PTS Remote start from OEM Fob - Page 4 - Focus Fanatics
Old 11-27-2012, 06:02 PM   #31
SaToX
Fan#: 94321
Originally Posted by Samuel Kadolph View Post
I've been looking at getting a remote started for my 2012 titanium and it would be cool to avoid the extra fob.
What's the difference between ADS and DBI? Is it hard to access the module behind the glovebox and do you think anyone can install it (I have quite a bit soldering experience but not on cars)?
DBI and ADS are protocols that allows the bypass module (al ca) to talk to remote car starters such as viper with a data cable. For instance it will tell the Starter that the brake has been pressed or that the door or hood is open without physically hooking up wires between the two units.
SaToX is offline
Old 11-27-2012, 06:10 PM   #32
SaToX
Fan#: 94321
Since I'm not sure how to edit the original post as edit button isn't showing up on it. I decided to make a new video showing the remote start. If i get a chance this week I will remove the glove box and show all the connections to help anyone out with the Install.
YouTube Video
SaToX is offline
Old 11-27-2012, 07:09 PM   #33
Samuel Kadolph
Fan#: 99215
What I Drive: 2012 Grey Focus HB Titanium
FF Reputation: 1 Samuel Kadolph Good Standing Member
How do you know which one you need? The idatalink website says both are compatible with the 2012 Titanium Hatchback. Does that mean it doesn't matter?
A video that shows where all the wires are to splice would be awesome.
Samuel Kadolph is offline
Old 11-27-2012, 07:11 PM   #34
SaToX
Fan#: 94321
It's the same box, just depends on which protocol you flash to it. If im not mistaken you pick DBI, but I will have to plug mine back in to confirm this 100%
SaToX is offline
Old 11-27-2012, 08:43 PM   #35
Darth_Focus
Fan#: 104539
What I Drive: 2012,Tuxedo Black, Titanium
FF Reputation: 1 Darth_Focus Good Standing Member
Does this system keep all the security functions the factory had intended intact? This isn't like taping a key to the bottom of the steering column to cheat the system is it?
Darth_Focus is offline
Old 11-28-2012, 10:26 AM   #36
SaToX
Fan#: 94321
No not at all, and yes it does keep the all the factory security in place.
SaToX is offline
Old 12-04-2012, 08:16 AM   #37
moocows42
Fan#: 101732
What I Drive: 2012 Tuxedo Black Titanium
FF Reputation: 17 moocows42 Great Standing Member
Are you still planning on doing this? I have all the parts and am planning to install it this weekend.
moocows42 is offline
Old 12-04-2012, 08:18 AM   #38
moocows42
Fan#: 101732
When flashing the module it said to use DBI if you intend to use the OEM remote.
Old 12-04-2012, 09:43 AM   #39
SaToX
Fan#: 94321
yes I am sorry I've been slammed at work. lf everything goes well I'll have about an hour and half tonight to do it.
SaToX is offline
Old 12-05-2012, 11:44 AM   #40
Michael Jackson
Michael Jackson's Avatar
Fan#: 104370
What I Drive: 2013 Tuxedo Black Hatchback
FF Reputation: 1 Michael Jackson Good Standing Member
Hey, this is a bit off topic, but just wondering if you could help me out. I currently have a manual 2013 focus that I've wired using the diagram from ads and flashed my al-ca with the FM4 firmware. I have the standard 80-bit key, and I've installed a proper manual remote starter from Solace, since I do not believe the OEM fob is capable of starting the car with a manual transmission. The firmware for the idatalink has been flashed appropriately.
Immediately after the car is put into reservation mode, I can restart it with the remote start with no issues. If a couple hours passes, or the car sits overnight, it will attempt to start, but will not crank the starter, although I can hear the relay click on the remote start, almost as if the clutch bypass has failed. After that, I get 7 flashes from the parking lights indicating a failed remote start attempt. I have a hard time believing that it is clutch related since it will start sometimes when I have put it in reservation mode.
I haven't torn into it too far, but the idatalink is currently hardwired with my Solace, mostly for peace of mind that it wasn't a 2 way data communication issue causing this problem. Thus far, ADS has told me I need to wire my own door pin for the remote starter, and that is what is causing the issue, and a second opinion has netted me these two documents:
https://www.box.com/s/bp50iedeb5dczunscx7s
I guess I feel bad kinda hijacking your thread asking for free advice, but I used to install remote starters a few years ago, and I guess I'd like a third opinion from someone I know to have experience installing on these cars before I go crazy and start cutting my factory harness up to get this done. My current thoughts are that this has something to do with the BCM going into a standby mode. Honestly, I feel like an idiot, but I'm lost.
Any help would be greatly appreciated!
Michael Jackson is offline
