Running 12GA speaker wire into the doors ??? - Focus Fanatics
Old 11-25-2012, 08:24 PM   #1
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
Hello,
Today I attempted to install my new ID CXS65 components into my 2012 Focus. I had read on this forum that it is very difficult to run speaker wire into the doors due to the mylex connection on the factory boot between the door and body so I was planning on drilling new holes, using grommets and running the wire through the new holes. Once I looked under the steering wheel by the hood release lever, I do not see how this is possible... How do you get to the inside of the door jamb? There is a peice of metal that all the insulation is attached to under there and that is approx 8" from the inside of the door jamb! I beleive a forum member named Storis has done this on his Focus. Can someone please tell me what I am missing? I am also adding an amp so I really do not want to use the thin factory wire... Help Please!!!!! (Hopefully I am explaining my problem good enough) I need to know how to get the speaker wire into the door...
Besbro is offline
Old 11-25-2012, 09:09 PM   #2
dbenney
Fan#: 1195
you need to check that area out good. The A pillar area has 2 parts, the outter part (what you see outside) and the inner part (that you see when you remove the kick panels). The inner part is NOT solid and has holes in it that would make it possible to feed a wire through, you just need to find the holes.
dbenney is online now
Old 11-25-2012, 09:52 PM   #3
Besbro
Besbro's Avatar
Fan#: 102785
Thanks! Are the holes up high? Do you need to take apart the dash to access them or are they low by the hood release?
Besbro is offline
Old 11-25-2012, 11:14 PM   #4
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
I could help alot more if you drove an mk1 lol
Rally Revolution #43
[HOONIGAN]
calebstubstad is offline
Old 11-26-2012, 12:11 AM   #5
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
FF Reputation: 21 freemind Great Standing Member
Buy-Sell-Trade Rating: (20)
If you are very careful, you can either remove the whole door and drill it or, release the locking rod. Then have someone hold the door while you drill the hole.
This all being said, how much power are you gonna run to them?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 11-26-2012, 08:02 AM   #6
Besbro
Besbro's Avatar
Fan#: 102785
I'm running 95 watts @ 2 ohms. Arc audio FD2100 amp.
Besbro is offline
Old 11-26-2012, 08:47 AM   #7
freemind
freemind's Avatar
Fan#: 67513
The OEM speaker wire will carry 95wpc no problem. But, it is up to you. You will have to go through the molex if you want the 12ga.
Nice comps man. Woofers inc. deal?
Hatch Nation #140
Old 11-26-2012, 09:35 AM   #8
Besbro
Besbro's Avatar
Fan#: 102785
Yes, Woofersetc deal. Thanks!
If I can use the factory wire that solves my problem!
Besbro is offline
Old 11-26-2012, 11:49 AM   #9
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
i was about to suggest 16gauge. would be easier to run and would handle the power fine.
alaskanzx5 is offline
Old 11-26-2012, 12:42 PM   #10
Besbro
Besbro's Avatar
Fan#: 102785
Does anyone know what the factory wire is? 16 or 18 gauge?
Besbro is offline
