Old 11-28-2012, 05:51 PM   #21
mrpeaches
Fan#: 103895
What I Drive: 2012 White Focus SE Hatchback
FF Reputation: 1 mrpeaches Good Standing Member
Honestly, I think that this is much more trouble than it is worth. The stock wiring should be just fine for your purposes unless you are running some insane amount of power to the speakers. For all normal purposes, you should be just fine using the stock wire to run to your speakers in the doors.
mrpeaches is offline
Old 11-28-2012, 06:06 PM   #22
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
Well by my calculations the factory wire (18 or 20 gauge) could handle approx 50 watts. I will be pushing 95 watts rms per side. It would be a lot easier to use the factory wiring, can you confirm that it can handle 95 watts rms? I am nervous it cannot.
Besbro is offline
Old 11-28-2012, 06:44 PM   #23
mrpeaches
Fan#: 103895
I'm pushing close to that with my amp and speakers and it's just fine on the stock wire. Go ahead and run new wire if you want, but I don't think there should be much of an issue.
Old 11-28-2012, 07:37 PM   #24
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2002 ZX3
FF Reputation: 18 freemind Great Standing Member
Buy-Sell-Trade Rating: (16)
Use this calculator, http://www.bcae1.com/wire.htm
You are fine if you use 12ga from the amp to the front of the car and into the OEM speaker wire.
133whp-126ftlbsTQ Eclipse CD8443,JBL Px300.4, JBL GTO7001, PPI 356cs, JBL p1022 in .95 cubes, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-28-2012, 08:13 PM   #25
Besbro
Besbro's Avatar
Fan#: 102785
Using this calculator, i punch in 95 for power output per channel, Speaker wire length 3, speaker wire gauge 18 and Load Impedance 2 (as my speakers a 2 ohms) and I hit enter. On the bottom is says " The wire is too small to meet the 300 circular mils per amp of electrical current standard."
Am I doing something wrong?
Besbro is offline
Old 11-28-2012, 09:35 PM   #26
freemind
freemind's Avatar
Fan#: 67513
No, I ran it at 16ga.
At this point it is totally up to you.
If you do drill it, post up pics and write a tutorial. You get Rep points for that kind of stuff.
Hatch Nation #140
freemind is offline
Old 11-29-2012, 02:44 PM   #27
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
i personaly think 50 watts would be pushing stock 18 gauge wire. 16 gauge can be pushed to 100-150 and some people use 12 gauge for sub with amps that put out thousands of watts but those are short run and i would still use 8gauge for subs running anything over 1k.
hn155:rockford stereo, will have 2 t215's 2 punch pro tweets 2pro 6.5mids, t400.4 t1500.1bdcp.
perfomance build to come, lentach tranny, engine build for 250hp, turbo.
alaskanzx5 is offline
Old 11-29-2012, 07:48 PM   #28
Besbro
Besbro's Avatar
Fan#: 102785
I will attempt to run this wire (and install my system) this Sat. I will take pics and document my progress, be it good or bad....
Thanks for all the help!!!
P.S. How do you give rep points?
Besbro is offline
Old 11-29-2012, 09:17 PM   #29
freemind
freemind's Avatar
Fan#: 67513
By clicking on the clicking on the blue number next to "FF Reputation:" in the Avater box.
Hatch Nation #140
freemind is offline
Old 11-29-2012, 10:53 PM   #30
mitchv
Fan#: 79720
What I Drive: 2003 blue zx3
Stock wiring and anything over head unit power scares me. You could run your 12 gauge speaker wire from the amplifier right up to the door jam, tap into the factory wiring, then on the otherside inside the door tap into the factory wiring and run your 12 gauge into the speaker. That way your run of wire would consist mostly of 12 gauge and only a couple inches of stock factory wiring. That would be safe to run 95wpc on and that way you dont have to drill into a brand new 2012.
mitchv is offline
