Replaced rear 02, still throwing CEL codes? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-18-2012, 01:15 PM   #11
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
I wish I could think of something for ya mate, but right now I can't think of anything helpful thats already been stated..
Gettysburg150 is offline
Old 04-18-2012, 05:36 PM   #12
kkeiran
Fan#: 60322
What I Drive: 2003 Silver SVT
Points 440, Level 8
Points: 440, Level: 8 Points: 440, Level: 8 Points: 440, Level: 8
Level Up 80% Completed
FF Reputation: 1 kkeiran Good Standing Member
I checked the #18 fuse and it looked fine :/
kkeiran is offline
Old 04-21-2012, 08:25 PM   #13
kkeiran
Fan#: 60322
Points 440, Level 8
**nvm
kkeiran is offline
Old 04-24-2012, 06:36 PM   #14
kkeiran
Fan#: 60322
Points 440, Level 8
I just got my car back from a local mechanic. They said it was a bit difficult to locate, but they were able to find a problem in the harness. The sensors were fine, but the bad voltage due was triggering the codes for the 02 and Knock Sensor.
Basically mikebontoft hit the nail right on the head.
Thanks for the replies, everybody! Hopefully I can drive cycle a few days and get through inspection soon before any more issues arise! hehe
kkeiran is offline
Old 11-18-2012, 11:43 AM   #15
the chad
Fan#: 106181
What I Drive: 2003 Red SVT
FF Reputation: 1 the chad Good Standing Member
New to SVT here, bought it the other day and now trying to get rid of the CEL to pass emissions. I'm thinking that I may have the same problem or something extremely similar. Had codes for o2 sensor bank 1, sensor 2 and knock sensor. replaced them both and the code came right back. If anyone has any insight on where I might look through the wiring harness to find the problem. I'm going to start just going through it, but any help would be greatly appreciated.
the chad is offline
Old 11-18-2012, 07:24 PM   #16
stromberg2
Fan#: 57480
Points 280, Level 5
Points: 280, Level: 5 Points: 280, Level: 5 Points: 280, Level: 5
Level Up 60% Completed
FF Reputation: 1 stromberg2 Good Standing Member
Did you replace them with Motorcraft? SVT's are really picky.
Stromberg2
stromberg2 is offline
Old 11-18-2012, 08:18 PM   #17
03SCSVT
Got Bewst?
03SCSVT's Avatar
Fan#: 89182
What I Drive: 2003 Screaming Yellow JRSC SVT
FF Reputation: 5 03SCSVT Good Standing Member
To anyone who has this problem more than once, I recomend tuning the car and in the process turning the post cat O2 off. This is what I did on mine and thus allowing me to run a test pipe without the O2 throwing a code.
2003 Screaming Yellow JR Supercharged SVTF
Hatch Nation #12
03SCSVT is offline
Old 11-18-2012, 11:11 PM   #18
the chad
Fan#: 106181
Thanks for a quick reply. After replacing them the o2 sensor with a bosch replacement, I took a real hard look at all the wiring connections today and located a plug that was disconnected. Now no codes and its running great.
the chad is offline
Old 11-21-2012, 12:14 AM   #19
trackhermit
Fan#: 82003
What I Drive: 02' Silver SVT
Points 184, Level 3
Points: 184, Level: 3 Points: 184, Level: 3 Points: 184, Level: 3
Level Up 68% Completed
FF Reputation: 1 trackhermit Good Standing Member
Also something I've ran into as-well check your vaccum lines and make sure none are broken.. also check the large one near the throttle body it's a black rubber hose make sure it's not slit. Mine was.. I know it's not O2 related but it's something I would still check.
trackhermit is offline
Old 04-25-2013, 10:26 AM   #20
JamesH
Fan#: 95753
What I Drive: 2002 Sonic Blue SVT Piranha
FF Reputation: 1 JamesH Good Standing Member
I'm getting a similar issue on my '02 SVTF - P0141 and P0136 codes come up, I checked the fuse, cleaned the connections and then replaced the 2nd (post-cat) O2 sensor with a Motorcraft one and the codes come back every time.
This is the first thread I've seen discussing wiring diagrams - can anyone link me to a wiring diagram or identify any trouble areas?
JamesH is offline
