Problems after installing doms rear lca's - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2012, 09:23 AM   #1
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
The car seems to sit a bit higher with the perches all the way down, and also after a quick test drive felt like the rear was wobbly as hell. I gave a look (knowing the alignment was off obviously changing then out) but then actual rear tires are pointed inward as well as the rear of the the rear tires (hope i dont confuse) being pointed outward.) I have adjustable toe links I am installing tomorrow, and was wondering if an alignment would straighten on the tires to run straight, not pointed inward in the rear as they are now. The steering wheel does need to be held at a slight angle at certain speeds to drive straight.
Thanks
Sent from my SGH-I717 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
Old 11-28-2012, 09:34 AM   #2
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,179, Level 67
Points: 10,179, Level: 67 Points: 10,179, Level: 67 Points: 10,179, Level: 67
Level Up 33% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
if you have adjustable lower control arms AND adjustable toe arms, they will be able to properly align the car and get the tires to run straight.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 11-28-2012, 10:00 AM   #3
1hotfocus
1hotfocus's Avatar
Fan#: 82813
Picture added. Can an alignment really align them so?
Old 11-28-2012, 10:04 AM   #4
doubles
doubles's Avatar
Fan#: 106022
What I Drive: 2008 ford focus
FF Reputation: 1 doubles Good Standing Member
a 4 point alignment will fix this problem as my 2000 did the same thing on rear wheels they were leaning in at top and out at bottom took it in for a 4 point alignment and problem solved
doubles is offline
Old 11-28-2012, 10:17 AM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,031, Level 74
Points: 13,031, Level: 74 Points: 13,031, Level: 74 Points: 13,031, Level: 74
Level Up 46% Completed
Any time you put the suspension apart you need to do a alignment. Before you add the toe-links make sure you add boots to them to protect the heim joints from dirt/dust & do not grease or oil them up. Then the tech will adjust your camber & then the toe on the rear first & then adjust the toe on the front after doing the rear, w/ getting the s/w straight. As far as the rear height & the spring perchs all the way down, the only thing left is to run shorter springs. I've seen where the springs perchs are set a few inches from the bottom & the car was sitting pretty low. Be interested in where he figured the height of the perches compared to the stock arms. Did you get a chance to compare his arms & the stock ones side by side? Just looking in pix the stock arms have pretty low spring pockets.
felixthecat is offline
Old 01-12-2014, 09:34 PM   #6
J0EC00L
J0EC00L's Avatar
Fan#: 86480
What I Drive: 2001 Ford Focus
Points 4,719, Level 43
Points: 4,719, Level: 43 Points: 4,719, Level: 43 Points: 4,719, Level: 43
Level Up 85% Completed
FF Reputation: 1 J0EC00L Good Standing Member
I just finished putting on Doms rear LCA today and my car went from being tight as a virgin to all over the place in the rear. I already had his Toe and Camber arms on as well as rear brace.
I am hoping its just an alignment issue with the weeble wobble rear. Will find out soon.
Did yours get right after the alignment 1hotfocus?
Peace.
Joe
J0EC00L is offline
