2010 focus air in lines after brake job - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2012, 02:04 PM   #1
ghostrider_14
Fan#: 60668
What I Drive: 2013 corolla s/2005 black zxw
FF Reputation: 1 ghostrider_14 Good Standing Member
Hey guys just had a rotor and caliper replaced on my 10 ses and we can not get the brakes to pump back up. There looks to be air in the lines still after bleeding that side but their aew no visible leaks or anything. Is there a special way that these brakes need to be bleed? Thanks. Eric
ghostrider_14 is offline
Old 11-27-2012, 02:35 PM   #2
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
You should bleed each wheel Because you took off a brake line. Start with the rear passenger side them rear driver side next the front passenger side last the driver front. be sure not to let the master cylinder go to low I try not to let it get lower than half full.
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
Old 11-27-2012, 02:44 PM   #3
Geezer
Fan#: 1427
GO.army is correct, you need to bleed all four corners not just the one you worked on.
Geezer is offline
Old 11-27-2012, 05:13 PM   #4
ghostrider_14
Fan#: 60668
Bleed all at brakes and still nothing no pressure at all and the car is pulling to one side when I apply the brakes.
Old 11-27-2012, 06:26 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
When you replaced the rotor & caliper on one side, Did you replace the pads on the other side? Seems like you start over w/ the bleeding process, yeh it is a hassel, but you got to do it. Somethings in life are hassel's but you have to deal w/ it.
felixthecat is offline
Old 11-27-2012, 07:03 PM   #6
ghostrider_14
Fan#: 60668
everything has been bleed but still no pressure i mean i have a little bit of breaks but it pulls like crazy.
Old 11-27-2012, 07:21 PM   #7
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Then I'd start w/ bleeding the master cylinder then. Does brake fluild come out when you open up the bleeder screw?
Old 11-27-2012, 07:27 PM   #8
ghostrider_14
Fan#: 60668
yep fluid and air still comes out.
Old 11-28-2012, 12:06 AM   #9
jburkey28
Fan#: 105295
What I Drive: 2009 Cobalt SS/TC
FF Reputation: 1 jburkey28 Good Standing Member
Cool
Keep bleeding then, lol.
Start at the back and work forward
jburkey28 is offline
Old 11-28-2012, 12:54 AM   #10
Geezer
Fan#: 1427
How much new fluid have you used? An average bleed uses 12 to 16 oz. If you haven't used that much bleed again.
Since a caliper was replaced double check all hose connections for tightness, kinking, etc. I'm assuming the new caliper is functioning properly (no leaks in piston seals and internal fluid passages are unobstructed). If this is the case, the problem may be the actual bleeding procedure and potential mistakes. What bleeding process are you using?
Geezer is offline
