P0135 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-23-2012, 04:26 PM   #1
focusmachnone
focusmachnone's Avatar
Fan#: 92770
What I Drive: 2004 TS Silver 2.3 Duratec
Points 811, Level 15
Points: 811, Level: 15 Points: 811, Level: 15 Points: 811, Level: 15
Level Up 11% Completed
FF Reputation: 1 focusmachnone Good Standing Member
P0135
Anyone come across this before. I checked the fuse #18 under the hood and it is good. O2 sensors (there seem to be two bank ones) are new but that doesnt mean one cant be bad. Any thoughts by anyone or has anyone had this problem before?
focusmachnone is offline
Old 11-23-2012, 08:41 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,021, Level 74
Points: 13,021, Level: 74 Points: 13,021, Level: 74 Points: 13,021, Level: 74
Level Up 43% Completed
po135 is your upstream o2 senser not going to closed loop, or not going to closed loop fast enough. You put a new one in, ok Is to the right one? & right part?
felixthecat is online now
Old 11-24-2012, 08:35 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,876, Level 100
Points: 51,876, Level: 100 Points: 51,876, Level: 100 Points: 51,876, Level: 100
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
Any mods on the car , any Vac leaks , both these could cause your issue ???
Tom
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 11-24-2012, 09:48 AM   #4
focusmachnone
Fan#: 92770
Only mod on the car is CAI (AEM) and cat back exhaust stock diameter. Did find a broken hose on the runner and fixed it but car still a little jerky and running rich. So I just ordered two new upstream O2 sensors and will just replace both, clear codes and see what happens. Also checked the air straitener on the MAF tube and cleaned the MAF. Car has new coils, wires, plugs, and will have all new O2 sensors (again).
Old 11-24-2012, 04:49 PM   #5
focusmachnone
Fan#: 92770
Ok read codes again and this time no PO135, instead I have a 107 (barometric pressure sensor low), a 122 (TPS Circuit low) and a 190 (Fuel Rail Circuit something or ruther) Now these are all pending. Any thoughts. MAP sensor bad? Cleared codes again and keep getting a P0122. So I am thinking still could be the MAP sensor but also the TPS sensor. O2 sensors are fine and working. Bought a FC throttle body online and a new TPS will see if that fixes the problems, along with a new MAP and MAF sensor. The car has a butt load of miles on it 180K+ and I only spent like $750 buying it so it wont hurt to replace most of the important sensors anyway. When is the radiator fluid recommended to be replaced. I should probably do that too! And a new fuel filter.
By the way anyone know where the MAP sensor is located on the 2.3??
Old 12-06-2012, 12:13 PM   #6
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
Points 32,355, Level 100
Points: 32,355, Level: 100 Points: 32,355, Level: 100 Points: 32,355, Level: 100
FF Reputation: 201 warneej Excellent Standing Member warneej Excellent Standing Member warneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Its on the front of the intake manifold.
173.4whp
gump
crew #6
warneej is online now
Old 12-09-2012, 11:40 AM   #7
focusmachnone
Fan#: 92770
Thanks replaced O2s not throwing that code any more. Instead a butt load. look up thread called the code thrower.
Old 12-15-2012, 09:15 AM   #8
focusmachnone
Fan#: 92770
you can close this thread!
