rear wheel bearing - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-20-2012, 04:03 PM   #1
dpmeeks
Fan#: 82112
What I Drive: 2000 Focus SE Zetec
FF Reputation: 3 dpmeeks Good Standing Member
rear wheel bearing
Im needing to replace the pass. side rear wheel bearing on my 2000 SE w/antilock brakes.
Ive read you can buy the drum with the bearing already pressed in the drum which makes the job fairly simple. Ive called the local parts stores and there saying i have to buy the bearing or the hub assy. ?
Can anyone give me some advice on how this is suppose to be done and where to get the parts without going to the dealer ? I looked up the drum w/bearing on Rock Auto and it shows all models except the SE.... thanks !!
dpmeeks is offline
Old 11-20-2012, 04:59 PM   #2
banditracer
Fan#: 82009
What I Drive: 00 ZX2
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 banditracer Good Standing Member
BrakeBest® Select™ - Brake Drum
Oreilly's auto parts: you can order online if you dont have a local store.
Part Number: 9759DGS
Line: BBR
2 year limited warranty
• UPC: 829352552186
• Includes Bearing
•Rear
•Contains Wheel Bearing
Detailed Description
•Overall Height: 3.19"
•Outside Diameter: 9.57"
•Brake (Surface) Depth: 1.69"
•Number of Bolts/Holes: 4
•Bolt Circle Diameter: 4.25"
•Maximum Brake Diameter: 8.04"
•Nominal Brake Diameter: 8.00"
banditracer is offline
Old 11-20-2012, 05:00 PM   #3
banditracer
Fan#: 82009
Points 51, Level 1
Thats for the SE model by the way.
Old 11-20-2012, 05:22 PM   #4
Tymes
Fan#: 94124
What I Drive: 02 SE SOHC SPI
FF Reputation: 8 Tymes Good Standing Member
Remember some of these stores call the SE a ZX4, because that's what it changed to. I've had that problem before.
Somewhere there's a DC10 struggling to get off the ground. I'm not a fan of wings on street cars, I like low key spoilers, but not something that you have to custom order from Boeing.
Tymes is offline
Old 11-20-2012, 05:45 PM   #5
dpmeeks
Fan#: 82112
Figures the one store i didnt check was Oreillys.. LOL.. thanks !!
Is it safe to re-use the axle nut or do i need to get another from the dealer ??
dpmeeks is offline
Old 11-20-2012, 05:49 PM   #6
banditracer
Fan#: 82009
Points 51, Level 1
you should be able to re-use it.
Old 11-20-2012, 07:06 PM   #7
dpmeeks
Fan#: 82112
cool.. thanks
dpmeeks is offline
Old 11-20-2012, 10:37 PM   #8
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Remember to move the tone ring for the ABS from the old drum to the new one :-)
nilskje is offline
Old 11-20-2012, 10:42 PM   #9
dpmeeks
Fan#: 82112
Thanks Nil.. i will :)
dpmeeks is offline
Old 11-22-2012, 08:25 PM   #10
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Reuse nut but make sure it pulls up to torque correctly, you'll feel it give if it's failing. I use them once or several times based on that. Make sure you hit the full torque number, simply very tight there don't cut it, you'll be walking in a week and get to do it over.............175-200ft.lbs. works fine.
amc49 is offline
