How to remove radio and surrounding trim pieces - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
Old 09-30-2012, 11:17 AM   #1
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 9 Chickenmuffn Good Standing Member
This is done on a right hand drive UK Focus. The process should be more or less the same, just take into account that some things may be flipped to the other side.
So below are the pieces that I'll show how to remove, labelled in order.
I started by removing the whole radio unit. This is really easy and takes about 20 seconds. Above the temperature control is a small piece that is easily removed with pliers. Behind this piece are 2 screws. Unscrew them and the whole radio unit can be pulled up and away from the car. Disconnect the harness behind the unit.
1.) Vent Trim Panels
These are attached to the radio unit, and can be popped off by simply pulling/prying from the bottom (label with an arrow above) moving upwards. If you come across a stubborn clip, get a flathead screw driver, get it between the radio unit and trim piece and push the clip inwards towards the vent opening.
2.) A/C Control Panel
There are 3 screws (indicated below). To access the side screw you will need to slightly pry the adjacent trim panel away. Once undone the panel can be wiggled out, disconnect the harnesses behind the panel and pull out of the console.
Behind the A/C control panel there are 4 screws (indicated) that will detach the knobs. The 2 sets of buttons below the knobs (also indicated) are removed by squeezing tabs on the backside.
3.) Shifter panel
To remove visit this how to, courtesy of Twenty
http://www.focusfanatics.com/forum/showthread.php?t=273852
So this is what your radio area would look like with everything removed. Circles indicate the radio screws, squares the A/C control panel screws
4.) Parking break piece
For this I just pryed the with a flathead on the side, near the bottom end. It popped out quite easily. I recommend not using too much force here, as it is not needed.
5.) Door trim
You must start prying at the front end (indicated by an arrow). Just because of how it sits in the door. The rear end is inserted into the door at an angle which prevents it from being pryed.
Enjoy! Feel free to ask questions.
Chickenmuffn is offline
Old 09-30-2012, 09:25 PM   #2
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
FF Reputation: 9 Twenty Good Standing Member
Certainly looks easier than expected, thank you! I'll add one to your rep for this.
officialTHREETWENTY
2012 Yellow Blaze Focus SE Sedan (DD+Project)
1992 Bright White Grand Prix SE Sedan (Project)
SR #74/SMk3C #17/YBOC #03
Bill M.
Twenty is offline
Old 10-06-2012, 04:53 PM   #3
MikeLondon
MikeLondon's Avatar
Fan#: 104572
What I Drive: 2012 White Focus
FF Reputation: 1 MikeLondon Good Standing Member
I'd like to say thanks for this fantastic how-to guide. I found it massively helpful when changing my radio/trim today.
Much obliged Sir!!
MikeLondon is offline
Old 10-06-2012, 05:14 PM   #4
Chickenmuffn
Fan#: 103458
Your welcome! Happy to help.
Old 10-06-2012, 09:44 PM   #5
dbenney
Fan#: 1195
that DiNoc is smooth looking stuff! excellent job bro! I used your guide to remove the ebrake silver piece to cover it with black DiNoc. if you hadnt written this up I would have prob jsut done it in place not knowing it was removable.
dbenney is offline
Old 10-08-2012, 04:51 PM   #6
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Looks good!
I'll be doing something very similar with
Sonic's Mk3 Crew #11
Hatch Nation#163
Watch out for the D
TiStick is offline
Old 10-16-2012, 06:35 AM   #7
focusonthefocus19
Fan#: 104272
What I Drive: 2002 yellow focus zx3
FF Reputation: 1 focusonthefocus19 Good Standing Member
Where can I get some of that wrap? Also, do they have yellow wrap?
focusonthefocus19 is offline
Old 11-24-2012, 03:00 PM   #8
manfromholland
manfromholland's Avatar
Fan#: 92863
What I Drive: 2012, white, focus 5d hatchback
FF Reputation: 1 manfromholland Good Standing Member
Foliencenter24
Albert Alt GmbH
Ortsstraße 12a
66571 Eppelborn
Telefon: (+49) 6881 5390 215
Fax: (+49) 6881 5390 216
They have we shop.
I have ordered 3m-dinoc in White to do my interior, great wrapp. Looks cool too
Manfromholland
European Focus 2012 White 5dr Titanium
manfromholland is offline
Old 11-24-2012, 08:46 PM   #9
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
Which wrap? Mine in the pic is actual CF
for vinyl, try metrorestyling.com
Hatch Nation#163
Watch out for the D
TiStick is offline
Old 02-07-2013, 09:57 AM   #10
felixdd
felixdd's Avatar
Fan#: 105655
What I Drive: 2013 Oxford White SE sports
FF Reputation: 1 felixdd Good Standing Member
How do you get that side trim out? Can't get it out with any amount of prying.
EDIT: nvm
felixdd is offline
