170 to 200hp hp goal - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2012, 07:01 PM   #61
streetfocus
streetfocus's Avatar
Fan#: 5768
What I Drive: 2004 Black Focus SVT
Points 2,551, Level 30
Points: 2,551, Level: 30 Points: 2,551, Level: 30 Points: 2,551, Level: 30
Level Up 68% Completed
FF Reputation: 2 streetfocus Good Standing Member
If the 2.5L was a direct swap, that would be sick.
05 ZX3: Steeda intake, 67mm TB, custom 2.5 Magnaflow exhaust, Tom's Tune.
New: 04 SVT : K&N panel filter, 3 performance motor mounts, Taylor wires, orp, 67mm TB, Tom's Tune.
streetfocus is offline
Old 11-27-2012, 07:33 PM   #62
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,831, Level 76
Points: 13,831, Level: 76 Points: 13,831, Level: 76 Points: 13,831, Level: 76
Level Up 46% Completed
Forum Activity 100%
Why wouldn't it be? You can get a 25 in a Mazda 3.
felixthecat is offline
Old 01-04-2013, 04:14 PM   #63
HAPPYHANDS
Fan#: 66793
What I Drive: 2005 silver zx3 5-speed
FF Reputation: 2 HAPPYHANDS Good Standing Member
I made 164.6whp and 136wtq on my 2.0. Bolt ons are "Ebay IM" F2 header and exhaust with Fswerks CAI. I rev. up to 7200 with stock internals. I have 168,00 mile on the motor and no issues. I know this thread is a couple of days old but thought you might want to see some actual dyno numbers. My tune is from Redline performance here in NC. Hope this helps.
MAXTON MILE AT 129mph!
HAPPYHANDS is offline
Old 01-04-2013, 04:20 PM   #64
HAPPYHANDS
Fan#: 66793
http://www.focusfanatics.com/forum/p...pictureid=6125
Old 01-04-2013, 05:34 PM   #65
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Just think what a set of cams could do for you?
Old 01-04-2013, 08:45 PM   #66
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
Points 32,503, Level 100
Points: 32,503, Level: 100 Points: 32,503, Level: 100 Points: 32,503, Level: 100
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by turbosvtfocus04 View Post
Smaller turbos will result in more torque, bigger turbos not as much. We will take a dodge srt4 for an example, makes 310whp 454wtq. But as soon as you go bigger turbo and add cams torque isn't as high, 420whp 380wtq. Rpms got pushed up bc of the slightly bigger cams which is a result in torque loss, you can also lose low end torque by switching intake manifolds as well.
And as for you to say 2.3 turbo could make more power, till you hit a certain amount of hp or big enough turbo then the 2.0 will make more due to it being able to rev higher and also bigger strong since the piston pin isn't moved up on the piston. And yes I have seen this happen when stroking a motor where the piston pin was too high on a motor with a turbo.
I'm not sure if he understands that horsepower is just a function of torque. If torque is constant then the only way to get more HP is to rev higher. If torque is not constant but large at the beginning and tapers off then the HP will raise and plateau. If the torque starts low and then jumps at the upper ranges then you have no HP at all until the torque jump which at that point becomes ridiculous.
I imagine the second SRT example was due to the cams having more overlap. A small turbo will spool quickly and run out of breath. A large one will take forever to spool and then become a monster.
An ideal NA motor has a flat torque curve which will yield a perfectly diagonal HP curve up to redline, i.e. a rotory.
Interesting debate but how much have we helped the OP?
173.4whp
gump
crew #6
warneej is online now
Old 01-04-2013, 08:54 PM   #67
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Originally Posted by w2s2008 View Post
I have a dyno at where i went to school and am guna go get a base line run in but ibwana see somewhere between 170 n 200 at the wheels. I have a steeda intake but everything eles is stock i drive tbis car daily and want to keep it that way. 93 octain is avalible n thats the only limiting factor i have im none emissions where i live so cats are option ;) ive built more mustangs the i care to admit n decided to go a with the focus this time. Forced induction isnt outa the picture but i dnt wana go over 8psi. So im looking for ideas i wana get a build sheet done n get at it. Stock trans okay i have a 5 speed also axle options exhaust i dnt wana have an overly loud car but i would like a nice hey here i am but not holy s what was that lol. Intake manifolds heads cams looking for direction
Originally Posted by felixthecat View Post
Fwerk's turbo kit will get you there no problem. For a N/A car as you know theres no replacement for displacement= Get a 23 motor to start with= longer stroke for more grunt, the head flows a lot better. Add a set of cams, fwerk's header w/ Fwerk's stealth system, cossie intake or do a sheet metal intake, CFM's TB, of course a 91-93 octane tune w/ rear o2 senser & egr delete. For more mods= forged pistons/ rods/ ranger crank & SS 1 piece valve's. Add a Torsen & CFM's tubular control arm's to help get the power down.
They you go!
Old 01-04-2013, 10:19 PM   #68
streetfocus
Fan#: 5768
Hey HAPPYHANDS, have you ever run that setup at the track? How is it on the street? Lose the low end with the IM? Any suggestions?
Old 01-05-2013, 08:33 PM   #69
HAPPYHANDS
Fan#: 66793
Only quarter and eigth and mile. In the 1/4 it did 15.1 at 93. In the standing mile it does 130mph. I get 31mpg. That's city and hwy. I live in the mountains. Got 34mpg when I visited fl. I lost 13wtq I've I remember right. And gained 14whp . The car got faster in the standing mile. I gained 3 more mph.
Old 01-05-2013, 08:37 PM   #70
HAPPYHANDS
Fan#: 66793
I would get the 2.3 motor. I miss my tq. But do love making power up top.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
