Can you overtighten axle nuts? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-21-2012, 02:23 PM   #11
G Ford Fan
Fan#: 80771
What I Drive: 2000 Ford Focus Wagon, SE, Silver.
FF Reputation: 0 G Ford Fan Newbie
I think it depends. I have 2, one goes to 150, and another goes to 250.
Exactly, they are not all the same. There are some that go to 250, they are typically longer than the 150 ft-lb max wrenches.
G Ford Fan is offline
Old 11-21-2012, 02:42 PM   #12
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,295, Level 67
Points: 10,295, Level: 67 Points: 10,295, Level: 67 Points: 10,295, Level: 67
Level Up 62% Completed
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
"whirring" in my experiences with the focus is 90% of the time due to rear wheel bearing failure. The bearing is pressed into the rear drum and you can buy brand new drums already setup with new bearings and dust collars for about $50/side.
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is online now
Old 11-21-2012, 02:45 PM   #13
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
FF Reputation: 9 drunkyoda Good Standing Member
hmmmm... ya it sounds like a bearing... ill check it sometime during this 4 day break lol. as you can tell im not too worried about it.
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 11-21-2012, 06:21 PM   #14
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,772, Level 54
Points: 6,772, Level: 54 Points: 6,772, Level: 54 Points: 6,772, Level: 54
Level Up 11% Completed
Forum Activity 49%
Mine are doing the same thing! Well one side for sure. I'm wondering if the 1.5" drop put them over the edge.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-21-2012, 06:40 PM   #15
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 49%
The rears I mean LOL
Hatch Nation #140
freemind is offline
Old 11-21-2012, 07:14 PM   #16
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
ya... your 1.5" drop... try my drop lol.
Old 11-22-2012, 04:41 AM   #17
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
I've heard bad ones that whirring would be a perfect description of the noise they made, no grind or rumble, just a smooth whir that got louder and louder over coming days, bearing change fixed it. Thinking they can make several sounds there on back or front. Whir means you got some time to fix it, grind or rumble, fix it now or walking in a short time. The grinding means bearing is eating itself.
You jack up vehicle by SUSPENSION not frame, jacked up by frame the suspension is overextended and CVs are not supposed to be cycled under those conditions, the angle will be one not normally seen in use and it SHOULD click if any wear there on an older car. Means nothing if it does, mine all do it. You should never motor car like that under power, can tear up axles.
amc49 is offline
Old 11-22-2012, 11:00 AM   #18
JCH841
JCH841's Avatar
Fan#: 79303
What I Drive: 2013 Blue ST3
Points 906, Level 16
Points: 906, Level: 16 Points: 906, Level: 16 Points: 906, Level: 16
Level Up 6% Completed
FF Reputation: 3 JCH841 Good Standing Member
First of all, it is possible to overtighten anything; that's why they make torque wrenches. Likely not the problem here, but we had a crankshaft failure in a 6000 hp diesel because the factory (over) tightened the connecting rod bolts to the same torque as the main bearing caps and distorted the bearing caps. Most threaded fasteners will develop some adhesion in service; rust, corrosion, heat cycling such that the disassembly torque is likely higher than the assembly torque. In this case if there are any residual stresses or minute fractures from manufacturing/rolling threads, gross overtightening could precipitate a fracture failure.
Growing old is unavoidable. Growing up is optional.
JCH841 is offline
Old 11-22-2012, 08:08 PM   #19
Forum Activity 40%
X2..........
amc49 is offline
Old 11-22-2012, 08:19 PM   #20
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
What I Drive: 97 Impreza coupe, 04 Mazda6
Points 36,564, Level 100
Points: 36,564, Level: 100 Points: 36,564, Level: 100 Points: 36,564, Level: 100
FF Reputation: 13 TheGlassMaker Great Standing Member
Bearing will expand when heated up from the motion of the car I thought you had to tighten just enough to expect the tolerance for that.
I haven't needed to change the bearings in the focus, but in my ranger I went through a few sets.
Do one thing every day that scares you. -Eleanor Roosevelt
TheGlassMaker is offline
