
Have you seen what those look like?
They are big plastic mats filled with a liquid of some sort and that runs al ong a tube down to a little ecu modual with a connector. If we know the coding that companies used to do all the calculations and crap I'm sure its possible but seems like a bit of work.
'94 Honda CBR600 F2
Aku is offline
Old 11-29-2012, 10:38 AM   #93806
klodkrawler05
Sooooooooooo EURO
Fan#: 47771
What I Drive: BMW's
Forum Activity 9%
I dig it
Could be a simpler way to go but I was thinking more of an accelerometer/wheel speed sensor.
type thing to live update and adjust max deliverable power. that way in addition to accounting for different weight drivers it would also be able to account for batteries starting to die off etc.
-Brad
Old 11-29-2012, 10:39 AM   #93807
kylesvt720
NeedsMoarEverything
kylesvt720's Avatar
Fan#: 51359
What I Drive: 2006 Saabaru "The Unicorn"
Points 10,926, Level 69
Points: 10,926, Level: 69 Points: 10,926, Level: 69 Points: 10,926, Level: 69
Level Up 19% Completed
Forum Activity 17%
FF Reputation: 17 kylesvt720 Great Standing Member
Seems like it would be easier to have an input for weight into the onboard computer to limit power. You then way each driver before the race starts, in full race gear with helmet, and enter that weight on their car. It then sets their power output.
Jeremy Clarkson on Detroit: “God may have created the world in six days, but while he was resting on the seventh, Beelzebub popped up and did this place.”
ST CREW #107 / TEAM DURATEC #93 / D23 Crew #3
kylesvt720 is online now
Old 11-29-2012, 10:46 AM   #93808
Aku
Sneeze
Aku's Avatar
Fan#: 57726
Forum Activity 7%
This is what I was thinking except just have it so when the person sits in the kart is auto does that itself. But having a scale to weight people would work as well to just input the data in via a computer or some thing. Since most Kart places already have radio controlled governers for the cool down lap and for slowing people down who are driving stupid so they can yell at them.
Also this. Rules for Klod and his future.
'94 Honda CBR600 F2
Aku is offline
Old 11-29-2012, 10:51 AM   #93809
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
Just wheel speed sensor would be easiest. Set the max accel to 10hp and a 250 lb load or whatever... that way guys heavier than that go faster, but the lighter guys don't gain anymore advantage (besides the inertia advantage)
Its definitely possible. You'd be amazed what you can do with this stuff. I once wrote a variable frequency drive for an ac motor completely in software... 1000hz control. And we could do it much faster with a modern micro.
Timmeh! is offline
Old 11-29-2012, 10:58 AM   #93810
egman2005
Slow n lifted
egman2005's Avatar
Fan#: 44983
What I Drive: 2003 SVT Focus
Points 9,661, Level 66
Points: 9,661, Level: 66 Points: 9,661, Level: 66 Points: 9,661, Level: 66
Level Up 3% Completed
FF Reputation: 21 egman2005 Great Standing Member
Buy-Sell-Trade Rating: (7)
Do it.....
Originally Posted by I <3 my ZX3 View Post
ed is right.
egman2005 is online now
Tags
aku & oberon , ff men cursed , hide yo kids , hide yo wife , in before the lock , kyle is troll king , mi euro-trash thread , toots was here
