Rear hub ass'y replaced: Already going out <5000 miles - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2012, 04:09 AM   #11
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (11)
Hell yea it is.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 11-16-2012, 04:44 AM   #12
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
Points 15,567, Level 80
Points: 15,567, Level: 80 Points: 15,567, Level: 80 Points: 15,567, Level: 80
Level Up 44% Completed
Chilton manual says 173 ftlbs. Also the hub nut needs to be replaced after a few uses.
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 11-16-2012, 05:51 AM   #13
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
I thought he/she said they did replace the hub? I'm doing that on mine in a short while, but I have disc brakes, so .. no big nut to torque, just the 4 that hold the hub on.
Old 11-16-2012, 11:46 PM   #14
zakkius
Fan#: 91044
What I Drive: 2005 Arizona Beige Metallic ZX4
Points 86, Level 1
Points: 86, Level: 1 Points: 86, Level: 1 Points: 86, Level: 1
Level Up 72% Completed
FF Reputation: 1 zakkius Good Standing Member
Noted. Thanks again.
zakkius is offline
Old 11-17-2012, 12:41 AM   #15
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
175-200 works just fine, the car will never know the difference in 10 pounds at torque that high.
It MUST be close on that range (I use 200) or the bearing will shell out in 5 minutes. Simply getting it 'tight' absolutely will not cut it there. The high torque guarantees the bearings are firmly locked together as one part with axle, lower torque lets the bearings wobble slightly and junk city in minutes.
I use the nut over until I feel it give while pulling up to torque, some last twice, some last more, I haven't replaced them yet because they still pull up tight.
amc49 is online now
Old 11-17-2012, 07:47 PM   #16
zakkius
Fan#: 91044
Points 86, Level 1
Alrighty. I'll give it another go and make sure that I torque this one properly (I don't think my friend had a torque wrench available last time). Thanks again.
zakkius is offline
Old 11-19-2012, 02:50 PM   #17
G Ford Fan
Fan#: 80771
What I Drive: 2000 Ford Focus Wagon, SE, Silver.
FF Reputation: 0 G Ford Fan Newbie
When I take the rear drums off to check the brakes, I always tighten them down to the highest setting my torque wrench will read, which is 150 ft-lbs. Yes, the manual does say 180-200 I think. However, I have yet to have any issues on either my 2000 or my wife's 2008 and she has over 90 on her car already.
Just hand tightening them is a no-go. The spec may be more, but 150 feels PLENTY tight enough. Going with the spec won't hurt either.
Just my .02.
G Ford Fan is offline
Old 11-19-2012, 03:15 PM   #18
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
You are also supposed to rotate the brake drum 10 times in the opposite direction while tightening the nut, to avoid damage to the bearing. (per the Ford manual)
elsolo is offline
Old 11-19-2012, 04:49 PM   #19
G Ford Fan
Fan#: 80771
the above is 100% correct and I also do just that.
I spin the drum both directions several times as I am torquing the bearing hub nut down.
This helps to seat the bearing properly and is a very important step.
Old 11-19-2012, 09:40 PM   #20
Forum Activity 40%
I would consider the fact that rolling drum on the last final tighten means that you are exerting torquing force also into the rear suspension in the form of twistup load, that amount of load will be subtracted from your actual nut torque regardless of what your wrench says. Meaning you won't have full torque there....
From like 75 ft. lbs. on up I have wheel bolted on, car on ground, brakes and engine on and someone standing on brake. The only way to guarantee pretty much full torque on nut itself.
amc49 is online now
