Front End Clunking - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-25-2012, 07:56 PM   #1
vermen1993
vermen1993's Avatar
Fan#: 79408
What I Drive: 1995 MKIII Jetta GLX (VR6)
FF Reputation: 1 vermen1993 Good Standing Member
Front End Clunking
I searched around and found a couple useful links as to what this might be, but they didn't give any descriptions. Something in my suspension is going and I'd rather fix it now, when it's still above freezing (barely). When I drive over any sort of bump in the road or when I pull into a driveway etc, my front end makes a sound that's sort of like metal on metal, hard to describe. From what I searched, I saw that there was the possibility of both my sway bar and my bushings. I laid next to the car and had my brother push down on the front end to hear where it was coming from and it seemed to be coming from right under the front sub frame. If the sway bar is not centered anymore, how would I go about a) seeing that, and b) re-centering it. Any other ideas on what it could be would also be useful. Thanks!
Stefan
2003 Focus LX Red (RIP)
2002 Focus SE Red (SOLD)
1995 Jetta GLX: VR6, Intake, Exhaust, Lowered, 5-speed, you get the idea.
vermen1993 is offline
Old 11-25-2012, 08:03 PM   #2
1hotfocus
1hotfocus's Avatar
Fan#: 82813
What I Drive: 00' sedan
FF Reputation: 7 1hotfocus Good Standing Member
Buy-Sell-Trade Rating: (21)
First of all, I doubt its the bar being off centered or even the bushings. I'd check the sway bar end links that go bad after 60k or so and being lowered makes them wear faster. Replace those and see if the noise goes away. If it doesn't, check your strut bar upper mounts. Make sure the lock nut is super tight. Again, if you've changed your struts/ shocks and reused them or even not tightening them enough (most think they are but aren't) will make noise. If its neither of those then I'd check the bar being off centered, but unless you hit something crazy then I highly doubt the bars off centered. Good luck. Also mileage? Have you changed out any suspension things before? If so, what? More info will help!
Sent from my SGH-I717 using FF Mobile
Give rep if youve been helped :)
1hotfocus is offline
Old 11-25-2012, 08:12 PM   #3
vermen1993
vermen1993's Avatar
Fan#: 79408
I replaced all of my shocks/ springs 5k miles ago with Koni shocks, and the tie rods/ end links about 22k miles ago with Moog adjustable ones. The reason I would think it's a bushing or off-centered sway bar is the fact that it's coming from under the sub frame.
Old 11-25-2012, 08:32 PM   #4
standard
standard's Avatar
Fan#: 72671
What I Drive: wrx
FF Reputation: 2 standard Good Standing Member
No doubt in my mind it's your sway-bar endlinks. Replace them as they cost like $50 and move on. If you replaced your shocks/springs with Koni, you likely lowered. Just accept that swaybar links are part of maintenance now, as a trade of to being lowered.
'02 WRB Subaru WRX
standard is offline
Old 11-26-2012, 12:00 AM   #5
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
Make sure the end-links are tightened down completely, ask me how I know they could be really annoyingly loud if not.
I always moderate naked!
bringler26 is offline
Old 11-26-2012, 07:39 AM   #6
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,474, Level 100
Points: 57,474, Level: 100 Points: 57,474, Level: 100 Points: 57,474, Level: 100
Forum Activity 17%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
If it's not the sway bar end links, my guess is that you probably have worn out lower control arms: that's what the noise turned out to be on my car. Have you tried picking the front wheels off the ground yet? Jack up the front of the car and see if you get any movement from the front wheels. If so, something is definitely worn out somewhere and you should be able to look underneath and see what's moving.
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is online now
Old 12-18-2012, 12:06 PM   #7
Focuselmo03
Fan#: 107442
What I Drive: 2003 dark blue zx3
FF Reputation: 1 Focuselmo03 Good Standing Member
Hello all,
I'm new here I have a small thud sound maybe something's is loose or broken?
I'm thinking strut, I only hear it when I go over speed bumps
My focus is 2003 zx3 201000 miles runs awesome! Never any issues and always taken care of this car! now this thud sound showed up a few days ago (please help me find this issue)
Have a great week to all
Focuselmo03 is offline
Old 12-22-2012, 05:40 PM   #8
vermen1993
vermen1993's Avatar
Fan#: 79408
I had the same problem above and it ended up being end links. Bring it to a shop and tell them they're loose and they'll tighten them down for you for cheap.
Sent from Stefan 's Phone
