How to lock fob in car - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-23-2012, 10:07 AM   #1
jeff_nc
Fan#: 106534
What I Drive: 2013 performance blue titanium
Points 701, Level 14
Points: 701, Level: 14 Points: 701, Level: 14 Points: 701, Level: 14
Level Up 1% Completed
FF Reputation: 1 jeff_nc Good Standing Member
Hi folks. I'm new here - just bought a 2013 Titanium hatch and still figuring it out. All in all, very happy with my new car.
I've know this was discussed before, but I've never seen a good answer. What I want to do is lock the fob inside the car and leave the emergency key in a magnetic holder somewhere on the undercarriage. That way I can canoe down the Colorado, trek the Himalayas, or go diving in Bimini without worrying my fob will be damaged, lost, or stolen.
I know I can lock it inside using the second fob, but that doesn't help me much. I could disable the fob by opening it. That works ok, but is kind of a hassle, because then when I unlock the car with the emergency key, I have to find and reassemble it really fast or the car alarm goes off. Plus, I'm afraid that the fob wasn't made to be opened and closed alot and might break.
I have tried wrapping the fob in aluminum foil, and this actually seems to work, but I'm worried that after time enough radio signal will leak out to open the doors.
Any other ideas?
jeff_nc is offline
Old 11-23-2012, 10:25 AM   #2
Faygo Focus
Faygo Focus's Avatar
Fan#: 85587
What I Drive: 2012 Tuxedo Ti with James Bond Pkg
Points 3,799, Level 38
Points: 3,799, Level: 38 Points: 3,799, Level: 38 Points: 3,799, Level: 38
Level Up 99% Completed
FF Reputation: 2 Faygo Focus Good Standing Member
I was going to suggest aluminum foil though never tried it.
Would be nice for cycling and running though.
Do they sell lead foil? Or how about a kid's metal lunchbox made in China? Surely its full of lead.
Faygo Focus is offline
Old 11-23-2012, 10:54 AM   #3
Billp1
Fan#: 90510
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
FF Reputation: 1 Billp1 Good Standing Member
Take the Battery out
Billp1 is offline
Old 11-23-2012, 11:50 AM   #4
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,770, Level 78
Points: 14,770, Level: 78 Points: 14,770, Level: 78 Points: 14,770, Level: 78
Level Up 80% Completed
Forum Activity 17%
Any solid metal box will block the signal. A little mints tin.
There are all sorts of small decorative boxes which will work.
Just need one where all metal parts overlap, no holes or gaps in the metal.
Elizabeth is offline
Old 11-23-2012, 03:56 PM   #5
Vernl
Fan#: 92066
What I Drive: 2012 Tri white Titanium 401a
FF Reputation: 1 Vernl Good Standing Member
Any other ideas?
why not just put the fob in a small plastic baggie for protection and hide it under the car as well.
Vernl is offline
Old 11-23-2012, 07:48 PM   #6
jeff_nc
Fan#: 106534
Elizabeth, I tried an Altoids box and it didn't work. Too thin? Maybe a lunch pail is the ticket. Billp1, you're right, I could remove the battery, but I'm worried I'll damage the thing trying to reassemble it quick before the alarm starts. Vernl, the problem is that the doors won't lock if the fob is within 3 feet of the car.
The quest continues...
jeff_nc is offline
Old 11-23-2012, 10:43 PM   #7
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,083, Level 83
Points: 17,083, Level: 83 Points: 17,083, Level: 83 Points: 17,083, Level: 83
Level Up 47% Completed
Forum Activity 7%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
i had to lock keys in someone's explorer today. i put the key in the glovebox and hit the lock button. closed the door and the horn sounded and unlocked the doors. luckily, the explorer still had the push rods on the doors to manually lock the doors. i pushed them down and was golden from there.
Will aka Misfire
misfire is offline
Old 11-23-2012, 11:11 PM   #8
mmmfloorpie
Fan#: 72039
What I Drive: 2014 Ruby Red Ford Fusion SE
Points 119, Level 2
Points: 119, Level: 2 Points: 119, Level: 2 Points: 119, Level: 2
Level Up 38% Completed
FF Reputation: 1 mmmfloorpie Good Standing Member
Does the Mk3 not have the keypad on the driver's door like every other Ford?
mmmfloorpie is offline
Old 11-23-2012, 11:27 PM   #9
Vernl
Fan#: 92066
I have the same keyless fob as you.If i place my fob under the front or back bumper, the doors dont unlock/lock.You should be able to lock the door, hide the fob and leave.The 3 ft you mention is from the sensor in the door.Try it.
Vernl is offline
Old 11-23-2012, 11:35 PM   #10
jdetzel
Fan#: 102548
Points 177, Level 3
Points: 177, Level: 3 Points: 177, Level: 3 Points: 177, Level: 3
Level Up 54% Completed
I carried a spare in my suitcase that was wrapped in aluminum foil. It worked fine but only had it in there for a few hours.
I would think that the foil either works or does not and would have not considered that radio signal could leak out if it was wrapped in foil.
Maybe you could test that theory by leaving a key wrapped in foil in the car overnight.
jdetzel is offline
