Engine vibration NOT mounts - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-17-2012, 03:52 PM   #1
rpokorny
Fan#: 53612
What I Drive: 2004 Grey zx5
FF Reputation: 1 rpokorny Good Standing Member
I have an 04 ZX5 automatic with the Zetec engine 135,000 kms. It started to vibrate about 6 months ago, I did the research and replaced all three mounts with factory mounts, very expensive and didn't solve the problem. I then did a tune up with Motocraft spark plugs and wires, oil and filter and air filter. Vibration is still there. The engine only vibrates at idle. It doesn't matter if I am in neutral, park, drive or reverse. The engine vibrates. The second I touch the gas, the vibration is gone. When looking at the engine, I can see it vibrate and when I put my hand on the engine I can feel it vibrate. It has only been doing it for about 6 months and some days are worse than others. I am at a loss on this one.
rpokorny is offline
Old 11-18-2012, 03:44 PM   #2
Fan4Focus
Fan#: 104234
What I Drive: 2001 White ZX3
Points 126, Level 2
Points: 126, Level: 2 Points: 126, Level: 2 Points: 126, Level: 2
Level Up 52% Completed
FF Reputation: 1 Fan4Focus Good Standing Member
Have you ever had the fuel injectors cleaned or flow checked. Could be a bad injector that leaks or has poor flow at low pressure at idle.
Fan4Focus
Fan4Focus is offline
Old 11-18-2012, 03:55 PM   #3
Elder
Points 12,793, Level 73
Points: 12,793, Level: 73 Points: 12,793, Level: 73 Points: 12,793, Level: 73
Level Up 86% Completed
What's the idle Rpm? And does it stay stable when you shift or turn on the A/C?
PCV hoses have been known to go bad, improved version currently sold by Ford if needed.
Just a couple thoughts if the idle is too low or rough...
sailor is online now
Old 11-18-2012, 09:58 PM   #4
rpokorny
Fan#: 53612
I have never had the injectors cleaned as it runs great other than idle. It idles at about 800 and stays there even with the a/c on. It gets good mileage however it's worth a try. I checked the PCV hose and it doesn't seem to be leaking, but it is soft in spots so I will try replacing it. This is a strange vibration. I am used to engines shaking if they have a vacuum leak or bad injector. I had a 1993 Ford Aerostar that had a vacuum leak and the engine shook badly. The Focus has a vibration like a vibrating chair or cushion. It shakes rapidly but very little travel, perhaps a 1/2 inch back and forth rapidly.
rpokorny is offline
Old 11-19-2012, 10:14 AM   #5
rpokorny
Fan#: 53612
I am going to try some seafoam treatment, replace the PCV valve and the hose and see if it makes a difference. I don't like just throwing parts at a car, but when I took it to the dealer they said that's what they would do as they said it could be any number of things and there are no codes.
rpokorny is offline
Old 11-19-2012, 01:00 PM   #6
FLZ_Boy
Fan#: 104842
What I Drive: 2000 Red ZX3
FF Reputation: 1 FLZ_Boy Good Standing Member
Which mounts were replaced? All three or 2/3?
2012 Toyota Sienna LE 2.7L 6AT (w/Convience Package + Preferred Package)
2000 Ford Focus ZX3 5MT (I want my MPG!)
1994 Toyota Supra 5MT (SZ-R Project Status: Retired, 2012 Speed Ventures Time Trial CC9 Champion)
FLZ_Boy is offline
Old 11-19-2012, 10:24 PM   #7
rpokorny
Fan#: 53612
I replaced all 3 although none looked bad. The dog bone and the transmission mount actually looked like new. The passenger mount had no cracks in it, but it did feel like it lacked any fluid inside.
rpokorny is offline
Old 11-20-2012, 12:51 AM   #8
FLZ_Boy
Fan#: 104842
There is a You Tubedeo named: "Zetec Engine Rough Idle - Issue solved"
In a nutshell, the person thought it was his MAF, turned out to be a crack in his air tube under the throttle body (vacuum leak).
FLZ_Boy is offline
Old 11-20-2012, 12:23 PM   #9
katkrazy2007
Fan#: 105248
What I Drive: 2008 Ebony Focus SES
FF Reputation: 1 katkrazy2007 Good Standing Member
I have the exact same vibration in my 2008 SES exactly as you describe your vibration -- It only does it at idle, but as long as I am accelerating, it is gone. So weird.
<Focus Freak>
katkrazy2007 is offline
Old 11-20-2012, 07:51 PM   #10
Edgenet
Edgenet's Avatar
Fan#: 106043
What I Drive: 2002 Wagon with Zetec, Auto
FF Reputation: 1 Edgenet Good Standing Member
I have read on youtube a mechanic commenting that most vibration complaints come from auto cars he believes the torque converter in the trans not releasing properly at idle. This is a known problem with Ford torque converters. I also have the same problem and my idle is around 590 rpm in drive. The tranny issue seems to make sense.
In my case I do not believe it's the engine mounts, but the vibration is consistent.
Edgenet is offline
